Before You Start
Before the upgrade, you can check whether your cluster can be upgraded and which versions are available on the CCE console. For details, see Cluster Upgrade Overview.
Precautions
Before upgrading a cluster, pay attention to the following points:
- Perform an upgrade during off-peak hours to minimize the impact on your services.
- Before upgrading a cluster, learn about the features and differences of each cluster version in Kubernetes Release Notes to prevent exceptions due to the use of an incompatible cluster version. For example, check whether any APIs deprecated in the target version are used in the cluster. Otherwise, calling the APIs may fail after the upgrade. For details, see Deprecated APIs.
- Do not upgrade a cluster within 10 minutes after the cluster configuration is modified on the Settings page. Otherwise, the cluster upgrade may fail due to operation conflicts.
During a cluster upgrade, pay attention to the following points that may affect your services:
- During a cluster upgrade, do not perform any operation on the cluster. If you stop, restart, or delete nodes while upgrading the cluster, the upgrade will fail.
- Before upgrading a cluster, ensure no high-risk operations are performed in the cluster. Otherwise, the cluster upgrade may fail or the configuration may be lost after the upgrade. Common high-risk operations include modifying cluster node configurations locally and modifying the configurations of the listeners managed by CCE on the ELB console. Instead, modify configurations on the CCE console so that the modifications can be automatically inherited during the upgrade.
- During a cluster upgrade, the running workloads will not be interrupted, but access to the API server will be temporarily interrupted.
- By default, application scheduling is not restricted during a cluster upgrade. During an upgrade of the following early cluster versions, the node.kubernetes.io/upgrade taint (equivalent to NoSchedule) will be added to the nodes in the cluster and removed after the cluster is upgraded:
- All v1.15 clusters
- All v1.17 clusters
- v1.19 clusters with patch version v1.19.16-r4 or earlier
- v1.21 clusters with patch version v1.21.7-r0 or earlier
- v1.23 clusters with patch version v1.23.5-r0 or earlier
- During a cluster upgrade, if an add-on is also upgraded and cluster resources are limited, add-on pods can use resources that would otherwise be allocated to service pods. This may result in the eviction of service pods. After the add-on is upgraded, the evicted service pods will automatically recover.
- When you upgrade a cluster to v1.28 or later, CCE will create an equal number of new master nodes to gradually replace the old ones. After the upgrade is complete, the IP addresses of the master nodes will change. If you accessed the cluster via master node IP addresses before, use the cluster's unified EIP or private IP address after the upgrade. For details, see Connection information.
- During a cluster upgrade, the system automatically edits the /etc/rc.local file. This operation may trigger security program alarms. You can ignore the alarms.
- You are advised to select Ignore the pre-allocated CPU and memory of the DaemonSet container when configuring auto scaling for a node pool. Otherwise, resource requests changed during the upgrade of an add-on or component running as a DaemonSet may affect the auto scaling capability of the node pool. For example, the ICAgent component is automatically upgraded during cluster upgrades. If you do not select this option, you must check whether the resource application of the component increases and dynamically adjust the auto scaling policy of the node pool.
- If an error occurred during a cluster upgrade, the cluster can be rolled back using the backup data. If you perform other operations (for example, modifying cluster specifications) after a successful cluster upgrade, the cluster cannot be rolled back using the backup data.
- If your cluster is upgraded to v1.21.10-r0, v1.23.8-r0, v1.25.3-r0, or later, the following add-ons must be upgraded to the target version if they are installed in the cluster (for details, see Data Disk Shared Between a Container Engine and kubelet Components):
- CCE Node Problem Detector: v1.18.10 or later
- Cloud Native Log Collection: v1.3.0 or later
- When clusters using the tunnel network model are upgraded to v1.19.16-r4, v1.21.7-r0, v1.23.5-r0, v1.25.1-r0, or later, SNAT rules that have a destination address within the pod CIDR block but a source address outside the pod CIDR block will be removed. If you have configured VPC routes to directly access all pods from outside the cluster, only pods on the corresponding nodes will remain directly accessible after the upgrade.
- The new add-on versions (see Release History) of the NGINX Ingress Controller allow graceful exit and the grace period for deleting the ELB backend controller and support hitless upgrades. During the upgrade of the add-on versions listed in the following table, services may be unavailable for a short period of time. If the following add-on versions have been installed in the cluster, perform the upgrade during off-peak hours.
Add-on Version
Version Range
2.1.x
x < 32
2.2.x
x < 41
2.4.x
x < 4
- Upgrading a cluster will restart NetworkManager. This will trigger the DHCP client to renew IP address leasing. By default, /etc/resolv.conf is updated based on the subnet DNS configuration. Modify the DNS configuration on the VPC console. For details, see How Do I Change the DNS Server Address of an ECS?
- For more details, see Version Differences.
Version Differences
Upgrade Path |
Version Difference |
Self-Check |
All upgrade paths |
Pay attention to Kubernetes API changes. For details, see Deprecated APIs. |
Check the API version used in the cluster. Do not use a deprecated API version. Change the API version to the one recommended in Deprecated APIs. |
From v1.28 to v1.29 or v1.31 |
In Kubernetes 1.29, the startup behavior of kube-proxy has been modified. This update allows kube-proxy to use a value smaller than the node sysctl setting. For example, if the kernel value of nf_conntrack_max on a node is set to 1000000, but kube-proxy calculates a value of 131072, the value 131072 calculated by kube-proxy will be used. Community PR: https://github.com/kubernetes/kubernetes/pull/120448 |
This issue may occur on nodes that generate a large number of connections, such as gateway nodes. Check whether the value of nf_conntrack_max has been changed to a large value (for example, 4294967295 or 1000000) using sysctl. After a node is upgraded, the value calculated by kube-proxy is used, and the parameter is overwritten with a smaller value (100,000+ or 200,000+), which affects traffic during peak hours. Configure conntrack-min using kube-proxy of the node pool instead of modifying the OS kernel parameter nf_conntrack_max. For details, see Configuring a Node Pool. |
v1.23 or v1.25 Upgraded to v1.27 |
Docker is no longer recommended. Use containerd instead. For details, see Container Runtimes. |
This item has been included in the pre-upgrade check. |
v1.21 or v1.19 Upgraded to v1.23 |
For the NGINX Ingress Controller of an earlier version (community version v0.49 or earlier, corresponding to CCE nginx-ingress version v1.x.x), the ingress type is not specified as nginx during ingress creation. This means the ingress can also be managed by NGINX Ingress Controller even if kubernetes.io/ingress.class: nginx is not added to annotations. However, for the NGINX Ingress Controller of a later version (community version v1.0.0 or later, or CCE nginx-ingress version v2.x.x), the ingresses created without specifying the Nginx type will not be managed by the NGINX Ingress Controller, and ingress rules will become invalid, which interrupts services. |
This item has been included in the pre-upgrade check. You can also perform the self-check by referring to NGINX Ingress Controller. |
v1.19 to v1.21 |
The bug of exec probe timeouts is fixed in Kubernetes v1.21. Before this bug is fixed, the exec probe does not consider the timeoutSeconds field. Instead, the probe will run indefinitely, even beyond its configured deadline. It will stop until the result is returned. If this field is not specified, the default value 1 is used. This field takes effect after the upgrade. If the probe runs over 1 second, the application health check may fail and the application may restart frequently. |
Before the upgrade, check whether the timeout is properly set for the exec probe. |
kube-apiserver of CCE v1.19 or later requires that the Subject Alternative Names (SANs) field be configured for the certificate of your webhook server. Otherwise, kube-apiserver fails to call the webhook server after the upgrade, and containers cannot be started properly. Root cause: X.509 CommonName is discarded in Go v1.15. kube-apiserver of CCE v1.19 is compiled using Go v1.15. If your webhook certificate does not have SANs, kube-apiserver does not process the CommonName field of the X.509 certificate as the host name by default. As a result, the authentication fails. |
Before the upgrade, check whether the SAN field is configured in the certificate of your webhook server.
v1.15 to v1.19 |
The control plane of CCE v1.19 clusters is incompatible with kubelet v1.15. When a node fails to upgrade or restarts after the master node has been successfully upgraded, it is likely to enter the NotReady state. This is because kubelet restarts and attempts to re-register the node, but the default registration labels (failure-domain.beta.kubernetes.io/is-baremetal and kubernetes.io/availablezone) used in v1.15 are considered invalid by v1.19 kube-apiserver. The valid labels in v1.19 clusters are node.kubernetes.io/baremetal and failure-domain.beta.kubernetes.io/zone. |
In CCE v1.15 and v1.19 clusters, the Docker storage driver file system has been changed from XFS to Ext4. As a result, the import package sequence may be abnormal in the pods of upgraded Java application, leading to pod exceptions. |
Before the upgrade, check the Docker configuration file /etc/docker/daemon.json on the node. Check whether the value of dm.fs is xfs.
"storage-driver": "devicemapper",
"storage-opts": [
"dm.thinpooldev=/dev/mapper/vgpaas-thinpool",
"dm.use_deferred_removal=true",
"dm.fs=xfs",
"dm.use_deferred_deletion=true"
kube-apiserver of CCE v1.19 or later requires that the Subject Alternative Names (SANs) field be configured for the certificate of your webhook server. Otherwise, kube-apiserver fails to call the webhook server after the upgrade, and containers cannot be started properly. Root cause: X.509 CommonName is discarded in Go v1.15. kube-apiserver of CCE v1.19 is compiled using Go v1.15. The CommonName field is processed as the host name. As a result, the authentication fails. |
NOTICE:
To mitigate the impact of version differences on cluster upgrade, CCE performs special processing during the upgrade from v1.15 to v1.19 and still supports certificates without SANs. However, no special processing is required for subsequent upgrades. You are advised to rectify your certificate as soon as possible. |
In clusters v1.17.17 and later, CCE automatically creates pod security policies (PSPs) for you, which restrict the creation of pods with unsafe configurations, for example, pods for which net.core.somaxconn under a sysctl is configured in the security context. |
After an upgrade, you can allow insecure system configurations as required. For details, see Configuring a Pod Security Policy. |
If an init container or Istio is used in the in-place upgrade of a cluster v1.15, pay attention to the following restrictions: In kubelet v1.16 and later versions, QoS classes are different from those in earlier versions. In kubelet v1.15 and earlier versions, only containers in spec.containers are counted. In kubelet v1.16 and later versions, containers in both spec.containers and spec.initContainers are counted. The QoS class of a pod will change after the upgrade. As a result, the container in the pod restarts. |
You are advised to modify the QoS class of the service container before the upgrade to avoid this problem. For details, see Table 1. |
Init Container (Calculated Based on spec.initContainers) |
Service Container (Calculated Based on spec.containers) |
Pod (Calculated Based on spec.containers and spec.initContainers) |
Impacted or Not |
Guaranteed |
BestEffort |
Burstable |
Yes |
Guaranteed |
Burstable |
Burstable |
No |
Guaranteed |
Guaranteed |
Guaranteed |
No |
BestEffort |
BestEffort |
BestEffort |
No |
BestEffort |
Burstable |
Burstable |
No |
BestEffort |
Guaranteed |
Burstable |
Yes |
Burstable |
BestEffort |
Burstable |
Yes |
Burstable |
Burstable |
Burstable |
No |
Burstable |
Guaranteed |
Burstable |
Yes |
Deprecated APIs
With the evolution of Kubernetes APIs, APIs are periodically reorganized or upgraded, and certain APIs are deprecated and finally deleted. The following tables list the deprecated APIs in each Kubernetes community version. For details about more deprecated APIs, see Deprecated API Migration Guide.
- APIs deprecated in Kubernetes v1.32
- No APIs deprecated in Kubernetes v1.30 or v1.31
- APIs deprecated in Kubernetes v1.29
- No APIs deprecated in Kubernetes v1.28
- APIs deprecated in Kubernetes v1.27
- APIs deprecated in Kubernetes v1.25
- APIs deprecated in Kubernetes v1.22
- APIs deprecated in Kubernetes v1.16
When an API is deprecated, the existing resources are not affected. However, when you create or edit the resources, the API version will be intercepted.
Resource |
Deprecated API Version |
Substitute API Version |
Change Description |
FlowSchema and PriorityLevelConfiguration |
flowcontrol.apiserver.k8s.io/v1beta3 |
flowcontrol.apiserver.k8s.io/v1 (This API has been available since v1.29.) |
Significant changes in flowcontrol.apiserver.k8s.io/v1: spec.limited.assuredConcurrencyShares of PriorityLevelConfiguration has been renamed spec.limited.nominalConcurrencyShares. The default value is 30 only when it is not specified, and the explicit value 0 does not change to 30. |
Resource |
flowcontrol.apiserver.k8s.io/v1beta2 |
flowcontrol.apiserver.k8s.io/v1 (This API has been available since v1.29.) flowcontrol.apiserver.k8s.io/v1beta3 (This API has been available since v1.26.) |
Resource |
CSIStorageCapacity |
storage.k8s.io/v1beta1 |
storage.k8s.io/v1 (This API has been available since v1.24.) |
flowcontrol.apiserver.k8s.io/v1beta1 |
HorizontalPodAutoscaler |
autoscaling/v2beta2 |
autoscaling/v2 (This API has been available since v1.23.) |
Resource |
CronJob |
batch/v1beta1 |
batch/v1 (This API has been available since v1.21.) |
EndpointSlice |
discovery.k8s.io/v1beta1 |
discovery.k8s.io/v1 (This API has been available since v1.21.) |
Pay attention to the following changes:
Event |
events.k8s.io/v1beta1 |
events.k8s.io/v1 (This API has been available since v1.19.) |
autoscaling/v2beta1 |
PodDisruptionBudget |
policy/v1beta1 |
policy/v1 (This API has been available since v1.21.) |
If spec.selector is set to null ({}) in PodDisruptionBudget of policy/v1, all pods in the namespace are selected. (In policy/v1beta1, an empty spec.selector means that no pod will be selected.) If spec.selector is not specified, pod will be selected in neither API version. |
PodSecurityPolicy |
policy/v1beta1 |
Since v1.25, the PodSecurityPolicy resource no longer provides APIs of the policy/v1beta1 version, and the PodSecurityPolicy access controller is deleted. Use Pod Security Admission instead. |
RuntimeClass |
node.k8s.io/v1beta1 |
node.k8s.io/v1 (This API has been available since v1.20.) |
Resource |
MutatingWebhookConfiguration ValidatingWebhookConfiguration |
admissionregistration.k8s.io/v1beta1 |
admissionregistration.k8s.io/v1 (This API has been available since v1.16.) |
CustomResourceDefinition |
apiextensions.k8s.io/v1beta1 |
apiextensions/v1 (This API has been available since v1.16.) |
APIService |
apiregistration/v1beta1 |
apiregistration.k8s.io/v1 (This API has been available since v1.10.) |
TokenReview |
authentication.k8s.io/v1beta1 |
authentication.k8s.io/v1 (This API has been available since v1.6.) |
LocalSubjectAccessReview SelfSubjectAccessReview SubjectAccessReview SelfSubjectRulesReview |
authorization.k8s.io/v1beta1 |
authorization.k8s.io/v1 (This API has been available since v1.16.) |
spec.group was renamed spec.groups in v1 (patch #32709). |
CertificateSigningRequest |
certificates.k8s.io/v1beta1 |
certificates.k8s.io/v1 (This API has been available since v1.19.) |
Pay attention to the following changes in certificates.k8s.io/v1:
Lease |
coordination.k8s.io/v1beta1 |
coordination.k8s.io/v1 (This API has been available since v1.14.) |
Ingress |
networking.k8s.io/v1beta1 extensions/v1beta1 |
networking.k8s.io/v1 (This API has been available since v1.19.) |
IngressClass |
networking.k8s.io/v1beta1 |
ClusterRole ClusterRoleBinding Role RoleBinding |
rbac.authorization.k8s.io/v1beta1 |
rbac.authorization.k8s.io/v1 (This API has been available since v1.8.) |
PriorityClass |
scheduling.k8s.io/v1beta1 |
scheduling.k8s.io/v1 (This API has been available since v1.14.) |
CSIDriver CSINode StorageClass VolumeAttachment |
storage.k8s.io/v1 |
Resource |
NetworkPolicy |
networking.k8s.io/v1 (This API has been available since v1.8.) |
DaemonSet |
extensions/v1beta1 apps/v1beta2 |
apps/v1 (This API has been available since v1.9.) |
Deployment |
extensions/v1beta1 apps/v1beta1 apps/v1beta2 |
StatefulSet |
ReplicaSet |
spec.selector is now a mandatory field and cannot be changed after the object is created. The label of an existing template can be used as a selector for seamless migration. |
PodSecurityPolicy |
policy/v1beta1 (This API has been available since v1.10.) |
PodSecurityPolicy for the policy/v1beta1 API version will be removed in v1.25. |
