What Is CCE?
Cloud Container Engine (CCE) is a Kubernetes cluster hosting service for enterprises. It manages the entire lifecycle of containerized applications and delivers scalable, high-performance solutions for deploying and managing cloud native applications.
Why CCE?
CCE is a one-stop platform integrating compute (ECS), networking (VPC, EIP, and ELB), storage (EVS, SFS, and OBS), and many other services. Multi-AZ, multi-region disaster recovery (DR) ensures high availability (HA) of Kubernetes clusters.
For more information, see CCE Advantages and Application Scenarios.
CCE Cluster Types
There are multiple types of CCE clusters.
| Cluster Type | CCE standard | CCE Turbo |
| Positioning | Standard clusters that provide highly reliable, secure containers for commercial use | Next-generation clusters designed for Cloud Native 2.0, with accelerated compute, networking, and scheduling |
| Application Scenario | For users who expect to use container clusters to manage applications, obtain elastic compute resources, and enable simplified management of compute, network, and storage resources | For users who have higher requirements on performance, resource utilization, and full-scenario coverage |
| Network | For scenarios where there are not so many containers and high performance is not needed, the following networks are provided:
| Cloud Native 2.0 networks: for scenarios where there are many containers and high performance is needed A maximum of 2,000 nodes is supported. |
| Host Ports (hostPort) for Pods | Supported | Not supported |
| Network Performance | The container network is overlaid with the VPC network, causing certain performance loss. | The VPC network and container network are flattened into one for zero performance loss. |
| Network Isolation |
| Pods can be associated with security groups for isolation. This ensures consistent security isolation both within and outside a cluster. |
| Container Resource Isolation | cgroups are used to isolate common containers. |
| Edge Infrastructure Management | Not supported | Support for management of edge cloud resources |
