Cluster Rolling Upgrade
Check Items
Check whether your cluster is eligible for a rolling upgrade. The check results show that the rolling upgrade is not supported.
Rolling upgrades cannot be performed if the tenant's resource quotas are insufficient.
Contact O&M personnel to expand resources and perform the check again.
