Situation Awareness
Release Notes for CCE Cluster Versions
Updated on 2024-01-04 GMT+08:00
Version 1.27
NOTICE:
In CCE v1.27 and later versions, all nodes support only the containerd container engine.
Table 1 Release notes for the v1.27 patch
CCE Cluster Patch Version
Kubernetes Version
Feature Updates
Optimization
Vulnerability Fixing
v1.27.1-r0
v1.27.2
CCE clusters of v1.27 are released for the first time. For more information, see Kubernetes 1.27 Release Notes.
  • Both soft eviction and hard eviction are supported in node pool configurations.
None
None
Version 1.25
NOTICE:
All nodes in the CCE clusters of version 1.25, except the ones running EulerOS 2.5, use containerd by default.
Table 2 Release notes for the v1.25 patch
Kubernetes Version
Feature Updates
Optimization
v1.25.3-r10
v1.25.5
The timeout interval can be configured for a load balancer.
High-frequency parameters of kube-apiserver are configurable.
Fixed some security issues.
v1.25.3-r0
v1.25.5
None
Enhanced network stability of CCE Turbo clusters when their specifications are modified.
v1.25.1-r0
v1.25.5
CCE clusters of v1.25 are released for the first time. For more information, see Kubernetes 1.25 Release Notes.
None
None
Version 1.23
Table 3 Release notes for the v1.23 patch
Kubernetes Version
Feature Updates
Optimization
v1.23.8-r10
v1.23.11
v1.23.8-r0
v1.23.11
None
  • Enhanced Docker reliability during upgrades.
  • Optimized node time synchronization.
v1.23.5-r0
v1.23.11
  • Fault detection and isolation are supported on GPU nodes.
  • Security groups can be customized by cluster.
  • CCE Turbo clusters support ENIs pre-binding by node.
  • containerd is supported.
  • The ETCD version of the master node has been upgraded to the Kubernetes version 3.5.6.
  • Scheduling is optimized so that pods are evenly distributed across AZs after pods are scaled in.
  • Optimized the memory usage of kube-apiserver when CRDs are frequently updated.
Fixed some security issues and the following CVE vulnerabilities:
v1.23.1-r0
v1.23.4
CCE clusters of v1.23 are released for the first time. For more information, see Kubernetes 1.23 Release Notes.
None
None
Version 1.21
Table 4 Release notes for the v1.21 patch
Kubernetes Version
Feature Updates
Optimization
v1.21.10-r10
v1.21.14
v1.21.10-r0
v1.21.14
None
  • Enhanced the stability of the Docker runtime for pulling images after nodes are restarted.
v1.21.7-r0
v1.21.14
Improved the stability of LoadBalancer Services/ingresses with a large number of connections.
v1.21.1-r0
v1.21.7
CCE clusters of v1.21 are released for the first time. For more information, see Kubernetes 1.21 Release Notes.
None
None
Version 1.19
Table 5 Release notes for the v1.19 patch
Kubernetes Version
Feature Updates
Optimization
v1.19.16-r30
v1.19.16
v1.19.16-r20
v1.19.16
None
  • Cloud Native 2.0 Networks allow you to specify subnets for a namespace.
  • Optimized the performance of CCE Turbo clusters in allocating ENIs if not all ENIs are pre-bound.
v1.19.16-r4
v1.19.16
  • Scheduling is optimized on taint nodes.
  • Enhanced the long-term running stability of containerd when cores are bound.
  • Improved the stability of LoadBalancer Services/ingresses with a large number of connections.
v1.19.16-r0
v1.19.16
None
Enhanced the stability in updating LoadBalancer Services when workloads are upgraded and nodes are scaled in or out.
v1.19.10-r0
v1.19.10
CCE clusters of v1.19 are released for the first time. For more information, see Kubernetes 1.19 Release Notes.
None
None
