Node Configuration File
Check Items
Check whether the configuration files of key components exist on the node.
The following table lists the files to be checked.
File Name
File Content
Remarks
/opt/cloud/cce/kubernetes/kubelet/kubelet
kubelet command line startup parameters
None
/opt/cloud/cce/kubernetes/kubelet/kubelet_config.yaml
kubelet startup parameters
None
/opt/cloud/cce/kubernetes/kube-proxy/kube-proxy
kube-proxy command line startup parameters
None
/etc/sysconfig/docker
Docker configuration file
Not checked when containerd or the Debain-Group machine is used.
/etc/default/docker
Not checked when containerd or the Centos-Group machine is used.
Solution
Reset the node. For details, see Resetting a Node. Alternatively, contact technical support to restore the file and then perform the upgrade.
