Upgrade Overview
To enable interoperability from one Kubernetes installation to the next, you must upgrade your Kubernetes clusters before the maintenance period ends.
After the latest Kubernetes version is available in CCE, CCE will describe the changes in this version.
You can use the CCE console to upgrade the Kubernetes version of a cluster.
An upgrade tag will be displayed on the cluster card view if there is a new version for the cluster to upgrade.
How to check:
Log in to the CCE console and check whether the message "New version available" is displayed in the lower left corner of the cluster. If yes, the cluster can be upgraded. View the release notes for the latest version. For details, see Release Notes for CCE Cluster Versions. If no such a message is displayed, the cluster is of the latest version.
Cluster Upgrade Process
The cluster upgrade process involves pre-upgrade check, backup, upgrade, and post-upgrade verification.
![](https://support.huaweicloud.com/intl/en-us/eu-west-0-usermanual-cce/en-us_image_0000001647417828.png)
After determining the target version of the cluster, read the precautions carefully and prevent function incompatibility during the upgrade.
- Pre-upgrade check
Before a cluster upgrade, CCE checks the compatibility of nodes, add-ons, and workloads in the cluster to reduce the probability of upgrade failures to the best extend. If any exception is detected, rectify the fault as prompted on the console.
- Backup
During the upgrade, cluster data is backed up by default. You can also back up the entire master nodes as needed. Cloud Backup and Recovery (CBR) will be used for full-node backup. It takes about 20 minutes to back up one node.
- Upgrade
During the upgrade, configure upgrade parameters, such as the step for add-on upgrade or node rolling upgrade. After the upgrade parameters are configured, the add-ons and nodes will be upgraded one by one.
- Post-upgrade verification
After the upgrade, manually check services and ensure that services are not interrupted by the upgrade.
Cluster Upgrade
The following table describes the target version to which each cluster version can be upgraded and the supported upgrade modes.
Source Version |
Target Version |
Upgrade Mode |
v1.25 |
v1.27 |
In-place upgrade |
v1.23 |
v1.25 |
In-place upgrade |
v1.21 |
v1.25 v1.23 |
In-place upgrade |
v1.19 |
v1.23 v1.21 |
In-place upgrade |
v1.17 |
v1.19 |
In-place upgrade |
v1.15 |
v1.19 |
In-place upgrade |
v1.13 |
v1.15 |
Rolling upgrade |
Upgrade Modes
Different upgrade modes have different advantages and disadvantages.
Upgrade Mode |
Method |
Advantage |
Disadvantage |
In-place upgrade |
Kubernetes components, network components, and CCE management components are upgraded on the node. During the upgrade, service pods and networks are not affected. The SchedulingDisabled label will be added to all existing nodes. After the upgrade is complete, you can properly use existing nodes. |
You do not need to migrate services, ensuring service continuity. |
In-place upgrade does not upgrade the OS of a node. If you want to upgrade the OS, clear the corresponding node data after the node upgrade is complete and reset the node to upgrade the OS to a new version. |
Rolling upgrade |
Only the Kubernetes components and certain network components are upgraded on the node. The SchedulingDisabled label will be added to all existing nodes to ensure that the running applications are not affected.
NOTICE:
Services are not interrupted. |
