Updated on 2026-09-21 GMT+08:00
Scheduling
Basic kube-scheduler configurations and Volcano-backed advanced scheduling are available. You can enable advanced scheduling functions such as bin packing, priority-based scheduling and preemption, AI task performance enhancement, and heterogeneous resource management for improved cluster resource utilization at low costs.
Default Cluster Scheduler
Default Scheduler (default-scheduler)
The Kubernetes scheduler discovers newly created pods that have not been accepted by nodes and assigns them to proper nodes. A Kubernetes cluster can run multiple schedulers simultaneously. kube-scheduler is the community default. CCE also supports the enhanced Volcano Scheduler, which provides general computing capabilities including high-performance job scheduling, heterogeneous chip management, and task management.
You can run both schedulers together or use kube-scheduler or Volcano Scheduler alone.
Table 1 Default cluster scheduler
Scheduler Name
Configuration
kube-scheduler
kube-scheduler provides the community native, standard scheduling capabilities.
If kube-scheduler is set as the default scheduler in a cluster and the Volcano Scheduler add-on (Volcano Scheduler) is also installed in the cluster, the enhanced Volcano capabilities are enabled by default. This ensures that you have access to advanced scheduling capabilities, including resource utilization optimization, AI job performance enhancement, and heterogeneous resource management. They help reduce costs while improving resource utilization. In this case, kube-scheduler schedules common workloads, while the Volcano Scheduler schedules some specified workloads. For details, see Scheduling Workloads.
kube-scheduler configurations:
Enhanced configurations after the Volcano Scheduler is installed:
Volcano (available in clusters v1.27 or later)
If the Volcano Scheduler is set as the default scheduler in a cluster, kube-scheduler will no longer work. The Volcano Scheduler schedules all workload tasks in the cluster.
Volcano provides enhanced scheduling capabilities in addition to the capabilities provided by kube-scheduler. Before using this scheduler, you need to install the Volcano Scheduler add-on first. For details, see Volcano Scheduler.
Enhanced configurations of the Volcano Scheduler:
kube-scheduler
Before enabling Volcano Enhancement, install Volcano Scheduler. Enabling this function will provide advanced scheduling capabilities, including optimizing resource utilization, enhancing AI job performance, and managing heterogeneous resources. This will ultimately improve cluster resource utilization and reduce costs.
Scheduler Performance Configuration
Only kube-scheduler supports this configuration.
Table 2 Parameters
Item
Value
QPS for Communicating with kube-apiserver
kube-api-qps
Maximum rate of stable requests sent to kube-apiserver, which is the number of requests that can be sent per second (QPS).
  • If the number of nodes in a cluster is less than 1,000, the default value is 100.
  • If the number of nodes in a cluster is 1,000 or more, the default value is 200.
After the cluster size is changed, the parameter value is automatically adjusted based on the current cluster size.
Burst for Communicating with kube-apiserver
kube-api-burst
Burst for communication with kube-apiserver.
Service Priority-based Scheduling
This is a basic scheduling capability and cannot be disabled. The scheduler preferentially guarantees the running of high-priority pods, and will not evict low-priority pods that are running. For details, see Priority-based Scheduling and Preemption.
Priority-based Preemption (supported by Volcano Scheduler)
After this function is enabled, when cluster resources are insufficient, the scheduler will proactively evict low-priority pods to make it possible to schedule pending high-priority pods. For details, see Priority-based Scheduling and Preemption.
  • This configuration is supported when Volcano is selected as the default scheduler.
  • Enabling both priority-based preemption scheduling and delayed pod creation simultaneously is not possible.
Priority Policy (Supported after Volcano Scheduler is set as the default scheduler)
After this function is enabled, the default priority policies and custom policies are used for application scale-in. For details, see Application Scaling Priority Policies.
Disabling this function will not affect the workloads that have it enabled.
Resource Utilization-optimized Scheduling (Supported by Volcano Scheduler)
Binpack
With this option enabled, the cluster scheduler schedules pods to nodes that have the most requested resources. This reduces resource fragments on each node and improves the resource utilization of the cluster. For details, see Bin Packing.
For details about the bin packing weight and weights for each resource to score nodes, see Table 3.
Table 3 Bin packing weight
Item
Default Value
Binpack Policy Weight
A larger value indicates a higher weight of the bin packing policy in overall scheduling.
10
CPU Weight
A larger value indicates a higher cluster CPU usage.
Memory Weight
A larger value indicates a higher cluster memory usage.
Custom Resource Requested by Pod
Other custom resource types requested by pods, for example, nvidia.com/gpu. A larger value indicates a higher usage of the specified cluster resource.
None
Load-aware Scheduling
This function uses the Cloud Native Cluster Monitoring (kube-prometheus-stack) add-on to obtain the actual CPU and memory load of each node, calculates the average load of each node based on the specified period, and preferentially schedules jobs to the node with the lightest load to balance load. For details, see Load-aware Scheduling.
Enhanced AI Job Scheduling (Supported by Volcano Scheduler)
DRF Scheduling
Dominant Resource Fairness (DRF) is a scheduling algorithm based on the dominant resource of a container group. It supports fair allocation of multiple types of resources and is suitable for batch AI training and big data jobs. DRF is suitable for batch processing small-scale services like single AI model training and single big data computing and query because it preferentially considers the throughput of services in clusters.
DRF helps you enhance the service throughput of clusters and improve service performance. For details, see DRF.
Gang Scheduling
Gang scheduling meets the scheduling requirements of "All or nothing" in the scheduling process and avoids the waste of cluster resources caused by arbitrary scheduling of pods. It is mainly used in scenarios that require multi-process collaboration, such as AI and big data scenarios.
Gang scheduling effectively resolves pain points such as resource waiting or deadlocks in distributed training jobs, thereby significantly improving the utilization of cluster resources. For details, see Gang.
Heterogeneous Resource Scheduling (Supported by Volcano Scheduler)
GPU Scheduling
To use this capability, the CCE AI Suite (NVIDIA GPU) add-on (CCE AI Suite (NVIDIA GPU)) must be installed. With this option enabled, GPUs can be used for AI training jobs, and the scheduler provides full GPU dispatch and GPU sharing to improve resource utilization.
NPU Scheduling
To use this capability, the CCE AI Suite (Ascend NPU) add-on (CCE AI Suite (Ascend NPU)) must be installed. With this option enabled, NPUs can be used for AI training jobs, and the scheduler provides NPU topology-aware scheduling to improve job training efficiency.
