Managing Custom Resources
Custom Resource Definition (CRD) is an extension of Kubernetes APIs. When default Kubernetes resources cannot meet service requirements, you can use CRDs to define new resource types. According to CRD, you can create custom resources in a cluster to meet service requirements. CRD allows you to create new resource types without adding new Kubernetes API servers. This makes cluster management more flexible.
Creating a CRD
- Log in to the CCE console.
- Click the cluster name to go to the cluster console, choose Custom Resources in the navigation pane, and click the Create from YAML in the upper right corner.
- Edit the YAML file to create the CRD that matches your service's requirements. For details, see Extend the Kubernetes API with CustomResourceDefinitions.
- Click OK.
Viewing CRDs and Their Resources
- Click the cluster name to access the cluster console. Choose Custom Resources in the navigation pane.
- On the Custom Resources page, view CRDs and their resources.
- View a CRD and its YAML.
All CRDs in the cluster as well as their API groups, API versions, and resource application scopes are listed. Click View YAML in the Operation column of a CRD to view its YAML.
You can enter a keyword in the search box to search for target resource types.
- View the resources of a CRD.
Locate a CRD in the list and click View Details in the Operation column to view the resources.
Common Issues
This section covers common issues encountered when managing custom resources.
IAM User Cannot View or Edit CRDs
Symptom
You can see a permission denied error when attempting to view or edit a CRD.
customresourcedefinitions.apiextensions.k8s.io is forbidden: User "xxx" cannot list resource "customresourcedefinitions" in API group "apiextensions.k8s.io" at the cluster scope
Solution
Grant the IAM user Kubernetes RBAC permissions for CRD resources. For details, see Using kubectl to Configure Namespace Permissions. The requiredscope is as follows:
- API group (apiGroups): apiextensions.k8s.io
- Resources: customresourcedefinitions
The following example demonstrates read-only access:
apiVersion: rbac.authorization.k8s.io/v1 kind: ClusterRole metadata: name: crd-reader # Cluster role name rules: - apiGroups: ["apiextensions.k8s.io"] # API group of CRD resources resources: ["customresourcedefinitions"] # CRD resource object verbs: ["get", "list", "watch"] # Retain only the read-only permission. --- # Specify the user or group to bind. apiVersion: rbac.authorization.k8s.io/v1 kind: ClusterRoleBinding metadata: name: crd-reader-binding subjects: - kind: User # Alternatively, user group name: 0c97ac3cb280f4d91fa7c0096739e1f8 # IAM user ID or user group ID apiGroup: rbac.authorization.k8s.io roleRef: kind: ClusterRole name: crd-reader # Cluster role name apiGroup: rbac.authorization.k8s.io
IAM User Cannot View CRs
Symptom
You can see a permission denied error when attempting to view or edit a custom resource (CR). The following example uses podmonitors:
Error from server (Forbidden): podmonitors.monitoring.coreos.com is forbidden: User "xxx" cannot list resource "podmonitors" in API group "monitoring.coreos.com" at the cluster scope
Solution
To view a CR, an IAM user must have Kubernetes RBAC permissions for that specific CR type. For details, see Using kubectl to Configure Namespace Permissions. The required permissions are as follows:
- API group (apiGroups): The API group of the parent CRD, for example, monitoring.coreos.com
- Resources: The CR resource name, for example, podmonitors
apiVersion: rbac.authorization.k8s.io/v1 kind: ClusterRole metadata: name: crd-cr-reader rules: # 1. Grant permission to view the CRD definition. - apiGroups: ["apiextensions.k8s.io"] resources: ["customresourcedefinitions"] verbs: ["get", "list", "watch"] # 2. Grant permission to view the CR instance. - apiGroups: ["Your CRD API groups"] # Example: monitoring.coreos.com resources: ["Your CR resource name"] # Example: podmonitors verbs: ["get", "list", "watch"] # Retain only the read-only permission. --- # Specify the user or group to bind. apiVersion: rbac.authorization.k8s.io/v1 kind: ClusterRoleBinding metadata: name: crd-cr-reader-binding subjects: - kind: User # Alternatively, user group name: 0c97ac3cb280f4d91fa7c0096739e1f8 # IAM user ID or user group ID apiGroup: rbac.authorization.k8s.io roleRef: kind: ClusterRole name: crd-cr-reader # Cluster role name apiGroup: rbac.authorization.k8s.io
