Situation Awareness
Help Center/ Cloud Container Engine/ User Guide (Ankara Region)/ Best Practices/ Networking/ Implementing Sticky Session Through Load Balancing
Concepts
Session persistence is one of the most common while complex problems in load balancing.
Session persistence is also called sticky sessions. After the sticky session function is enabled, requests from the same client are distributed to the same backend ECS by the load balancer for better continuity.
In load balancing and sticky session, connection and session are two key concepts. When only load balancing is concerned, session and connection refer to the same thing.
Simply put, if a user needs to log in, it can be regarded as a session; otherwise, a connection.
The sticky session mechanism fundamentally conflicts with the basic functions of load balancing. A load balancer forwards requests from clients to multiple backend servers to avoid overload on a single server. However, sticky session requires that some requests be forwarded to the same server for processing. Therefore, select a proper sticky session mechanism based on the application environment.
Layer-4 Load Balancing (Service)
In layer-4 load balancing, source IP address-based sticky session (Hash routing based on the client IP address) can be enabled. To enable source IP address-based sticky session on Services, the following conditions must be met:
  1. Service Affinity of the Service is set to Node level (that is, the value of the externalTrafficPolicy field of the Service is Local).
  2. Enable the source IP address-based sticky session in the load balancing configuration of the Service.
    apiVersion: v1
    kind: Service
      namespace: default
      annotations:
        kubernetes.io/elb.class: union
        kubernetes.io/elb.id: 56dcc1b4-8810-480c-940a-a44f7736f0dc
        kubernetes.io/elb.lb-algorithm: ROUND_ROBIN
        kubernetes.io/elb.session-affinity-mode: SOURCE_IP
      selector:
        app: nginx
      externalTrafficPolicy: Local
      ports:
        - name: cce-service-0
          targetPort: 80
          nodePort: 32633
          port: 80
          protocol: TCP
      type: LoadBalancer
  3. Anti-affinity is enabled for the backend application corresponding to the Service.
Layer-7 Load Balancing (Ingress)
In layer-7 load balancing, sticky session based on HTTP cookies and app cookies can be enabled. To enable such sticky session, the following conditions must be met:
  1. The application (workload) corresponding to the ingress is enabled with workload anti-affinity.
  2. Node affinity is enabled for the Service corresponding to the ingress.
  1. Create an Nginx workload.
    Set the number of pods to 3 and set the podAntiAffinity.
    kind: Deployment
    apiVersion: apps/v1
      namespace: default
      replicas: 3
      selector:
        matchLabels:
          app: nginx
      template:
          labels:
            app: nginx
          containers:
            - name: container-0
              image: 'nginx:perl'
              resources:
                limits:
                  cpu: 250m
                  memory: 512Mi
                requests:
                  cpu: 250m
                  memory: 512Mi
          imagePullSecrets:
            - name: default-secret
          affinity:
            podAntiAffinity:                   # Pod anti-affinity.
              requiredDuringSchedulingIgnoredDuringExecution:
                - labelSelector:
                    matchExpressions:
                      - key: app
                        operator: In
                        values:
                          - nginx
                  topologyKey: kubernetes.io/hostname
  2. Creating a NodePort Service
    Configure the sticky session in a Service. An ingress can connect to multiple Services, and each Service can have different sticky sessions.
    apiVersion: v1
    kind: Service
      namespace: default
      annotations:
        kubernetes.io/elb.session-affinity-mode: HTTP_COOKIE      # HTTP cookie type.
        kubernetes.io/elb.session-affinity-option: '{"persistence_timeout":"1440"}'   # Session stickiness duration, in minutes. The value ranges from 1 to 1440.
      selector:
        app: nginx
      ports:
          protocol: TCP
          port: 80
          targetPort: 80
          nodePort: 32633            # Node port number.
      type: NodePort
      externalTrafficPolicy: Local   # Node-level forwarding.
    You can also select APP_COOKIE.
    apiVersion: v1
    kind: Service
      namespace: default
      annotations:
        kubernetes.io/elb.session-affinity-mode: APP_COOKIE     # Select APP_COOKIE.
        kubernetes.io/elb.session-affinity-option: '{"app_cookie_name":"test"}'  # Application cookie name.
  3. Create an ingress and associate it with a Service.
    kind: Ingress
      namespace: default
      annotations:
        kubernetes.io/elb.port: '80'
        kubernetes.io/elb.autocreate:
              "type":"public",
              "bandwidth_name":"cce-bandwidth-test",
              "bandwidth_chargemode":"traffic",
              "bandwidth_size":1,
              "bandwidth_sharetype":"PER",
              "eip_type":"5_bgp"
      rules:
      - host: 'www.example.com'
        http:
          paths:
          - path: '/'
            backend:
              service:
                name: nginx     #Service name
                port:
                  number: 80
            property:
      ingressClassName: cce
  4. Log in to the ELB console, access the load balancer details page, and check whether the sticky session feature is enabled.
