Help Center>
Cloud Container Engine>
User Guide (ME-Abu Dhabi Region)>
Nodes>
Management Nodes>
Stopping a Node
Updated on 2024-01-04 GMT+08:00
Stopping a Node
After a node in the cluster is stopped, services on the node are also stopped. Before stopping a node, ensure that discontinuity of the services on the node will not result in adverse impacts.
- Deleting a node will lead to pod migration, which may affect services. Therefore, delete nodes during off-peak hours.
- Unexpected risks may occur during the operation. Back up related data in advance.
- While the node is being deleted, the backend will set the node to the unschedulable state.
- Only worker nodes can be stopped.
- In the navigation pane, choose Nodes. On the displayed page, click the Nodes tab.
- Locate the target node and click its name.
- In the upper right corner of the ECS details page, click Stop. In the displayed dialog box, click Yes.
Parent topic: Management Nodes
