Updated on 2026-05-26 GMT+08:00
Auto Scale-Out Settings
CCE Cluster Autoscaler comprehensively checks the resource statuses of an entire cluster. When the load of a microservice is high (for example, the CPU or memory usage is too high), it will add more pods to reduce the load.
Node Scale-Out Criteria
  • Auto Node Scale-Out: If a workload pod cannot be scheduled, the system automatically scales out the node pool with auto scaling enabled. If the pod has been configured to be affinity for a node, the system will not automatically add more nodes.
    Such auto scaling works with an HPA policy. For details, see Using an HPA and a CA for Auto Scaling of Workloads and Nodes.
  • Custom Node Scale-Out: specifies whether to automatically scale out a node pool based on the node scaling policies. This function is enabled by default.
When both Auto Node Scale-Out and metric-based node scaling policies are enabled and their conditions are met, CCE prioritizes the former.
  • If the scale-out succeeds, CCE skips the metric-based policy and waits for the next cycle.
  • If the scale-out fails, CCE executes the metric-based policy.
Upper Resource Limit for Node Scale-Out
  • Nodes: specifies how many nodes can be present in a cluster during scale-out. If there are more nodes in the cluster than the specified value, the cluster will not add nodes. The default value is determined by how many nodes a cluster can manage at most.
  • CPU Cores: specifies how many cores on all nodes can be present in a cluster during scale-out. If there are more cores in the cluster than the specified value, the cluster will not add nodes. By default, the number is not limited.
  • Memory (GiB): specifies the upper limit of the total memory of all nodes in a cluster during scale-out. If the total memory exceeds the specified value, the cluster will not add nodes. By default, the number is not limited.
When the total number of nodes, CPU cores, and memory in a cluster is collected, unavailable nodes are included in the calculation. However, if a node becomes unavailable due to being deleted from the default node pool using kubectl delete node, it is excluded from the resource totals.
This deletion method is not officially supported by CCE. For standard procedures on node deletion, see Deleting or Unsubscribing from a Node.
Scale-Out Priority
You can adjust the scale-out priority by dragging node pools in the list. Yearly/Monthly node pools do not support auto scale-out.
Auto Scale-In Settings
CCE Cluster Autoscaler comprehensively checks the resource statuses of an entire cluster. Once it confirms that workload pods can be scheduled and run properly, it automatically obtains nodes for scale-in. Auto scale-in is disabled by default. If you uninstall the add-on and then install it again, you need to enable auto scale-in again.
Node Scale-In Criteria
Nodes in a cluster comply with the default scale-in conditions by default. If scale-in conditions are customized for a node pool, the nodes in the node pool comply with the customized scale-in conditions.
Table 1 Node scale-in conditions
Default Scale-In Conditions
If the CPU and memory allocation rates of a node are lower than a certain percentage (50% by default) for a period of time (10 minutes by default), or the node is unavailable for a period of time (20 minutes by default), the node will be scaled in.
Allocation rate = Total requested resources of all pods/Allocatable resources on the node
If the option Exclude CPU and memory resources pre-allocated to DaemonSet pods is selected, CCE will not consider the CPU and memory resources pre-allocated to DaemonSet pods when determining whether to scale in cluster nodes. This means that the resources used by DaemonSet pods will not affect the scale-in decision. If this option is not selected, the resources pre-allocated to DaemonSet pods will be included in the resource allocation calculations. This can cause the CPU and memory allocation rates to exceed the node scale-in threshold, potentially preventing nodes with low CPU and memory utilization from being scaled in.
(Optional) Custom Scale-In Conditions
You can configure scale-in conditions for each node pool. If the CPU and memory allocation rates of nodes in a node pool are lower than a certain percentage (50% by default) for a period of time (10 minutes by default), the node pool will be scaled in.
Custom scale-in conditions are supported when the CCE Cluster Autoscaler add-on version is v1.25.181, v1.27.152, v1.28.120, v1.29.81, v1.30.48, v1.31.10, or later. If the auto scaling function is not enabled for all flavors in a node pool, custom scale-in conditions configured for the node pool do not take effect. For details about how to enable the auto scaling function for a node pool, see Configuring a Node Pool Auto Scaling Policy.
Scale-In Exception Scenarios
When a node meets the following exception scenarios, CCE will not scale in the node even if the node resources or status meets scale-in conditions:
  • Resources on other nodes in the cluster are insufficient.
  • Scale-in protection is enabled on the node. To enable or disable node scale-in protection, choose Nodes in the navigation pane and then click the Nodes tab. Locate the target node and choose More > Enable Scale-in Protection or Disable Scale-in Protection in the Operation column.
  • There is a pod with the non-scale label on the node.
  • Policies such as reliability have been configured on some containers on the node.
  • There are non-DaemonSet pods in the kube-system namespace on the node.
  • (Optional) A container managed by a third-party pod controller is running on a node. Third-party pod controllers are for custom workloads except Kubernetes-native workloads such as Deployments and StatefulSets. Such controllers can be created using CustomResourceDefinitions.
Node Scale-In Policy
Table 2 Node scale-in policy configurations
Item
Default Value
Max Nodes for Batch Deletion
Maximum number of idle nodes that can be deleted concurrently. The actual number of nodes that can be deleted concurrently is also affected by the flow control value of the node deletion API.
Only idle nodes can be concurrently scaled in. Nodes that are not idle can only be scaled in one by one.
During a node scale-in, if all the pods on a node do not need to be evicted (such as the DaemonSet pods), the node will be considered as idle. Otherwise, the node is not idle.
10
Check Period
Interval at which a node can be checked again after it is determined that the node cannot be scaled in
5 minutes
Cooldown Duration
(If multiple cooldown durations are active in a cluster, scale-in evaluation will only resume after all cooldown durations have completed.)
The length of time before CCE starts evaluating scale-in again after an auto scale-in in a cluster.
10 minutes
The length of time before CCE starts evaluating scale-in again after an auto scale-out in a cluster.
If both auto scale-outs and scale-ins exist in a cluster, set this parameter to 0 minutes. This prevents unexpected waste of node resources caused by a blocked node scale-in due to continuous scale-outs of some node pools or retries upon a scale-out failure.
10 minutes
The length of time before CCE starts evaluating scale-in again after an auto scale-in failure in a cluster.
3 minutes
