Help Center/
Cloud Container Engine/
User Guide/
Storage Management: FlexVolume (Deprecated)/
Using SFS Turbo File Systems as Storage Volumes/
Overview
Updated on 2025-04-27 GMT+08:00
Overview
CCE allows you to mount a volume created from an SFS Turbo file system to a container to store data persistently. Provisioned on demand and fast, SFS Turbo is suitable for DevOps, container microservices, and enterprise OA scenarios.
Figure 1 Mounting SFS Turbo volumes to CCE
- Standard file protocols: You can mount file systems as volumes to servers, the same as using local directories.
- Data sharing: The same file system can be mounted to multiple servers, so that data can be shared.
- Private network: User can access data only in private networks of data centers.
- Data isolation: The on-cloud storage service provides exclusive cloud file storage, which delivers data isolation and ensures IOPS performance.
- Use cases: Deployments/StatefulSets in the ReadWriteMany mode, DaemonSets, and jobs created for high-traffic websites, log storage, DevOps, and enterprise OA applications
