Buying a CCE Standard Cluster
On the CCE console, you can easily create Kubernetes clusters. After a cluster is created, the master node is hosted by CCE. You only need to create worker nodes. In this way, you can implement cost-effective O&M and efficient service deployment.
- During the node creation, software packages are downloaded from OBS using the domain name. A private DNS server must be used to resolve the OBS domain name. Therefore, the DNS server address of the subnet where the node resides must be set to the private DNS server address so that the node can access the private DNS server. When you create a subnet, the private DNS server is used by default. If you change the subnet DNS, ensure that the DNS server in use can resolve the OBS domain name.
- You can create a maximum of 50 clusters in a single region.
- After a cluster is created, the following items cannot be changed:
- Cluster type
- Number of master nodes in the cluster
- AZ of a master node
- Network configurations of the cluster, such as the VPC, subnet, Service CIDR block, and kube-proxy settings.
- Network model. For example, change Tunnel network to VPC network.
Step 1: Log In to the CCE Console
- Log in to the CCE console.
- On the Clusters page, click Buy Cluster in the upper right corner.
Step 2: Configure the Cluster
On the Buy Cluster page, configure the parameters.
Basic Settings
Parameter |
Description |
Billing Mode |
Select a billing mode for the cluster as required.
Cluster Name |
Enter a cluster name. Cluster names under the same account must be unique. |
Enterprise Project |
This parameter is available only for enterprise users who have enabled an enterprise project. After an enterprise project (for example, default) is selected, the cluster, nodes in the cluster, cluster security groups, node security groups, and EIPs of the automatically created nodes will be created in this enterprise project. After the cluster is created, do not modify the enterprise projects of nodes, cluster security groups, and node security groups in the cluster. Enterprise projects facilitate project-level management and grouping of cloud resources and users. |
Cluster Version |
Select the Kubernetes version used by the cluster. |
Cluster Scale |
Select a cluster scale for your cluster as required. These values specify the maximum number of nodes that can be managed by the cluster. |
Master Nodes |
Select the number of master nodes. The master nodes are automatically hosted by CCE and deployed with Kubernetes cluster management components such as kube-apiserver, kube-controller-manager, and kube-scheduler.
You can also select AZs for the master nodes. By default, AZs are allocated automatically for the master nodes.
Network Settings
The network settings cover nodes, containers, and Services. For details about the cluster networking and container network models, see Overview.
Parameter |
Description |
VPC |
Select the VPC to which the cluster belongs. If no VPC is available, click Create VPC to create one. The value cannot be changed after the cluster is created. |
Subnet |
Select the subnet to which the master nodes belong. If no subnet is available, click Create Subnet to create one. The value cannot be changed after the cluster is created. |
Default Security Group |
Select the security group automatically generated by CCE or use the existing one as the default security group of the node.
NOTICE:
The default security group must allow traffic from certain ports to ensure normal communication. Otherwise, the node cannot be created. |
Parameter |
Description |
Network Model |
Select VPC network or Tunnel network for your CCE standard cluster. For more information about their differences, see Overview. |
Container CIDR Block (configured for CCE standard clusters) |
Configure the CIDR block used by containers. The value determines the maximum number of containers in your cluster. |
Parameter |
Description |
Service CIDR Block |
Configure the Service CIDR blocks for containers in the same cluster to access each other. The value determines the maximum number of Services you can create. The value cannot be changed after the cluster is created. |
Request Forwarding |
Select IPVS or iptables for your cluster. For details, see Comparing iptables and IPVS.
(Optional) Advanced Settings
Parameter |
Description |
Certificate Authentication |
CPU Management |
If enabled, exclusive CPU cores can be allocated to workload pods. For details, see CPU Policy. |
Overload Control |
After this function is enabled, concurrent requests will be dynamically controlled based on the resource demands received by master nodes to ensure the stable running of the master nodes and the cluster. For details, see Cluster Overload Control. |
Resource Tag |
You can add resource tags to classify resources. You can create predefined tags on the TMS console. The predefined tags are available to all resources that support tags. You can use predefined tags to improve the tag creation and resource migration efficiency.
Key specifications:
Description |
You can enter description for the cluster. A maximum of 200 characters are allowed. |
Step 3: Select Add-ons
Click Next: Select Add-on. On the page displayed, select the add-ons to be installed during cluster creation.
Basic capabilities
Add-on Name |
Description |
CCE Container Network (Yangtse CNI) |
This is the basic cluster add-on. It provides network connectivity, Internet access, and security isolation for pods in your cluster. |
CCE Container Storage (Everest) |
This add-on (CCE Container Storage (Everest)) is installed by default. It is a cloud native container storage system based on CSI and supports cloud storage services such as EVS. |
CoreDNS |
This add-on (CoreDNS) is installed by default. It provides DNS resolution for your cluster and can be used to access the in-cloud DNS server. |
NodeLocal DNSCache |
(Optional) If selected, this add-on (NodeLocal DNSCache) will be automatically installed. NodeLocal DNSCache improves cluster DNS performance by running a DNS caching agent on cluster nodes. |
Add-on Name |
Description |
CCE Node Problem Detector |
(Optional) If selected, this add-on (CCE Node Problem Detector) will be automatically installed to detect faults and isolate nodes for prompt cluster troubleshooting. |
Step 4: Configure Add-ons
Click Next: Add-on Configuration.
Basic capabilities
Add-on Name |
Description |
This add-on is unconfigurable. |
This add-on is unconfigurable. After the cluster is created, choose Add-ons in the navigation pane of the cluster console and modify the configuration. |
CoreDNS |
Add-on Name |
Description |
Step 5: Confirm the Configuration
After the parameters are specified, click Next: Confirm configuration. The cluster resource list is displayed. Confirm the information and click Submit.
It takes about 5 to 10 minutes to create a cluster. You can click Back to Cluster List to perform other operations on the cluster or click Go to Cluster Events to view the cluster details.
Related Operations
- After creating a cluster, you can use the Kubernetes command line (CLI) tool kubectl to connect to the cluster. For details, see Connecting to a Cluster Using kubectl.
- Add nodes to the cluster. For details, see Creating a Node.
