- What's New
- Function Overview
Product Bulletin
- Latest Notices
Product Change Notices
- EOM of CentOS
- Billing Changes for Huawei Cloud CCE Autopilot Data Plane
- CCE Autopilot for Commercial Use on September 30, 2024, 00:00 GMT+08:00
- Reliability Hardening for Cluster Networks and Storage Functions
- Support for Docker
- Service Account Token Security Improvement
- Upgrade of Helm v2 to Helm v3
- Problems Caused by conn_reuse_mode Settings in the IPVS Forwarding Mode of CCE Clusters
- Optimized Key Authentication of the everest Add-on
Cluster Version Release Notes
- End of Maintenance for Clusters 1.25
- End of Maintenance for Clusters 1.23
- End of Maintenance for Clusters 1.21
- End of Maintenance for Clusters 1.19
- End of Maintenance for Clusters 1.17
- End of Maintenance for Clusters 1.15
- End of Maintenance for Clusters 1.13
- Creation of CCE Clusters 1.13 and Earlier Not Supported
- Upgrade for Kubernetes Clusters 1.9
Vulnerability Notices
- Vulnerability Fixing Policies
- Notice of Kubernetes Security Vulnerability (CVE-2024-10220)
- Notice of Kubernetes Security Vulnerabilities (CVE-2024-9486 and CVE-2024-9594)
- Notice of Container Escape Vulnerability in NVIDIA Container Toolkit (CVE-2024-0132)
- Notice of Linux Remote Code Execution Vulnerability in CUPS (CVE-2024-47076, CVE-2024-47175, CVE-2024-47176, and CVE-2024-47177)
- Notice of the NGINX Ingress Controller Vulnerability That Allows Attackers to Bypass Annotation Validation (CVE-2024-7646)
- Notice of Docker Engine Vulnerability That Allows Attackers to Bypass AuthZ (CVE-2024-41110)
- Notice of Linux Kernel Privilege Escalation Vulnerability (CVE-2024-1086)
- Notice of OpenSSH Remote Code Execution Vulnerability (CVE-2024-6387)
- Notice of Fluent Bit Memory Corruption Vulnerability (CVE-2024-4323)
- Notice of runC systemd Attribute Injection Vulnerability (CVE-2024-3154)
- Notice of the Impact of runC Vulnerability (CVE-2024-21626)
- Notice of Kubernetes Security Vulnerability (CVE-2022-3172)
- Notice of Privilege Escalation Vulnerability in Linux Kernel openvswitch Module (CVE-2022-2639)
- Notice of nginx-ingress Add-on Security Vulnerability (CVE-2021-25748)
- Notice of nginx-ingress Security Vulnerabilities (CVE-2021-25745 and CVE-2021-25746)
- Notice of containerd Process Privilege Escalation Vulnerability (CVE-2022-24769)
- Notice of CRI-O Container Runtime Engine Arbitrary Code Execution Vulnerability (CVE-2022-0811)
- Notice of Container Escape Vulnerability Caused by the Linux Kernel (CVE-2022-0492)
- Notice of Non-Security Handling Vulnerability of containerd Image Volumes (CVE-2022-23648)
- Notice of Linux Kernel Integer Overflow Vulnerability (CVE-2022-0185)
- Notice of Linux Polkit Privilege Escalation Vulnerability (CVE-2021-4034)
- Notice of Vulnerability of Kubernetes subPath Symlink Exchange (CVE-2021-25741)
- Notice of runC Vulnerability That Allows a Container Filesystem Breakout via Directory Traversal (CVE-2021-30465)
- Notice of Docker Resource Management Vulnerability (CVE-2021-21285)
- Notice of NVIDIA GPU Driver Vulnerability (CVE-2021-1056)
- Notice of the Sudo Buffer Vulnerability (CVE-2021-3156)
- Notice of the Kubernetes Security Vulnerability (CVE-2020-8554)
- Notice of Apache containerd Security Vulnerability (CVE-2020-15257)
- Notice of Docker Engine Input Verification Vulnerability (CVE-2020-13401)
- Notice of Kubernetes kube-apiserver Input Verification Vulnerability (CVE-2020-8559)
- Notice of Kubernetes kubelet Resource Management Vulnerability (CVE-2020-8557)
- Notice of Kubernetes kubelet and kube-proxy Authorization Vulnerability (CVE-2020-8558)
- Notice of Fixing the Kubernetes HTTP/2 Vulnerability
- Notice of Fixing the Linux Kernel SACK Vulnerabilities
- Notice of Fixing the Docker Command Injection Vulnerability (CVE-2019-5736)
- Notice of Fixing the Kubernetes Permission and Access Control Vulnerability (CVE-2018-1002105)
- Notice of Fixing the Kubernetes Dashboard Security Vulnerability (CVE-2018-18264)
Product Release Notes
Cluster Versions
- Kubernetes Version Policy
Kubernetes Version Release Notes
- Kubernetes 1.31 Release Notes
- Kubernetes 1.30 Release Notes
- Kubernetes 1.29 Release Notes
- Kubernetes 1.28 Release Notes
- Kubernetes 1.27 Release Notes
- Kubernetes 1.25 Release Notes
- Kubernetes 1.23 Release Notes
- Kubernetes 1.21 (EOM) Release Notes
- Kubernetes 1.19 (EOM) Release Notes
- Kubernetes 1.17 (EOM) Release Notes
- Kubernetes 1.15 (EOM) Release Notes
- Kubernetes 1.13 (EOM) Release Notes
- Kubernetes 1.11 (EOM) Release Notes
- Kubernetes 1.9 (EOM) and Earlier Versions Release Notes
- Patch Versions
- OS Images
Add-on Versions
- CoreDNS Release History
- CCE Container Storage (Everest) Release History
- CCE Node Problem Detector Release History
- Kubernetes Dashboard Release History
- CCE Cluster Autoscaler Release History
- NGINX Ingress Controller Release History
- Kubernetes Metrics Server Release History
- CCE Advanced HPA Release History
- CCE Cloud Bursting Engine for CCI Release History
- CCE AI Suite (NVIDIA GPU) Release History
- CCE AI Suite (Ascend NPU) Release History
- Volcano Scheduler Release History
- CCE Secrets Manager for DEW Release History
- CCE Network Metrics Exporter Release History
- NodeLocal DNSCache Release History
- Cloud Native Cluster Monitoring Release History
- Cloud Native Log Collection Release History
- Container Image Signature Verification Release History
- Grafana Release History
- OpenKruise Release History
- Gatekeeper Release History
- Vertical Pod Autoscaler Release History
- CCE Cluster Backup & Recovery (End of Maintenance) Release History
- Kubernetes Web Terminal (End of Maintenance) Release History
- Prometheus (End of Maintenance) Release History
Cluster Versions
- Billing
- Kubernetes Basics
- Getting Started
User Guide
- High-Risk Operations
Clusters
- Basic Cluster Information
- Release Notes for Kubernetes 1.9 (EOM) and Earlier Versions
- Patch Version Release Notes
- Buying a Cluster
- Connecting to a Cluster
Managing a Cluster
- Modifying Cluster Configurations
- Enabling Overload Control for a Cluster
- Changing Cluster Scale
- Changing the Default Security Group of a Node
- Deleting a Cluster
- Hibernating or Waking Up a Pay-per-Use Cluster
- Renewing a Yearly/Monthly Cluster
- Changing the Billing Mode of a Cluster from Pay-per-Use to Yearly/Monthly
Upgrading a Cluster
- Process and Method of Upgrading a Cluster
- Before You Start
- Performing Post-Upgrade Verification
- Migrating Services Across Clusters of Different Versions
Troubleshooting for Pre-upgrade Check Exceptions
- Pre-upgrade Check
- Node Restrictions
- Upgrade Management
- Add-ons
- Helm Charts
- SSH Connectivity of Master Nodes
- Node Pools
- Security Groups
- Residual Nodes
- Discarded Kubernetes Resources
- Compatibility Risks
- CCE Agent Versions
- Node CPU Usage
- CRDs
- Node Disks
- Node DNS
- Node Key Directory File Permissions
- kubelet
- Node Memory
- Node Clock Synchronization Server
- Node OS
- Node CPU Cores
- Node Python Commands
- ASM Version
- Node Readiness
- Node journald
- containerd.sock
- Internal Error
- Node Mount Points
- Kubernetes Node Taints
- Everest Restrictions
- cce-hpa-controller Limitations
- Enhanced CPU Policies
- Health of Worker Node Components
- Health of Master Node Components
- Memory Resource Limit of Kubernetes Components
- Discarded Kubernetes APIs
- NetworkManager
- Node ID File
- Node Configuration Consistency
- Node Configuration File
- CoreDNS Configuration Consistency
- sudo
- Key Node Commands
- Mounting of a Sock File on a Node
- HTTPS Load Balancer Certificate Consistency
- Node Mounting
- Login Permissions of User paas on a Node
- Private IPv4 Addresses of Load Balancers
- Historical Upgrade Records
- CIDR Block of the Cluster Management Plane
- GPU Add-on
- Nodes' System Parameters
- Residual Package Version Data
- Node Commands
- Node Swap
- Upgrade of Cloud Native Cluster Monitoring
- containerd Pod Restart Risks
- Key GPU Add-on Parameters
- GPU or NPU Pod Rebuild Risks
- ELB Listener Access Control
- Master Node Flavor
- Subnet Quota of Master Nodes
- Node Runtime
- Node Pool Runtime
- Number of Node Images
- OpenKruise Compatibility Check
- Compatibility Check of Secret Encryption
- Compatibility Between the Ubuntu Kernel and GPU Driver
- Drainage Tasks
- Image Layers on a Node
- Cluster Rolling Upgrade
- Rotation Certificates
- Ingress and ELB Configuration Consistency
- Network Policies of Cluster Network Components
- Cluster and Node Pool Configurations
- Time Zone of Master Nodes
Nodes
- Node Overview
- Container Engines
- Node OSs
- Node Specifications
- Creating a Node
- Accepting Nodes for Management
- Logging In to a Node
Management Nodes
- Managing Node Labels
- Managing Node Taints
- Resetting a Node
- Removing a Node
- Synchronizing the Data of Cloud Servers
- Draining a Node
- Deleting or Unsubscribing from a Node
- Changing the Billing Mode of a Node to Yearly/Monthly
- Modifying the Auto-Renewal Configuration of a Yearly/Monthly Node
- Stopping a Node
- Performing Rolling Upgrade for Nodes
Node O&M
- Node Resource Reservation Policy
- Space Allocation of a Data Disk
- Maximum Number of Pods That Can Be Created on a Node
- Differences in kubelet and Runtime Component Configurations Between CCE and the Native Community
- Migrating Nodes from Docker to containerd
- Optimizing Node System Parameters
- Configuring Node Fault Detection Policies
- Executing the Pre- or Post-installation Commands During Node Creation
- ECS Event Handling Suggestions
- Node Pools
Workloads
- Overview
- Creating a Workload
Configuring a Workload
- Secure Runtime and Common Runtime
- Configuring Time Zone Synchronization
- Configuring an Image Pull Policy
- Using Third-Party Images
- Configuring Container Specifications
- Configuring Container Lifecycle Parameters
- Configuring Container Health Check
- Configuring Environment Variables
- Configuring APM
- Configuring Workload Upgrade Policies
- Configuring Tolerance Policies
- Configuring Labels and Annotations
- Scheduling a Workload
- Logging In to a Container
- Managing Workloads
- Managing Custom Resources
- Pod Security
Scheduling
- Overview
- CPU Scheduling
- GPU Scheduling
- NPU Scheduling
- Volcano Scheduling
- Cloud Native Hybrid Deployment
Network
- Overview
Container Network
- Overview
Cloud Native Network 2.0 Settings
- Cloud Native Network 2.0
- Configuring a Default Container Subnet for a CCE Turbo Cluster
- Binding a Security Group to a Pod Using an Annotation
- Binding a Security Group to a Workload Using a Security Group Policy
- Binding a Subnet and Security Group to a Namespace or Workload Using a Container Network Configuration
- Configuring a Static IP Address for a Pod
- Configuring an EIP for a Pod
- Configuring a Static EIP for a Pod
- Configuring Shared Bandwidth for a Pod with IPv6 Dual-Stack ENIs
- VPC Network Settings
- Tunnel Network Settings
- Pod Network Settings
Service
- Overview
- ClusterIP
- NodePort
LoadBalancer
- Creating a LoadBalancer Service
- Configuring LoadBalancer Services Using Annotations
- Configuring HTTP/HTTPS for a LoadBalancer Service
- Configuring SNI for a LoadBalancer Service
- Configuring HTTP/2 for a LoadBalancer Service
- Configuring an HTTP/HTTPS Header for a LoadBalancer Service
- Configuring Timeout for a LoadBalancer Service
- Configuring TLS for a LoadBalancer Service
- Configuring GZIP Data Compression for a LoadBalancer Service
- Configuring a Blocklist/Trustlist Access Policy for a LoadBalancer Service
- Configuring Health Check on Multiple Ports of a LoadBalancer Service
- Configuring Passthrough Networking for a LoadBalancer Service
- Enabling a LoadBalancer Service to Obtain the Client IP Address
- Configuring a Custom EIP for a LoadBalancer Service
- Configuring a Range of Listening Ports for LoadBalancer Services
- Setting the Pod Ready Status Through the ELB Health Check
- Enabling ICMP Security Group Rules
- DNAT
- Headless Services
Ingresses
- Overview
- Comparison Between ELB Ingress and Nginx Ingress
LoadBalancer Ingresses
- Creating a LoadBalancer Ingress on the Console
- Creating a LoadBalancer Ingress Using kubectl
- Annotations for Configuring LoadBalancer Ingresses
Advanced Setting Examples of LoadBalancer Ingresses
- Configuring an HTTPS Certificate for a LoadBalancer Ingress
- Updating the HTTPS Certificate for a LoadBalancer Ingress
- Configuring SNI for a LoadBalancer Ingress
- Configuring Multiple Forwarding Policies for a LoadBalancer Ingress
- Configuring HTTP/2 for a LoadBalancer Ingress
- Configuring HTTPS Backend Services for a LoadBalancer Ingress
- Configuring gRPC Backend Services for a LoadBalancer Ingress
- Configuring Timeout for a LoadBalancer Ingress
- Configuring a Slow Start for a LoadBalancer Ingress
- Configuring Grayscale Release for a LoadBalancer Ingress
- Configuring a Blocklist/Trustlist Access Policy for a LoadBalancer Ingress
- Configuring a Range of Listening Ports for a LoadBalancer Ingress
- Configuring an HTTP/HTTPS Header for a LoadBalancer Ingress
- Configuring GZIP Data Compression for a LoadBalancer Ingress
- Configuring URL Redirection for a LoadBalancer Ingress
- Configuring URL Rewriting for a LoadBalancer Ingress
- Redirecting HTTP to HTTPS for a LoadBalancer Ingress
- Configuring the Priorities of Forwarding Rules for LoadBalancer Ingresses
- Configuring a Custom Header Forwarding Policy for a LoadBalancer Ingress
- Configuring a Custom EIP for a LoadBalancer Ingress
- Configuring Cross-Origin Access for LoadBalancer Ingresses
- Configuring Advanced Forwarding Rules for a LoadBalancer Ingress
- Configuring Advanced Forwarding Actions for a LoadBalancer Ingress
- Forwarding Policy Priorities of LoadBalancer Ingresses
- Configuring Multiple Ingresses to Use the Same External ELB Port
Nginx Ingresses
- Creating an Nginx Ingress on the Console
- Creating an Nginx Ingress Using kubectl
- Annotations for Configuring Nginx Ingresses
Advanced Setting Examples of Nginx Ingresses
- Configuring an HTTPS Certificate for an Nginx Ingress
- Configuring Redirection Rules for an Nginx Ingress
- Configuring URL Rewriting Rules for an Nginx Ingress
- Configuring HTTPS Backend Services for an Nginx Ingress
- Configuring gRPC Backend Services for an Nginx Ingress
- Configuring Consistent Hashing for Load Balancing of an Nginx Ingress
- Configuring Application Traffic Mirroring for an Nginx Ingress
- Configuring Cross-Origin Access for Nginx Ingresses
- Nginx Ingress Usage Suggestions
- Optimizing NGINX Ingress Controller in High-Traffic Scenarios
- Configuring an ELB Certificate for NGINX Ingress Controller
- Migrating Data from a Bring-Your-Own Nginx Ingress to a LoadBalancer Ingress
- DNS
- Cluster Network Settings
- Configuring Intra-VPC Access
- Accessing the Internet from a Container
- Storage
- Auto Scaling
O&M
- Overview
- Agency Permissions
- Health Center
- Monitoring Center
- Logging
- Alarm Center
- Log Auditing
- O&M FAQ
O&M Best Practices
- Cloud Native Cluster Monitoring Is Compatible with Self-Built Prometheus
- Monitoring Custom Metrics Using Cloud Native Cluster Monitoring
- Monitoring Custom Metrics on AOM
- Monitoring Metrics of Master Node Components Using Prometheus
- Monitoring Metrics of NGINX Ingress Controller
- Monitoring Container Network Metrics of CCE Turbo Clusters
- Cloud Native Cost Governance
- Namespaces
- ConfigMaps and Secrets
- Add-ons
- Helm Chart
- Permissions
- Settings
- Storage Management: FlexVolume (Deprecated)
Best Practices
- Checklist for Deploying Containerized Applications in the Cloud
- Containerization
- Migration
- DevOps
- Disaster Recovery
Security
- Overview
- Configuration Suggestions on CCE Cluster Security
- Configuration Suggestions on CCE Node Security
- Configuration Suggestions on CCE Container Runtime Security
- Configuration Suggestions on CCE Container Security
- Configuration Suggestions on CCE Container Image Security
- Configuration Suggestions on CCE Secret Security
- Configuration Suggestions on CCE Workload Identity Security
- Auto Scaling
- Monitoring
Cluster
- Suggestions on CCE Cluster Selection
- Creating an IPv4/IPv6 Dual-Stack Cluster in CCE
- Creating a Custom CCE Node Image
- Using OBS Buckets to Implement Custom Script Injection During Node Creation
- Connecting to Multiple Clusters Using kubectl
- Selecting a Data Disk for the Node
- Implementing Cost Visualization for a CCE Cluster
- Creating a CCE Turbo Cluster Using a Shared VPC
- Protecting a CCE Cluster Against Overload
- Managing Costs for a Cluster
- Planning CIDR Blocks for a Cluster
- Selecting a Network Model
- Enabling Cross-VPC Network Communications Between CCE Clusters
- Implementing Network Communications Between Containers and IDCs Using VPC and Direct Connect
- Enabling a CCE Cluster to Resolve Domain Names on Both On-Premises IDCs and HUAWEI CLOUD
- Implementing Sticky Session Through Load Balancing
- Obtaining the Client Source IP Address for a Container
- Increasing the Listening Queue Length by Configuring Container Kernel Parameters
- Accessing an External Network from a Pod
- Deploying Nginx Ingress Controllers Using a Chart
- CoreDNS Configuration Optimization
- Pre-Binding Container ENI for CCE Turbo Clusters
- Connecting a Cluster to the Peer VPC Through an Enterprise Router
- Accessing an IP Address Outside a Cluster That Uses a VPC Network Using Source Pod IP Addresses in the Cluster
- Expanding the Storage Space
- Mounting Object Storage Across Accounts
- Dynamically Creating an SFS Turbo Subdirectory Using StorageClass
- Changing the Storage Class Used by a Cluster of v1.15 from FlexVolume to CSI Everest
- Using Custom Storage Classes
- Scheduling EVS Disks Across AZs Using csi-disk-topology
- Automatically Collecting JVM Dump Files That Exit Unexpectedly Using SFS 3.0
- Deploying Storage Volumes in Multiple AZs
Container
- Recommended Configurations for Workloads
- Properly Allocating Container Computing Resources
- Upgrading Pods Without Interrupting Services
- Modifying Kernel Parameters Using a Privileged Container
- Using Init Containers to Initialize an Application
- Setting Time Zone Synchronization
- Configuration Suggestions on Container Network Bandwidth Limit
- Configuring the /etc/hosts File of a Pod Using hostAliases
- Configuring Domain Name Resolution for CCE Containers
- Using Dual-Architecture Images (x86 and Arm) in CCE
- Locating Container Faults Using the Core Dump File
- Configuring Parameters to Delay the Pod Startup in a CCE Turbo Cluster
- Automatically Updating a Workload Version Using SWR Triggers
- Permission
- Release
- Batch Computing
API Reference
- Before You Start
- API Overview
- Calling APIs
APIs
- API URL
Cluster Management
- Creating a Cluster
- Reading a Specified Cluster
- Listing Clusters in a Specified Project
- Updating a Specified Cluster
- Hibernating a Cluster
- Waking Up a Cluster
- Obtaining a Cluster Certificate
- Revoking a Cluster Certificate of a User
- Modifying Cluster Specifications
- Querying a Job
- Binding/Unbinding Public API Server Address
- Obtaining Cluster Access Address
- Obtaining a Cluster's Logging Configurations
- Configuring Cluster Logs
- Obtaining the Partition List
- Creating a Partition
- Obtaining Partition Details
- Updating a Partition
Node Management
- Creating a Node
- Reading a Specified Node
- Listing All Nodes in a Cluster
- Updating a Specified Node
- Deleting a Node
- Enabling Scale-In Protection for a Node
- Disabling Scale-In Protection for a Node
- Synchronizing Nodes
- Synchronizing Nodes in Batches
- Accepting a Node
- Managing a Node in a Customized Node Pool
- Resetting a Node
- Removing a Node
- Migrating a Node
- Migrating a Node to a Custom Node Pool
- Node Pool Management
- Add-on Management
Cluster Upgrade
- Upgrading a Cluster
- Suspending a Cluster Upgrade Task (Deprecated)
- Continuing to Execute a Cluster Upgrade Task (Deprecated)
- Pre-upgrade Check
- Post-upgrade Check
- Cluster Backup
- Obtaining Details About a Specified Cluster Upgrade Task
- Quota Management
- API Versions
- Tag Management
- Configuration Management
Chart Management
- Uploading a Chart
- Obtaining a Chart List
- Obtaining a Release List
- Updating a Chart
- Creating a Release
- Deleting a Chart
- Updating a Release
- Obtaining a Chart
- Deleting a Release
- Downloading a Chart
- Obtaining Chart Values
Add-on Instance Parameters
- CoreDNS
- CCE Advanced HPA
- Volcano Scheduler
- Cloud Native Logging
- Kubernetes APIs
- Out-of-Date APIs
Appendix
- Status Code
- Error Codes
- Obtaining a Project ID
- Obtaining an Account ID
- Specifying Add-ons to Be Installed During Cluster Creation
- How to Obtain Parameters in the API URI
- Creating a VPC and Subnet
- Creating a Key Pair
- Node Flavor Description
- Adding a Salt in the password Field When Creating a Node
- Node OS
- Attaching Disks to a Node
- SDK Reference
- Common FAQ
Billing
- How Is CCE Billed?
- How Do I Change the Billing Mode of a CCE Cluster from Pay-per-Use to Yearly/Monthly?
- Can I Change the Billing Mode of CCE Nodes from Pay-per-Use to Yearly/Monthly?
- Which Invoice Modes Are Supported by Huawei Cloud?
- Will I Be Notified When My Balance Is Insufficient?
- Will I Be Notified When My Account Balance Changes?
- Can I Delete a Yearly/Monthly-Billed CCE Cluster Directly When It Expires?
- How Do I Unsubscribe From CCE?
Cluster
- Cluster Creation
Cluster Running
- How Do I Locate the Fault When a Cluster Is Unavailable?
- How Do I Reset or Reinstall a CCE Cluster?
- How Do I Check Whether a Cluster Is in Multi-Master Mode?
- Can I Directly Connect to the Master Node of a CCE Cluster?
- How Do I Retrieve Data After a CCE Cluster Is Deleted?
- Why Does CCE Display Node Disk Usage Inconsistently with Cloud Eye?
- How Do I Change the Name of a CCE Cluster?
- Cluster Deletion
- Cluster Upgrade
Node
- Node Creation
Node Running
- What Should I Do If a Cluster Is Available But Some Nodes Are Unavailable?
- How Do I Troubleshoot the Failure to Remotely Log In to a Node in a CCE Cluster?
- How Do I Log In to a Node Using a Password and Reset the Password?
- How Do I Collect Logs of Nodes in a CCE Cluster?
- What Can I Do If the Container Network Becomes Unavailable After yum update Is Used to Upgrade the OS?
- What Should I Do If the vdb Disk of a Node Is Damaged and the Node Cannot Be Recovered After Reset?
- Which Ports Are Used to Install kubelet on CCE Cluster Nodes?
- How Do I Configure a Pod to Use the Acceleration Capability of a GPU Node?
- What Should I Do If I/O Suspension Occasionally Occurs When SCSI EVS Disks Are Used?
- What Should I Do If Excessive Docker Audit Logs Affect the Disk I/O?
- How Do I Fix an Abnormal Container or Node Due to No Thin Pool Disk Space?
- Where Can I Get the Listening Ports of CCE Worker Nodes?
- How Do I Rectify Failures When the NVIDIA Driver Is Used to Start Containers on GPU Nodes?
- What Can I Do If the Time of CCE Nodes Is Not Synchronized with the NTP Server?
- What Should I Do If the Data Disk Usage Is High Because a Large Volume of Data Is Written Into the Log File?
- Why Does My Node Memory Usage Obtained by Running the kubelet top node Command Exceed 100%?
- What Should I Do If "Failed to reclaim image" Is Displayed in the Node Events?
- Specification Change
OSs
- What Can I Do If cgroup kmem Leakage Occasionally Occurs When an Application Is Repeatedly Created or Deleted on a Node Running CentOS with an Earlier Kernel Version?
- What Should I Do If There Is a Service Access Failure After a Backend Service Upgrade or a 1-Second Latency When a Service Accesses a CCE Cluster?
- Why Are Pods Evicted by kubelet Due to Abnormal cgroup Statistics?
- When Container OOM Occurs on the CentOS Node with an Earlier Kernel Version, the Ext4 File System Is Occasionally Suspended
- What Should I Do If a DNS Resolution Failure Occurs Due to a Defect in IPVS?
- What Should I Do If the Number of ARP Entries Exceeds the Upper Limit?
- What Should I Do If a VM Is Suspended Due to an EulerOS 2.9 Kernel Defect?
Node Pool
- What Should I Do If a Node Pool Is Abnormal?
- What Should I Do If No Node Creation Record Is Displayed When the Node Pool Is Being Expanding?
- What Should I Do If a Node Pool Scale-Out Fails?
- What Should I Do If Some Kubernetes Events Fail to Display After Nodes Were Added to or Deleted from a Node Pool in Batches?
- How Do I Modify ECS Configurations When an ECS Cannot Be Managed by a Node Pool?
Workload
Workload Exception Troubleshooting
- How Can I Find the Fault for an Abnormal Workload?
- What Should I Do If Pod Scheduling Fails?
- What Should I Do If a Pod Fails to Pull the Image?
- What Should I Do If Container Startup Fails?
- What Should I Do If a Pod Fails to Be Evicted?
- What Should I Do If a Storage Volume Cannot Be Mounted or the Mounting Times Out?
- What Should I Do If a Workload Remains in the Creating State?
- What Should I Do If a Pod Remains in the Terminating State?
- What Should I Do If a Workload Is Stopped Caused by Pod Deletion?
- What Should I Do If an Error Occurs When I Deploy a Service on the GPU Node?
- What Should I Do If a Workload Exception Occurs Due to a Storage Volume Mount Failure?
- Why Does Pod Fail to Write Data?
- Why Is Pod Creation or Deletion Suspended on a Node Where File Storage Is Mounted?
- How Can I Locate Faults Using an Exit Code?
- Container Configuration
- Monitoring Log
Scheduling Policies
- How Do I Evenly Distribute Multiple Pods to Each Node?
- How Do I Prevent a Container on a Node from Being Evicted?
- Why Are Pods Not Evenly Distributed on Nodes?
- How Do I Evict All Pods on a Node?
- How Do I Check Whether a Pod Is Bound with vCPUs?
- What Should I Do If Pods Cannot Be Rescheduled After the Node Is Stopped?
- How Do I Prevent a Non-GPU or Non-NPU Workload from Being Scheduled to a GPU or NPU Node?
- Why Cannot a Pod Be Scheduled to a Node?
- What Should I Do If a Cron Job Cannot Be Restarted After Being Stopped for a Period of Time?
- What Is a Headless Service When I Create a StatefulSet?
- What Should I Do If Error Message "Auth is empty" Is Displayed When a Private Image Is Pulled?
- What Is the Image Pull Policy for Containers in a CCE Cluster?
- Why Is the Mount Point of a Docker Container in the Kunpeng Cluster Uninstalled?
- What Can I Do If a Layer Is Missing During Image Pull?
- Why the File Permission and User in the Container Are Question Marks?
Network Exception Troubleshooting
- How Do I Locate a Workload Networking Fault?
- Why the ELB Address Cannot Be used to Access Workloads in a Cluster?
- Why the Ingress Cannot Be Accessed Outside the Cluster?
- Why Does the Browser Return Error Code 404 When I Access a Deployed Application?
- What Should I Do If a Container Fails to Access the Internet?
- What Can I Do If a VPC Subnet Cannot Be Deleted?
- How Do I Restore a Faulty Container NIC?
- What Should I Do If a Node Fails to Connect to the Internet (Public Network)?
- How Do I Resolve a Conflict Between the VPC CIDR Block and the Container CIDR Block?
- What Should I Do If the Java Error "Connection reset by peer" Is Reported During Layer-4 ELB Health Check
- How Do I Locate the Service Event Indicating That No Node Is Available for Binding?
- Why Does "Dead loop on virtual device gw_11cbf51a, fix it urgently" Intermittently Occur When I Log In to a VM using VNC?
- Why Does a Panic Occasionally Occur When I Use Network Policies on a Cluster Node?
- Why Are Lots of source ip_type Logs Generated on the VNC?
- What Should I Do If Status Code 308 Is Displayed When the Nginx Ingress Controller Is Accessed Using the Internet Explorer?
- What Should I Do If Nginx Ingress Access in the Cluster Is Abnormal After the NGINX Ingress Controller Add-on Is Upgraded?
- What Should I Do If An Error Occurred During a LoadBalancer Update?
- What Could Cause Access Exceptions After Configuring an HTTPS Certificate for a LoadBalancer Ingress?
Network Planning
- What Is the Relationship Between Clusters, VPCs, and Subnets?
- How Do I View the VPC CIDR Block?
- How Do I Set the VPC CIDR Block and Subnet CIDR Block for a CCE Cluster?
- How Do I Set a Container CIDR Block for a CCE Cluster?
- When Should I Use Cloud Native Network 2.0?
- What Is an ENI?
- How Can I Configure a Security Group Rule in a Cluster?
- How Do I Configure the IPv6 Service CIDR Block When Creating a CCE Turbo Cluster?
- Can Multiple NICs Be Bound to a Node in a CCE Cluster?
- Security Hardening
- How Does CCE Communicate with Other Huawei Cloud Services over an Intranet?
- How Do I Set the Port When Configuring the Workload Access Mode on CCE?
- How Can I Achieve Compatibility Between Ingress's property and Kubernetes client-go?
- How Do I Obtain the Actual Source IP Address of a Client After a Service Is Added into Istio?
- Why Cannot an Ingress Be Created After the Namespace Is Changed?
- Why Is the Backend Server Group of an ELB Automatically Deleted After a Service Is Published to the ELB?
- How Can Container IP Addresses Survive a Container Restart?
- How Can I Check Whether an ENI Is Used by a Cluster?
- How Can I Delete a Security Group Rule Associated with a Deleted Subnet?
- How Can I Synchronize Certificates When Multiple Ingresses in Different Namespaces Share a Listener?
- How Can I Determine Which Ingress the Listener Settings Have Been Applied To?
- How Do I Expand the Storage Capacity of a Container?
- What Are the Differences Among CCE Storage Classes in Terms of Persistent Storage and Multi-Node Mounting?
- Can I Create a CCE Node Without Adding a Data Disk to the Node?
- Can EVS Volumes in a CCE Cluster Be Restored After They Are Deleted or Expired?
- What Should I Do If the Host Cannot Be Found When Files Need to Be Uploaded to OBS During the Access to the CCE Service from a Public Network?
- How Can I Achieve Compatibility Between ExtendPathMode and Kubernetes client-go?
- Can CCE PVCs Detect Underlying Storage Faults?
- An Error Is Reported When the Owner Group and Permissions of the Mount Point of the SFS 3.0 File System in the OS Are Modified
- Why Cannot I Delete a PV or PVC Using the kubectl delete Command?
- What Should I Do If "target is busy" Is Displayed When a Pod with Cloud Storage Mounted Is Being Deleted?
- What Should I Do If a Yearly/Monthly EVS Disk Cannot Be Automatically Created?
- Namespace
Chart and Add-on
- What Should I Do If the nginx-ingress Add-on Fails to Be Installed on a Cluster and Remains in the Creating State?
- What Should I Do If Residual Process Resources Exist Due to an Earlier npd Add-on Version?
- What Should I Do If a Chart Release Cannot Be Deleted Because the Chart Format Is Incorrect?
- Does CCE Support nginx-ingress?
- What Should I Do If Installation of an Add-on Fails and "The release name is already exist" Is Displayed?
- What Should I Do If a Release Creation or Upgrade Fails and "rendered manifests contain a resource that already exists" Is Displayed?
- What Can I Do If the kube-prometheus-stack Add-on Instance Fails to Be Scheduled?
- What Can I Do If a Chart Fails to Be Uploaded?
- How Do I Configure the Add-on Resource Quotas Based on Cluster Scale?
- How Can I Clean Up Residual Resources After the NGINX Ingress Controller Add-on in the Unknown State Is Deleted?
- Why TLS v1.0 and v1.1 Cannot Be Used After the NGINX Ingress Controller Add-on Is Upgraded?
API & kubectl FAQs
- How Can I Access a Cluster API Server?
- Can the Resources Created Using APIs or kubectl Be Displayed on the CCE Console?
- How Do I Download kubeconfig for Connecting to a Cluster Using kubectl?
- How Do I Rectify the Error Reported When Running the kubectl top node Command?
- Why Is "Error from server (Forbidden)" Displayed When I Use kubectl?
DNS FAQs
- What Should I Do If Domain Name Resolution Fails in a CCE Cluster?
- Why Does a Container in a CCE Cluster Fail to Perform DNS Resolution?
- Why Cannot the Domain Name of the Tenant Zone Be Resolved After the Subnet DNS Configuration Is Modified?
- How Do I Optimize the Configuration If the External Domain Name Resolution Is Slow or Times Out?
- How Do I Configure a DNS Policy for a Container?
- Image Repository FAQs
- Permissions
- Related Services
- Videos
More Documents
- Getting Started
- High-Risk Operations and Solutions
Clusters
- Cluster Overview
- Buying a Cluster
Upgrading a Cluster
- Upgrade Overview
- Before You Start
- Performing an In-place Upgrade
- Pre-upgrade Check
- Node Restrictions
- Add-ons
- Helm Charts
- Node Pools
- Security Groups
- Arm Node Restrictions
- To-Be-Migrated Nodes
- Node CCE Agent Versions
- Node CPU Usage
- CRDs
- Node Disks
- Node DNS
- Kubelet
- Node Memory
- Node OS
- Node CPUs
- ASM Version
- Node Readiness
- Node journald
- containerd.sock
- Internal Errors
- Node Mount Points
- cce-hpa-controller Restrictions
- IPv6 Capabilities of a CCE Turbo Cluster
- Node NetworkManager
- Node ID File
- sudo Commands of a Node
- Key Commands of Nodes
- Node Mounting
- GPU Add-on
- Nodes' System Parameter Settings
- Residual Package Versions
- Node Commands
- Node Swap
- nginx-ingress Upgrade
- Managing a Cluster
- Nodes
- Node Pools
Workloads
- Overview
Configuring a Container
- Configuring APM Settings for Performance Bottleneck Analysis
- Workload Upgrade Policies
- Scheduling Policies (Affinity/Anti-affinity)
- Taints and Tolerations
- Labels and Annotations
- Accessing a Container
- Managing Workloads and Jobs
- Kata Runtime and Common Runtime
- Scheduling
Network
- Overview
- Container Network Models
Service
- Overview
- ClusterIP
- NodePort
LoadBalancer
- Using Annotations to Configure Load Balancing
- Service Using HTTP or HTTPS
- Configuring Health Check for Multiple Ports
- Enabling Passthrough Networking for LoadBalancer Services
- DNAT
- Headless Service
Ingresses
- Overview
ELB Ingresses
- Creating an ELB Ingress on the Console
- Using kubectl to Create an ELB Ingress
- Configuring ELB Ingresses Using Annotations
- Configuring HTTPS Certificates for ELB Ingresses
- Configuring the Server Name Indication (SNI) for ELB Ingresses
- ELB Ingresses Routing to Multiple Services
- ELB Ingresses Using HTTP/2
- Interconnecting ELB Ingresses with HTTPS Backend Services
- Configuring Timeout for an ELB Ingress
Nginx Ingresses
- Creating Nginx Ingresses on the Console
- Using kubectl to Create an Nginx Ingress
- Configuring Nginx Ingresses Using Annotations
- Configuring HTTPS Certificates for Nginx Ingresses
- Configuring URL Rewriting Rules for Nginx Ingresses
- Interconnecting Nginx Ingresses with HTTPS Backend Services
- Nginx Ingresses Using Consistent Hashing for Load Balancing
- DNS
- Container Network Settings
- Accessing Public Networks from a Container
- Storage
- Observability
- Namespaces
- Auto Scaling
Add-ons
- Overview
- CoreDNS
- Nginx Ingress Controller
- CCE Advanced HPA
- Volcano Scheduler
- Prometheus
- Helm Chart
- Permissions
Best Practices
- Containerization
- Disaster Recovery
- Security
- Auto Scaling
- Monitoring
- Cluster
- Networking
- Storage
- Container
- Permission
- Release
- Common Questions
- Cluster
Node
- Node Creation
Node Running
- Node Pool
Workload
Workload Abnormalities
- How Do I Use Events to Fix Abnormal Workloads?
- What Should I Do If Pods in the Terminating State Cannot Be Deleted?
- What Should I Do If an Error Occurs When Deploying a Service on the GPU Node?
- When Is Pre-stop Processing Used?
- How Do I Set an FQDN for Accessing a Specified Container in the Same Namespace?
- What Should I Do If Health Check Probes Occasionally Fail?
- How Do I Set the umask Value for a Container?
- What Can I Do If an Error Is Reported When a Deployed Container Is Started After the JVM Startup Heap Memory Parameter Is Specified for ENTRYPOINT in Dockerfile?
- What Is the Retry Mechanism When CCE Fails to Start a Pod?
- What Should I Do If a Scheduled Task Cannot Be Restarted After Being Stopped for a Period of Time?
- Networking
- What Are the Differences Among CCE Storage Classes in Terms of Persistent Storage and Multi-node Mounting?
- Can I Add a Node Without a Data Disk?
- Namespace
- Chart and Add-on
API & kubectl FAQs
- How Can I Access a CCE Cluster?
- DNS FAQs
- Permissions
- Reference
- Before You Start
- API Overview
- Calling APIs
APIs
- API URL
Cluster Management
- Querying a Job
- Node Management
- Add-on Management
- Quota Management
- API Versions
- Kubernetes APIs
Appendix
- Status Code
- Error Codes
- Obtaining the Account ID
- Node OS
- Data Disk Space Allocation
- Change History
User Guide (Paris Regions)
Product Bulletin
- Risky Operations on Cluster Nodes
- CCE Security Guide
- Cluster Node OS Patch Notes
- Notice on the Kubernetes Security Vulnerability (CVE-2022-3172)
- Privilege Escalation Vulnerability in Linux openvswitch Kernel Module (CVE-2022-2639)
- Notice on CRI-O Container Runtime Engine Arbitrary Code Execution Vulnerability (CVE-2022-0811)
- Notice on the Container Escape Vulnerability Caused by the Linux Kernel (CVE-2022-0492)
- Linux Kernel Integer Overflow Vulnerability (CVE-2022-0185)
- Kubernetes Basics
- Getting Started
Clusters
- Cluster Overview
Upgrading a Cluster
- Upgrade Overview
- Before You Start
- Performing In-place Upgrade
- Pre-upgrade Check
- Node Restrictions
- Add-ons
- Helm Charts
- Node Pools
- Security Groups
- Node CPU Usage
- CRDs
- Node Disks
- Node DNS
- Kubelet
- Node Memory
- Node OS
- Node CPUs
- ASM Version
- Node Readiness
- Node journald
- containerd.sock
- Internal Errors
- Node Mount Points
- everest Restrictions
- Node ID File
- Node Mounting
- GPU Add-on
- Node Commands
- Node Swap
- Nodes
- Node Pools
Workloads
- Overview
- Setting Container Specifications
- Setting Container Lifecycle Parameters
- Setting Health Check for a Container
- Setting an Environment Variable
- Configuring the Workload Upgrade Policy
- Scheduling Policy (Affinity/Anti-affinity)
- Scheduling
Network
- Overview
- Service
Ingresses
- Overview
ELB Ingresses
Nginx Ingresses
- DNS
- Storage
- Observability
- Namespaces
- Auto Scaling
- Add-ons
- Helm Chart
- Permissions
- Common Questions
- Billing
- Cluster
Node
- Node Creation
Node Running
- Node Pool
Workload
- What Should I Do If Sandbox-Related Errors Are Reported When the Pod Remains in the Creating State?
- Network Planning
Network Fault
- What Should I Do If an Nginx Ingress Access in the Cluster Is Abnormal After the Add-on Is Upgraded?
- Namespace
- Chart and Add-on
API & kubectl FAQs
- DNS FAQs
- Permissions
- Reference
Best Practices
- Containerization
- Disaster Recovery
- Security
- Auto Scaling
- Monitoring
- Cluster
- Networking
- Mounting an Object Storage Bucket of a Third-Party Tenant
- Dynamically Creating and Mounting Subdirectories of an SFS Turbo File System
- How Do I Change the Storage Class Used by a Cluster of v1.15 from FlexVolume to CSI Everest?
- Custom Storage Classes
- Enabling Automatic Topology for EVS Disks When Nodes Are Deployed in Different AZs (csi-disk-topology)
- Container
- Permission
- Release
- Migrating Data from CCE 1.0 to CCE 2.0
API Reference (Paris Regions)
- Before You Start
- API Overview
- Calling APIs
APIs
- API URL
Cluster Management
- Querying a Job
- Node Management
- Add-on Management
- Quota Management
- API Versions
- Kubernetes APIs
Appendix
- Status Code
- Error Codes
- Node OS
- Change History
- CCE Console Upgrade
- Getting Started
Clusters
- Cluster Overview
- Buying a Cluster
Upgrading a Cluster
- Before You Start
- Pre-upgrade Check
- Node Restrictions
- Add-ons
- Helm Charts
- Node Pools
- Security Groups
- Residual Nodes
- Node CPU Usage
- CRDs
- Node Disks
- Node DNS
- kubelet
- Node Memory
- Node OS
- Node CPUs
- ASM Version
- Node Readiness
- Node journald
- containerd.sock
- Internal Errors
- Node Mount Points
- NetworkManager
- Node ID File
- sudo
- Key Node Commands
- Node Mounting
- GPU Add-on
- Node Commands
- Node Swap
- Node Runtime
- Node Pool Runtime
- Nodes
- Node Pools
Workloads
- Overview
- Pod Security
- Scheduling
Network
- Overview
- Container Network
Service
- Overview
- ClusterIP
- NodePort
LoadBalancer
- Using Annotations to Balance Load
- DNAT
- Headless Services
Ingresses
- Overview
- Using kubectl to Create a LoadBalancer Ingress
- Configuring a LoadBalancer Ingress Using Annotations
- Routing a LoadBalancer Ingress to Multiple Services
Nginx Ingresses
- DNS
- Storage
- Observability
- Auto Scaling
- Namespaces
- Add-ons
- Helm Chart
- Permissions
Best Practices
- Containerization
- Disaster Recovery
- Security
- Auto Scaling
- Monitoring
- Cluster
- Networking
- Storage
- Container
- Permission
- Release
- Common Questions
- Cluster
Node
- Node Creation
Node Running
- OSs
- Node Pool
Workload
- Network Planning
Network Fault
- Network Configuration
- Namespace
Chart and Add-on
API & kubectl FAQs
- DNS FAQs
- Permissions
- Before You Start
- API Overview
- Calling APIs
APIs
- API URL
Cluster Management
- Querying a Job
- Node Management
- Add-on Management
- Tag Management
Chart Management
- Uploading a Chart
- Updating a Chart
- Deleting a Chart
- Obtaining a Chart
- Kubernetes APIs
Appendix
- Status Code
- Error Codes
- Obtaining a Domain ID
- Node OS
User Guide (Ankara Region)
- Product Bulletin
- Getting Started
Clusters
- Cluster Overview
Upgrading a Cluster
- Upgrade Overview
- Before You Start
- Pre-upgrade Check
- Node Restrictions
- Add-ons
- Helm Charts
- Node Pools
- Security Groups
- Node CPU Usage
- CRDs
- Node Disks
- Node DNS
- Kubelet
- Node Memory
- Node OS
- Node CPU Cores
- ASM Version
- Node Readiness
- Node journald
- containerd.sock
- Internal Error
- Node Mount Points
- Node ID File
- Node Mounting
- GPU Add-on
- Node Commands
- Node Swap
- Node Runtime
- Node Pool Runtime
- Nodes
- Node Pools
Workloads
- Overview
- Scheduling
Network
- Overview
Service
- Overview
- ClusterIP
- NodePort
LoadBalancer
- Configuring an HTTP or HTTPS Service
- Configuring SNI for a Service
- Configuring HTTP/2 for a Service
- Configuring Timeout for a Service
- Configuring Health Check on Multiple Service Ports
- Headless Services
Ingresses
- Overview
- LoadBalancer Ingresses to Multiple Services
Nginx Ingresses
- DNS
- Storage
- Observability
- Namespaces
- Auto Scaling
Add-ons
- Overview
- CoreDNS
- CCE Advanced HPA
- Volcano Scheduler
- Grafana
- Prometheus
- Helm Chart
- Permissions
- Common Questions
- Cluster
Node
- Node Creation
Node Running
- OSs
- Node Pool
Workload
- Network Planning
Network Fault
- Others
- Namespace
Chart and Add-on
- Why Does Add-on Installation Fail and Prompt "The release name is already exist"?
- What Should I Do If the Helm Chart Uploaded Before the Tenant Account Name Is Changed Is Abnormal?
API & kubectl FAQs
- DNS FAQs
- Permissions
- Reference
Best Practices
- Containerization
- Disaster Recovery
- Security
- Auto Scaling
- Monitoring
- Cluster
- Networking
- Storage
- Container
- Permission
- Release
API Reference (Ankara Region)
- Before You Start
- API Overview
- Calling APIs
APIs
- API URL
Cluster Management
- Querying a Job
- Node Management
- Add-on Management
- Quota Management
- API Versions
- Tag Management
Chart Management
- Uploading a Chart
- Updating a Chart
- Deleting a Chart
- Obtaining a Chart
- Kubernetes APIs
Appendix
- Status Code
- Error Codes
- Node OS
On this page
Help Center/
Cloud Container Engine/
User Guide (ME-Abu Dhabi Region)/
Clusters/
Cluster Overview/
Kubernetes Release Notes/
Kubernetes 1.19 Release Notes
CCE has passed the Certified Kubernetes Conformance Program and is a certified Kubernetes offering. This section describes the updates in CCE Kubernetes 1.19.
Resource Changes and Deprecations
Kubernetes v1.19 Release Notes
- vSphere in-tree volumes can be migrated to vSphere CSI drivers. The in-tree vSphere Volume plugin is no longer used and will be deleted in later versions.
- apiextensions.k8s.io/v1beta1 has been deprecated. You are advised to use apiextensions.k8s.io/v1.
- apiregistration.k8s.io/v1beta1 has been deprecated. You are advised to use apiregistration.k8s.io/v1.
- authentication.k8s.io/v1beta1 and authorization.k8s.io/v1beta1 have been deprecated and will be removed from Kubernetes 1.22. You are advised to use authentication.k8s.io/v1 and authorization.k8s.io/v1.
- autoscaling/v2beta1 has been deprecated. You are advised to use autoscaling/v2beta2.
- coordination.k8s.io/v1beta1 has been deprecated in Kubernetes 1.19 and will be removed from version 1.22. You are advised to use coordination.k8s.io/v1.
- kube-apiserver: The componentstatus API has been deprecated.
- kubeadm: The kubeadm config view command has been deprecated and will be deleted in later versions. Use kubectl get cm -o yaml -n kube-system kubeadm-config to directly obtain the kubeadm configuration.
- kubeadm: The kubeadm alpha kubelet config enable-dynamic command has been deprecated.
- kubeadm: The --use-api flag in the kubeadm alpha certs renew command has been deprecated.
- Kubernetes no longer supports hyperkube image creation.
- The --export flag is removed from the kubectl get command.
- The alpha feature ResourceLimitsPriorityFunction has been deleted.
- storage.k8s.io/v1beta1 has been deprecated. You are advised to use storage.k8s.io/v1.
Kubernetes v1.18 Release Notes
- kube-apiserver
- All resources in the apps/v1beta1 and apps/v1beta2 API versions are no longer served. You can use the apps/v1 API version.
- DaemonSets, Deployments, and ReplicaSets in the extensions/v1beta1 API version are no longer served. You can use the apps/v1 API version.
- NetworkPolicies in the extensions/v1beta1 API version are no longer served. You can use the networking.k8s.io/v1 API version.
- PodSecurityPolicies in the extensions/v1beta1 API version are no longer served. Migrate to use the policy/v1beta1 API version.
- kubelet
- --redirect-container-streaming is not recommended and will be deprecated in v1.20.
- The resource measurement endpoint /metrics/resource/v1alpha1 and all measurement standards under this endpoint have been deprecated. Use the measurement standards under the endpoint /metrics/resource instead:
- scrape_error --> scrape_error
- node_cpu_usage_seconds_total --> node_cpu_usage_seconds
- node_memory_working_set_bytes --> node_memory_working_set_bytes
- container_cpu_usage_seconds_total --> container_cpu_usage_seconds
- container_memory_working_set_bytes --> container_memory_working_set_bytes
- In future releases, kubelet will no longer create the target directory CSI NodePublishVolume according to the CSI specifications. You may need to update the CSI driver accordingly to correctly create and process the target path.
- kube-proxy
- You are not advised to use the --healthz-port and --metrics-port flags. Use --healthz-bind-address and --metrics-bind-address instead.
- The EndpointSliceProxying function option is added to control the use of EndpointSlices in kube-proxy. This function is disabled by default.
- kubeadm
- The --kubelet-version flag of kubeadm upgrade node has been deprecated and will be deleted in later versions.
- The --use-api flag in the kubeadm alpha certs renew command has been deprecated.
- kube-dns has been deprecated and will no longer be supported in future versions.
- The ClusterStatus structure in the kubeadm-config ConfigMap has been deprecated and will be deleted in later versions.
- kubectl
- You are not advised to use boolean and unset values for --dry-run. server|client|none is used in the new version.
- --server-dry-run has been deprecated for kubectl apply and replaced by --dry-run=server.
- add-ons
The cluster-monitoring add-on is deleted.
- kube-scheduler
- The scheduling_duration_seconds metric has been deprecated.
- The scheduling_algorithm_predicate_evaluation_seconds and scheduling_algorithm_priority_evaluation_seconds counters metrics are no longer used and are replaced by framework_extension_point_duration_seconds[extension_point="Filter"] and framework_extension_point_duration_seconds[extension_point="Score"].
- The scheduler policy AlwaysCheckAllPredictes has been deprecated.
- Other changes
- The k8s.io/node-api component is no longer updated. Instead, you can use the RuntimeClass type in k8s.io/api and the generated clients in k8s.io/client-go.
- The client label has been deleted from apiserver_request_total.
References
For more details about the performance comparison and function evolution between Kubernetes 1.19 and other versions, see the following documents:
Parent topic: Kubernetes Release Notes
