Updated on 2023-07-07 GMT+08:00
ConfigMaps and Secrets
- Creating a ConfigMap
- Using a ConfigMap
After a ConfigMap is created, it can be used in three workload scenarios: environment variables, command line parameters, and data volumes. - Creating a Secret
- Using a Secret
After secrets are created, they can be mounted as data volumes or be exposed as environment variables to be used by a container in a pod. - Cluster Secrets
