Updated on 2026-09-21 GMT+08:00
CPU Burst
If a CPU limit is set for the containers in a pod, the CPU usage of the containers cannot exceed the limit. Frequent CPU traffic limiting affects service performance and increases the long-tail response latency, especially for latency-sensitive services.
CPU burst is an elastic traffic limiting mechanism that allows temporarily exceeding the CPU limit to reduce the long-tail response time of services. When the CPU quota for a service in each CPU scheduling period is remaining, the system accumulates the CPU quota. If the CPU limit needs to be exceeded in subsequent scheduling periods, the accumulated CPU quota can be used.
  • If CPU burst is not enabled, the CPU quota for a container cannot exceed the limit, and the accumulated burst resources cannot be used.
    Figure 1 CPU burst not enabled
  • After CPU burst is enabled, the CPU quota for a container can exceed the limit to use the accumulated burst resources.
    Figure 2 CPU burst enabled
Notes and Constraints
  • Cluster version: CCE Turbo cluster v1.23.5-r0 or later
  • OS version: Huawei Cloud EulerOS 2.0
  • Volcano: v1.9.0 or later; hybrid deployment: enabled
  2. In the navigation pane, choose Nodes. On the Node Pools tab page, locate the target node pool and choose More > Mixed configuration.
    Ensure that node pool hybrid deployment and traffic limit for CPU burst are enabled.
    After CPU burst is disabled, this function is still enabled on the existing pods where CPU burst has been enabled. Disabling CPU burst takes effect only on new pods.
  3. Deploy a workload in a node pool where hybrid deployment has been enabled. Take Nginx as an example. Set requests to 2 and limits to 4, and create a Service that can be accessed in the cluster for the workload.
    apiVersion: apps/v1
    kind: Deployment
      namespace: default
      replicas: 1
      selector:
        matchLabels:
          app: nginx
      template:
          labels:
            app: nginx
          annotations:
            volcano.sh/enable-quota-burst: "true"
            volcano.sh/quota-burst-time: "200000"
          containers:
          - name: container-1
            image: nginx:latest
            resources:
              limits:
                cpu: "4"
              requests:
                cpu: "2"
          imagePullSecrets:
            - name: default-secret
    apiVersion: v1
    kind: Service
      namespace: default
      labels:
        app: nginx
      selector:
        app: nginx
      ports:
        - name: cce-service-0
          targetPort: 80
          nodePort: 0
          port: 80
          protocol: TCP
      type: ClusterIP
    Annotation
    Mandatory
    Yes
    CPU burst is enabled for the workload.
    No
    To ensure CPU scheduling stability and reduce contention when multiple containers encounter CPU bursts at the same time, the default CPU Burst value is the same as the CPU Quota value, indicating that a container can use a maximum of twice the CPU Limit value. By default, CPU Burst is set for all service containers in a pod.
    For example, if the CPU Limit of a container is 4, the default CPU Burst value is 400000 (1 core = 100000), indicating that a maximum of four additional CPU cores can be used after the value of CPU limit is reached.
  4. Verify CPU burst.
    You can use the wrk tool to increase load of the workload and observe the service latency, traffic limiting, and CPU limit exceeding when CPU Burst is enabled and disabled, respectively.
    1. Run the following command to increase load of the pod. <service_ip> indicates the service IP address associated with the pod.
      # Download and install the wrk tool on the node.
      # The Gzip compression module is enabled in the Apache configuration to simulate the computing logic for the server to process requests.
      # Run the following command to increase the load. Note that you need to change the IP address of the target application.
      wrk -H "Accept-Encoding: deflate, gzip" -t 4 -c 28 -d 120  --latency --timeout 2s http://<service_ip>
    2. Obtain the pod ID.
      kubectl get pod -n <namespace> <pod_name> -o jsonpath='{.metadata.uid}'
    3. You can run the following commands on the node to view the traffic limiting status and CPU limit exceeding status. In the command, <pod_id> indicates the pod ID.
      cat /sys/fs/cgroup/cpu/kubepods/burstable/pod<pod_id>/cpu.stat
      Information similar to the following is displayed:
      nr_periods 0  # Number of scheduling periods
      nr_throttled 0  # Traffic limiting times
      throttled_time 0  # Traffic limiting duration (ns)
      nr_bursts 0 # CPU Limit exceeding times
      burst_time 0 # Total Limit exceeding duration
      Table 1 Result summary in this example
      CPU Burst
      P99 latency
      nr_throttled
      Traffic Limiting Times
      throttled_time
      Traffic Limiting Duration
      nr_bursts
      Limit Exceeding Times
      bursts_time
      Total Limit Exceeding Duration
      Not enabled
      2.96 ms
      986
      14.3s
      0
      0
      Enabled
      456 µs
      0
      0
      469
      3.7s
