Situation Awareness
On this page
Service Using HTTP or HTTPS
Updated on 2024-01-04 GMT+08:00
  • Only clusters of v1.19.16 or later support HTTP or HTTPS.
  • Do not connect an Ingress and a Service that uses HTTP or HTTPS to the same listener of the same load balancer. Otherwise, a port conflict occurs.
Service Using HTTP
The following annotations need to be added:
  • kubernetes.io/elb.protocol-port: "https:443,http:80"
    The value of protocol-port must be the same as the port in the spec.ports field of the Service. The format is Protocol:Port. The port matches the one in the service.spec.ports field and is released as the corresponding protocol.
  • kubernetes.io/elb.cert-id: "17e3b4f4bc40471c86741dc3aa211379"
    cert-id indicates the certificate ID in ELB certificate management. When https is configured for protocol-port, the certificate of the ELB listener will be set to the cert-id certificate. When multiple HTTPS services are released, the same certificate is used.
The following is a configuration example. The two ports in spec.ports correspond to those in kubernetes.io/elb.protocol-port. Ports 443 and 80 are enabled for HTTPS and HTTP requests, respectively.
apiVersion: v1
kind: Service
  annotations:
    kubernetes.io/elb.autocreate: '
          "type": "public",
          "bandwidth_name": "cce-bandwidth-1634816602057",
          "bandwidth_chargemode": "bandwidth",
          "bandwidth_size": 5,
          "bandwidth_sharetype": "PER",
          "eip_type": "5_bgp",
          "available_zone": [
          "l7_flavor_name": "L7_flavor.elb.s2.small",
          "l4_flavor_name": "L4_flavor.elb.s1.medium"
    kubernetes.io/elb.class: performance
  labels:
    app: nginx
  namespace: default
  ports:
  - name: cce-service-0
    port: 443
    protocol: TCP
    targetPort: 80
  - name: cce-service-1
    port: 80
    protocol: TCP
    targetPort: 80
  selector:
    app: nginx
    version: v1
  sessionAffinity: None
  type: LoadBalancer
Use the preceding example configurations to create a Service. In the new ELB load balancer, you can see that the listeners on ports 443 and 80 are created.
