Situation Awareness
Configuring SFS Volume Mount Options
Updated on 2024-01-26 GMT+08:00
This section describes how to configure SFS volume mount options. You can configure mount options in a PV and bind the PV to a PVC. Alternatively, configure mount options in a StorageClass and use the StorageClass to create a PVC. In this way, PVs can be dynamically created and inherit mount options configured in the StorageClass by default.
The everest add-on version must be 1.2.8 or later. The add-on identifies the mount options and transfers them to the underlying storage resources, which determine whether the specified options are valid.
The everest add-on in CCE presets the options described in Table 1 for mounting SFS volumes.
Table 1 SFS volume mount options
Value
keep-original-ownership
Leave it blank.
Whether to retain the ownership of the file mount point. If this option is used, the everest add-on must be v1.2.63 or v2.1.2 or later.
  • By default, this option is not added. and the mount point ownership is root:root when SFS is mounted.
  • If this option is added, the original ownership of the file system is retained when SFS is mounted.
vers
3
File system version. Currently, only NFSv3 is supported. Value: 3
nolock
Leave it blank.
Whether to lock files on the server using the NLM protocol. If nolock is selected, the lock is valid for applications on one host. For applications on another host, the lock is invalid.
timeo
600
Waiting time before the NFS client retransmits a request. The unit is 0.1 seconds. Recommended value: 600
hard/soft
Leave it blank.
Mount mode.
  • hard: If the NFS request times out, the client keeps resending the request until the request is successful.
  • soft: If the NFS request times out, the client returns an error to the invoking program.
The default value is hard.
Configuring Mount Options in a PV
You can use the mountOptions field to configure mount options in a PV. The options you can configure in mountOptions are listed in SFS Volume Mount Options.
  1. Use kubectl to connect to the cluster. For details, see Connecting to a Cluster Using kubectl.
  2. Configure mount options in a PV. Example:
    apiVersion: v1
    kind: PersistentVolume
      annotations:
        pv.kubernetes.io/provisioned-by: everest-csi-provisioner
        everest.io/reclaim-policy: retain-volume-only      # (Optional) The PV is deleted while the underlying volume is retained.
      accessModes:
      - ReadWriteMany      # Access mode. The value must be ReadWriteMany for SFS.
      capacity:
        storage: 1Gi     # SFS volume capacity.
      csi:
        driver: disk.csi.everest.io   # Dependent storage driver for the mounting.
        fsType: nfs
        volumeHandle: <your_volume_id>   # ID of the SFS Capacity-Oriented volume.
        volumeAttributes:
          everest.io/share-export-location: <your_location>  # Shared path of the SFS volume.
          storage.kubernetes.io/csiProvisionerIdentity: everest-csi-provisioner
      persistentVolumeReclaimPolicy: Retain    # Reclaim policy.
      storageClassName: csi-nas                # Storage class name.
      mountOptions:                            # Mount options.
      - vers=3
      - nolock
      - timeo=600
      - hard
  3. After a PV is created, you can create a PVC and bind it to the PV, and then mount the PV to the container in the workload. For details, see Using an Existing SFS File System Through a Static PV.
  4. Check whether the mount options take effect.
    In this example, the PVC is mounted to the workload that uses the nginx:latest image. You can run the mount -l command to check whether the mount options take effect.
    1. View the pod to which the SFS volume has been mounted. In this example, the workload name is web-sfs.
      kubectl get pod | grep web-sfs
      Command output:
      web-sfs-***   1/1     Running   0             23m
    2. Run the following command to check the mount options (web-sfs-*** is an example pod):
      kubectl exec -it web-sfs-*** -- mount -l | grep nfs
      If the mounting information in the command output is consistent with the configured mount options, the mount options are set successfully.
      <Your shared path> on /data type nfs (rw,relatime,vers=3,rsize=1048576,wsize=1048576,namlen=255,hard,nolock,noresvport,proto=tcp,timeo=600,retrans=2,sec=sys,mountaddr=**.**.**.**,mountvers=3,mountport=2050,mountproto=tcp,local_lock=all,addr=**.**.**.**)
Setting Mount Options in a StorageClass
You can use the mountOptions field to configure mount options in a StorageClass. The options you can configure in mountOptions are listed in SFS Volume Mount Options.
  2. Create a customized StorageClass. Example:
    apiVersion: storage.k8s.io/v1
    kind: StorageClass
    provisioner: everest-csi-provisioner
    parameters:
      csi.storage.k8s.io/csi-driver-name: nas.csi.everest.io
      csi.storage.k8s.io/fstype: nfs
    everest.io/share-access-to: <your_vpc_id> # VPC ID of the cluster.
    reclaimPolicy: Delete
    volumeBindingMode: Immediate
    - vers=3
    - nolock
    - timeo=600
    - hard
  3. After the StorageClass is configured, you can use it to create a PVC. By default, the dynamically created PVs inherit the mount options configured in the StorageClass. For details, see Using an SFS File System Through a Dynamic PV.
      Command output:
