Check containerd pod restart risk
Check Items
Check whether the service container running on the node may restart when the containerd component is upgraded on the node that uses containerd in the current cluster.
Solution
Ensure that the cluster is upgraded when the impact on services is controllable (for example, during off-peak hours) to mitigate the impact of service container restart. If you need help, contact O&M personnel.
