Cluster Secrets
By default, CCE creates the following secrets in each namespace:
- default-secret
- paas.elb
- default-token-xxxxx (xxxxx is a random number.)
The functions of these secrets are described as follows.
default-secret
The type of default-secret is kubernetes.io/dockerconfigjson. The data is the credential for logging in to the SWR image repository and is used to pull images from SWR. To pull an image from SWR when creating a workload on CCE, set imagePullSecrets to default-secret.
apiVersion: v1
kind: Pod
containers:
- image: nginx:alpine
resources:
limits:
cpu: 100m
memory: 200Mi
requests:
cpu: 100m
memory: 200Mi
imagePullSecrets:
- name: default-secret
The data of default-secret is updated periodically, and the current data will expire after a certain period of time. You can run the describe command to view the expiration time in of default-secret.
![](https://support.huaweicloud.com/intl/en-us/ae-ad-1-usermanual-cce/public_sys-resources/notice_3.0-en-us.png)
Use default-secret directly instead of copying the secret content to create a new one. The credential in the copied secret will expire and the image cannot be pulled.
$ kubectl describe secret default-secret
Namespace: default
Labels: secret-generated-by=cce
Annotations: temporary-ak-sk-expires-at: 2021-11-26 20:55:31.380909 +0000 UTC
Type: kubernetes.io/dockerconfigjson
Data
.dockerconfigjson: 347 bytes
paas.elb
The data of paas.elb is the temporary AK/SK data, which is used to create ELB load balancers during Service and ingress creation. The data of paas.elb is periodically updated and expires after a certain period of time.
In practice, you will not directly use paas.elb. However, do not delete it. Otherwise, ELB load balancers will fail to be created.
default-token-xxxxx
By default, Kubernetes creates a service account named default for each namespace. default-token-xxxxx is the key of the service account, and xxxxx is a random number.
$ kubectl get sa
NAME SECRETS AGE
default 1 30d
$ kubectl describe sa default
Namespace: default
Labels: <none>
Annotations: <none>
Image pull secrets: <none>
Mountable secrets: default-token-xxxxx
Tokens: default-token-xxxxx
Events: <none>
