Updated on 2026-09-21 GMT+08:00
PVC View
The PVC view displays the PV/PVC status and usage.
The following PVC types support usage monitoring:
  • EVS PVCs (The value of volumeMode must be Filesystem.)
  • Local PVCs (The Everest version installed in the cluster must be 2.4.41 or later.)
  • SFS Turbo PVCs (Subdirectories generated dynamically by SFS Turbo also support usage monitoring. However, the PVC usage and capacity collected from the subdirectories are the same as those of the SFS Turbo instance).
  • PVCs mounted to common containers (The usages and inodes usages can be collected for such PVCs, but not for the PVCs mounted to secure containers.)
Metric Description
You can view PVC metrics in the following table.
Table 1 PVC metrics
Metric
Unit
PV Status
N/A
PV status, which can be Available, Bound, Failed, Pending, or Released.
PVC Status
N/A
PVC status, which can be Bound, Lost, or Pending.
Used PVC
GiB
Used and available PVC space.
PVC Usage
Percentage of a PVC that is used.
Used Inodes in PVC
N/A
Used and available space of inodes in a PVC.
Inodes Usage in PVC
Percentage of inodes that are used in a PVC.
Metric List
The following is the metric list of the PVC view.
Table 2 Metric description
Metric
Type
kubelet_volume_stats_inodes_used
Gauge
The number of used inodes in a volume.
Gauge
Maximum number of inodes in a volume.
kubelet_volume_stats_capacity_bytes
Gauge
Capacity in bytes of a volume.
kubelet_volume_stats_available_bytes
Gauge
The number of available bytes in a volume.
kubelet_volume_stats_used_bytes
Gauge
The number of used bytes in a volume.
kube_persistentvolume_status_phase
Gauge
PV status.
kube_persistentvolumeclaim_status_phase
Gauge
PVC status.
