Updated on 2026-09-21 GMT+08:00
Node ID File
Check Items
Check the ID file format.
  1. On the Nodes page of the CCE console, click the name of the abnormal node to go to the ECS page.
  2. Copy the node ID and save it to the local host.
    Figure 1 Copying a node ID
  3. Log in to the abnormal node and back up the file.
    cp /var/lib/cloud/data/instance-id /tmp/instance-id
    cp /var/paas/conf/server.conf /tmp/server.conf
  4. Log in to the abnormal node and write the obtained node ID to the file.
    echo Node ID > /var/lib/cloud/data/instance-id
    echo Node ID > /var/paas/conf/server.conf
