Updated on 2026-09-21 GMT+08:00
Monitoring
CCE monitors applications and resources and collects metrics and events to analyze application health status. You can choose Settings from the navigation pane, click the Monitoring tab, and change monitoring parameters on the console.
You will need to enable cluster monitoring (Enabling Monitoring Center) to use all monitoring functions.
Monitoring Settings
Collection Settings
  • Preset Policies: manage monitoring tasks of the Cloud Native Cluster Monitoring add-on in a visualized manner. For details, see Managing Collection Tasks.
  • ServiceMonitor Policies: define the metric collection policies for Services. For details, see Managing Collection Tasks.
    For details about how to create a ServiceMonitor, see Method 4: Configuring ServiceMonitor.
  • PodMonitor Policies: define the metric collection policies for pods. For details, see Managing Collection Tasks
    For details about how to create a PodMonitor, see Method 3: Configuring PodMonitor.
  • Targets: statuses of the metric collection targets. For details, see Managing Collection Tasks.
  • Default Collection Period: the metric collection period of the Cloud Native Cluster Monitoring add-on. The default value is 15 seconds.
  • Auto Service Discovery: After this function is enabled, Cloud Native Cluster Monitoring automatically collects application metrics using annotation-based service discovery. By default, applications in the kube-system and monitoring namespaces are excluded. You need to provide custom metrics of applications based on Prometheus specifications, expose APIs of these metrics, and use the application images to deploy workloads in clusters. Cloud Native Cluster Monitoring will collect these metrics through the collection configuration. For details about how to configure automatic collection of annotations, see Configuring Pod Annotations and Configuring Service Annotations.
Connection to AOM
AOM uses Prometheus for container monitoring. To enable monitoring, you need to select an AOM instance first. With this function enabled, metrics will be reported to the selected AOM instance. Basic container metrics can be monitored for free, but other metrics are billed on a pay-per-use basis. For details about free metrics, see Basic Metrics: Container Metrics.
Connection to Third-Party Monitoring Platform
After this function is enabled, Prometheus data can be reported to a third-party monitoring platform. You need to obtain the data reporting address and identity authentication credential of the third-party platform beforehand. For details, see Reporting Prometheus Monitoring Data to a Third-Party Monitoring Platform.
Log Settings
Collection Settings
CCE collects, obtains, and analyzes Kubernetes container logs, including standard container output logs, container log files, node logs, and Kubernetes events.
When logs are reported to LTS, a default log group named k8s-logs-{Cluster ID} will be created and will generate costs. For details about LTS pricing, see Price Calculator.
Log Type
Log
LTS Log Group Name
Status
Reference
Container logs
Container standard output
stdout-{Cluster ID}
To enable service log collection, you need to install the Cloud Native Log Collection add-on (Cloud Native Log Collection).
Collecting Container Logs Using the Cloud Native Log Collection Add-on
Kubernetes events
Kubernetes events
event-{Cluster ID}
Collecting Kubernetes Events
Kubernetes audit logs
audit-{Cluster ID}
The option can be enabled separately.
Collecting Audit Logs
Control plane component logs
kube-apiserver logs
kube-apiserver-{Cluster ID}
Collecting Control Plane Component Logs
kube-controller-manager logs
kube-controller-manager-{Cluster ID}
kube-scheduler logs
kube-scheduler-{Cluster ID}
Send stdout Logs to AOM 1.0 (No more evolution): Logging in AOM 1.0 will not be improved, so you are advised to disable this function and use LTS logging instead. Logs sent to AOM will incur storage charges.
Report Kubernetes Events to AOM
Once the Cluster Native Logging add-on (Cloud Native Log Collection) is installed in a cluster, Kubernetes events are reported to LTS by default, while this feature can be used to report Kubernetes events to AOM.
  • Reporting of abnormal events
    • Enabled (default): All abnormal events except blacklisted ones are reported.
    • Disabled: No abnormal events are reported.
  • Reporting of common events: controls supplementary reporting of whitelisted events. (Note: System-default common events are not controlled by this setting.)
    • Enabled (default): Only whitelisted normal events are reported.
    • Disabled: No normal events are reported.
