Updated on 2026-09-21 GMT+08:00
Prometheus Server View
Prometheus with local data storage enabled scrapes the metrics of all hosts and components. The metrics are then reported to and stored on AOM or a third-party monitoring platform. The Prometheus Server view displays some built-in metrics provided by Prometheus, which can be used to monitor and measure system performance and status.
Metric Description
You can view Prometheus Server metrics in the following table.
Figure 1 Prometheus Server metrics
Table 1 Prometheus Server metrics
Metric
Unit
Target Sync
second
Collection latency of the target.
Targets
N/A
Total number of metrics collected by the target.
Average Scrape Interval
second
Interval for collecting metrics.
Scrape Failures
N/A
The number of collection failures.
Appended Samples Rate
N/A
The rate at which samples are added to the head.
Head Series
N/A
The number of series in the head.
Head Chunks
N/A
The number of head blocks.
Query Rate
N/A
The number of Prometheus queries per second.
P90 Query Duration
second
Duration for querying 90% of operations on different shards.
Remote Sample Lag Ratio
second
Percentage of the highest timestamp of samples stored in WAL.
Remote Write Traffic
byte/s
Remote write rate.
Current Shards
N/A
The number of shards used for parallel sending to the remote storage.
Max Shards
N/A
Maximum number of shards that the queue is allowed to run.
Min Shards
N/A
Minimum number of shards that the queue is allowed to run.
Desired Shards
N/A
The number of shards that the queue wants to run based on the percentage of input samples to output samples.
Shard Capacity
N/A
Capacity of each shard of the queue used for parallel sending to the remote storage.
Pending Samples
N/A
Current TSDB Segment
N/A
WAL segment index that TSDB is currently writing to.
Current Segment of Remote Write
N/A
Current segment from which the WAL watcher is reading records.
Sample Discard Rate
N/A
The rate at which samples are discarded after being read from WAL before being sent via remote write.
Sample Failure Rate
N/A
Rate of samples that failed to be sent to remote storage due to unrecoverable errors.
Sample Retry Rate
N/A
Rate of samples that failed to be sent to remote storage due to recoverable errors and were resent.
Retry Rate of Enqueuing
N/A
Retry rate of enqueuing failed due to full shard queue.
Metric List
The following is the metric list of the Prometheus Server view.
Table 2 Metric description
Metric
Type
prometheus_target_sync_length_seconds_sum
Summary
Collection latencies of different targets.
prometheus_sd_discovered_targets
Gauge
The number of metrics collected by different targets.
prometheus_target_interval_length_seconds_sum
Summary
Collection interval.
prometheus_target_scrapes_exceeded_body_size_limit_total
Counter
prometheus_tsdb_head_samples_appended_total
Counter
Total number of samples added to the head.
prometheus_tsdb_head_series
Gauge
The number of series in the head block.
prometheus_tsdb_head_chunks
Gauge
The number of chunks in the head block.
prometheus_engine_query_duration_seconds_count
Counter
The number of queries.
Counter
Time taken by queries to complete, in seconds.
prometheus_remote_storage_highest_timestamp_in_seconds
Gauge
Latest timestamp in the remote storage.
prometheus_remote_storage_queue_highest_sent_timestamp_seconds
Gauge
Latest timestamp in the Prometheus shard.
prometheus_remote_storage_bytes_total
Counter
Total number of bytes of data (non-metadata) sent by the queue after compression.
prometheus_remote_storage_shards
Gauge
prometheus_remote_storage_shards_max
Gauge
prometheus_remote_storage_shards_min
Gauge
prometheus_remote_storage_shards_desired
Gauge
prometheus_remote_storage_shard_capacity
Gauge
prometheus_remote_storage_pending_samples
Gauge
The number of pending samples in queue shards to be sent to remote storage.
prometheus_tsdb_wal_segment_current
Gauge
prometheus_wal_watcher_current_segment
Gauge
Current segment from which the WAL is reading records.
prometheus_remote_storage_dropped_samples_total
Gauge
prometheus_remote_storage_failed_samples_total
Gauge
prometheus_remote_storage_retried_samples_total
Gauge
The number of samples that failed to be sent to remote storage due to recoverable errors and were resent.
prometheus_remote_storage_enqueue_retries_total
Gauge
The number of retries upon enqueuing failed due to full shard queue.
