Situation Awareness
On this page
New Pod Check
Updated on 2024-01-26 GMT+08:00
Check Item
  • Check whether pods can be created on the existing nodes after the cluster is upgraded.
  • Check whether pods can be created on new nodes after the cluster is upgraded.
After creating a node based on New Node Check, create a DaemonSet workload to create pods on each node.
Go to the CCE console, access the cluster console, and choose Workloads in the navigation pane. On the displayed page, switch to the DaemonSets tab page and click Create Workload or Create from YAML in the upper right corner. For details, see Creating a DaemonSet.
You are advised to use the image for routine tests as the base image. You can deploy a pod by referring to the following YAML file.
In this test, YAML deploys DaemonSet in the default namespace, uses ngxin:perl as the base image, requests 10 MB CPU and 10 MiB memory, and limits 100 MB CPU and 50 MiB memory.
apiVersion: apps/v1
kind: DaemonSet
  namespace: default
  selector:
    matchLabels:
      app: post-upgrade-check
      version: v1
  template:
      labels:
        version: v1
      containers:
        - name: container-1
          image: nginx:perl
          imagePullPolicy: IfNotPresent
          resources:
            requests:
              cpu: 10m
              memory: 10Mi
            limits:
              cpu: 100m
              memory: 50Mi
After the workload is created, check whether the pod status of the workload is normal.
After the check is complete, go to the CCE console and access the cluster console. Choose Workloads in the navigation pane. On the displayed page, switch to the DaemonSets tab page, choose More > Delete in the Operation column of the post-upgrade-check workload to delete the test workload.
Solution
If the pod cannot be created or the pod status is abnormal, contact technical support and specify whether the exception occurs on new nodes or existing nodes.
