Help Center/ Cloud Container Engine/ User Guide/ O&M/ Log Auditing/ CCE Operations Supported by CTS
Updated on 2026-09-21 GMT+08:00
Cloud Trace Service (CTS) records operations on cloud service resources, allowing you to query, audit, and backtrack the resource operation requests initiated from the CCE console or open APIs as well as responses to the requests.
To collect the query events (Get and List) listed in the table below, enable read-only event reporting of CCE in CTS. Because query operations occur far more frequently than addition, deletion, or modification operations, enabling this function may generate a large number of events. Assess the potential impacts before enabling it.
Table 1 CCE operations supported by CTS
Operation
Resource
Trace Name
Creating an agency
Cluster
createUserAgencies
Querying an agency
Cluster
getUserAgencies
Obtaining an access policy
Cluster
getAccessPolicy
Creating an access policy
Cluster
createAccessPolicy
Deleting an access policy
Cluster
deleteAccessPolicy
Obtaining the access policy list
Cluster
listAccessPolicy
Updating an access policy
Cluster
updateAccessPolicy
Creating a cluster
Cluster
createCluster
Creating a yearly/monthly cluster
Cluster
createCluster/createPeriodicCluster
Updating the description of a cluster
Cluster
updateCluster
Upgrading a cluster
Cluster
clusterUpgrade
Deleting a cluster
Cluster
claimCluster/deleteCluster
Obtaining the cluster list
Cluster
listCluster
Obtaining the cluster list in a project
Cluster
getClustersByProjectID
Obtaining the number of clusters
Cluster
getClusterInstances
Obtaining a cluster
Cluster
getClusterByUID
Obtaining the cluster package list
Cluster
getPackageLists
Obtaining the package configuration of a cluster
Cluster
getPackageConfigs
Downloading a cluster certificate
Cluster
getClusterCertByUID
Revoking a cluster certificate
Cluster
revokeClusterCert
Binding and unbinding an EIP
Cluster
operateMasterEIP
Waking up a cluster and resetting node management (V2)
Cluster
operateCluster
Hibernating a cluster (V3)
Cluster
hibernateCluster
Waking up a cluster (V3)
Cluster
awakeCluster
Changing the size of a pay-per-use cluster
Cluster
resizeCluster
Changing the size of a yearly/monthly cluster
Cluster
resizePeriodCluster
Modifying configurations of a cluster
Cluster
updateConfiguration
Obtaining cluster configuration
Cluster
getClusterConfiguration
Obtaining all configurations of the current cluster version
Cluster
getClusterConfigurationDetail
Querying the detailed configuration items of a cluster by cluster version or type
Cluster
getClusterSupportConfiguration
Obtaining cluster quotas
Cluster
getQuotas
Obtaining the global OBS access secret configuration of a cluster
Cluster
getClusterLongAKSKConfig
Updating the global OBS access secret configuration of a cluster
Cluster
updateClusterLongAKSKConfig
Updating the global OBS access secret configuration in a project
Cluster
UpdateAKSKConfig
Obtaining the global OBS access secret configuration in a project
Cluster
GetAKSKConfig
Obtaining the IP address of a master node
Cluster
GetOpenAPIInfo
Obtaining the cluster access address
Cluster
GetEndpoints
Changing the billing mode of a cluster from pay-per-use to yearly/monthly
Cluster
ChangeBillingModeToPeriod
Retrying a cluster upgrade
Cluster
ClusterUpgradeRetry
Pausing a cluster upgrade
Cluster
ClusterUpgradePause
Continuing a cluster upgrade
Cluster
ClusterUpgradeContinue
Rolling back a cluster upon an upgrade failure
Cluster
Rollback
Rolling back a cluster upon an upgrade retry failure
Cluster
ClusterRollbackRetry
Pausing a cluster upgrade rollback
Cluster
ClusterRollbackPause
Continuing a cluster upgrade rollback
Cluster
ClusterRollbackContinue
Querying the cluster rollback history
Cluster
GetRollbackTasks
Querying the cluster upgrade history
Cluster
GetUpgradeTasks
Querying the records of a cluster upgrade
Cluster
GetUpgradeTask
Querying cluster labels
Cluster
GetLabels
Querying the configuration of a cluster
Cluster
GetUpgradeInfo
Obtaining the certificate rotation state
Cluster
GetRotationState
Rotating certificates
Cluster
RotateCredentials
Downloading certificates
Cluster
DownloadNodeCredentials
Rolling back certificates
Cluster
RollbackCredentials
Completing certificate rotation
Cluster
FinishEncryptionKeyRotation
Supplementing the component certificates of a master node
Cluster
CompleteComponentCredential
Updating cluster certificates
Cluster
RotateClusterCredentials
Enabling the cluster upgrade workflow booting task
Cluster
UpgradeWorkFlow
Querying cluster upgrade workflows
Cluster
GetUpgradeWorkFlows
Querying details about a cluster upgrade task
Cluster
UpgradeWorkFlowUpdate
Performing a pre-upgrade check for a cluster
Cluster
PreCheck
Obtaining the list of historical check records
Cluster
GetPreCheckList
Obtaining a specific check record
Cluster
GetPreCheck
Performing a post-upgrade check
Cluster
PostCheck
Performing a rolling upgrade on the cluster control plane
Cluster
RollingUpdateControlPlane
Retrying a rolling upgrade on the cluster control plane
Cluster
RetryRollingUpdateControlPlane
Creating a node pool
Node pool
createNodePool
Updating a node pool
Node pool
updateNodePool
Deleting a node pool
Node pool
claimNodePool
Migrating a node pool
Node pool
migrateNodepool
Updating the node pool configuration
Node pool
updateConfiguration
Obtaining the node pool configuration
Node pool
getConfiguration
Obtaining node pool details
Node pool
getConfigurationDetail
Querying a node pool
Node pool
getNodePool
Querying the node pool quota
Node pool
getNodePoolQuota
Querying all node pools in a cluster
Node pool
listNodePools
Scaling up a yearly/monthly node pool
Node pool
scalePeriodicNodePool
Scaling down a node pool
Node pool
scaleNodePool
Upgrading a node pool
Node pool
upgradeNodePool
Adding nodes
Node
addNodes
Creating a node
Node
createNode
Creating a yearly/monthly node
Node
createPeriodNode
Deleting all nodes from a cluster
Node
deleteAllHosts
Deleting a node
Node
deleteOneHost/claimOneHost
Updating the description of a node
Node
updateNode
Obtaining the list of nodes in a cluster
Node
getHostsList
Obtaining a node
Node
getOneHost
Changing the node billing mode from pay-per-use to yearly/monthly
Node
changeNodeBillingModeToPeriod
Removing nodes
Node
removeNodesTask
Resetting nodes
Node
resetNodes
Migrating nodes to the node pool
Node
MigrateNodes
Synchronizing nodes in a batch
Node
SyncNodes
Migrating nodes
Node
MigrateNodesTask
Locking a node pool so that it will not be scaled down
Node
LockNodepoolNodeScaleDown
Unlocking a node pool so that it can be scaled down
Node
UnLockNodepoolNodeScaleDown
Deleting all jobs
Job
deleteJobs
Deleting a job
Job
deleteOneJob
Obtaining jobs in a project
Job
getJobsByProjectID
Obtaining a job
Job
getJobByUID
Creating an add-on pod
Add-on pod
createAddonInstance
Querying an add-on pod
Add-on pod
getAddonInstance
Deleting an add-on pod
Add-on pod
deleteAddonInstance
Obtaining the add-on list
Add-on pod
getAddonsList
Updating an add-on pod
Add-on pod
updateAddonInstance
Rolling back an add-on pod
Add-on pod
rollbackAddonInstance
Obtaining add-on details by add-on ID
Add-on pod
GetAddonTemplate
Obtaining the add-on template list
Add-on pod
GetAddonTemplateList
Uploading a chart
Chart
uploadChart
Updating a chart
Chart
updateChart
Deleting a chart
Chart
deleteChart
Downloading a chart
Chart
downloadChart
Querying a chart
Chart
getChart
Obtaining chart details
Chart
getChartValues
Obtaining the chart list
Chart
listCharts
Obtaining the chart quota
Chart
getUserChartsQuotas
Creating a release
Release
createRelease
Upgrading a release
Release
updateRelease
Deleting a release
Release
deleteRelease
Querying a release
Release
getRelease
Querying the release history
Release
getReleaseHistory
Querying the release list
Release
listReleases
Creating a ConfigMap
Kubernetes resource
createConfigmaps
Querying a ConfigMap
Kubernetes resource
getConfigmaps
Creating a DaemonSet
Kubernetes resource
createDaemonsets
Querying a DaemonSet
Kubernetes resource
getDaemonsets
Creating a Deployment
Kubernetes resource
createDeployments
Querying a Deployment
Kubernetes resource
getDeployments
Creating an event
Kubernetes resource
createEvents
Querying an event
Kubernetes resource
getEvents
Creating an ingress
Kubernetes resource
createIngresses
Querying an ingress
Kubernetes resource
getIngresses
Creating a job
Kubernetes resource
createJobs
Querying a job
Kubernetes resource
getJobs
Creating a namespace
Kubernetes resource
createNamespaces
Querying a namespace
Kubernetes resource
getNamespaces
Creating a node
Kubernetes resource
createNodes
Querying a node
Kubernetes resource
getNodes
Creating a PersistentVolumeClaim
Kubernetes resource
createPersistentvolumeclaims
Querying a PersistentVolumeClaim
Kubernetes resource
getPersistentvolumeclaims
Creating a pod
Kubernetes resource
createPods
Querying a pod
Kubernetes resource
getPods
Creating a ReplicaSet
Kubernetes resource
createReplicasets
Querying a ReplicaSet
Kubernetes resource
getReplicasets
Creating a resource quota
Kubernetes resource
createResourcequotas
Creating a secret
Kubernetes resource
createSecrets
Querying a secret
Kubernetes resource
getSecrets
Creating a Service
Kubernetes resource
createServices
Querying a Service
Kubernetes resource
getServices
Creating a StatefulSet
Kubernetes resource
createStatefulsets
Querying a StatefulSet
Kubernetes resource
getStatefulsets
Creating a volume
Kubernetes resource
createVolumes
Querying a volume
Kubernetes resource
getVolumes
Deleting a ConfigMap
Kubernetes resource
deleteConfigmaps
Deleting a DaemonSet
Kubernetes resource
deleteDaemonsets
Deleting a Deployment
Kubernetes resource
deleteDeployments
Deleting an event
Kubernetes resource
deleteEvents
Deleting an ingress
Kubernetes resource
deleteIngresses
Deleting a job
Kubernetes resource
deleteJobs
Deleting a namespace
Kubernetes resource
deleteNamespaces
Deleting a node
Kubernetes resource
deleteNodes
Deleting a Pod
Kubernetes resource
deletePods
Deleting a ReplicaSet
Kubernetes resource
deleteReplicasets
Deleting a resource quota
Kubernetes resource
deleteResourcequotas
Deleting a secret
Kubernetes resource
deleteSecrets
Deleting a Service
Kubernetes resource
deleteServices
Deleting a StatefulSet
Kubernetes resource
deleteStatefulsets
Deleting a volume
Kubernetes resource
deleteVolumes
Replacing a ConfigMap
Kubernetes resource
updateConfigmaps
Replacing a DaemonSet
Kubernetes resource
updateDaemonsets
Replacing a Deployment
Kubernetes resource
updateDeployments
Replacing an event
Kubernetes resource
updateEvents
Replacing an ingress
Kubernetes resource
updateIngresses
Replacing a job
Kubernetes resource
updateJobs
Replacing a namespace
Kubernetes resource
updateNamespaces
Replacing a node
Kubernetes resource
updateNodes
Replacing a PersistentVolumeClaim
Kubernetes resource
updatePersistentvolumeclaims
Replacing a pod
Kubernetes resource
updatePods
Replacing a ReplicaSet
Kubernetes resource
updateReplicasets
Replacing a resource quota
Kubernetes resource
updateResourcequotas
Replacing a secret
Kubernetes resource
updateSecrets
Replacing a Service
Kubernetes resource
updateServices
Replacing a StatefulSet
Kubernetes resource
updateStatefulsets
Replacing a status
Kubernetes resource
updateStatus
Uploading a component chart
Kubernetes resource
uploadChart
Updating a component chart
Kubernetes resource
updateChart
Deleting a component chart
Kubernetes resource
deleteChart
Querying a component chart
Kubernetes resource
getChart
Creating a release
Kubernetes resource
createRelease
Updating a release
Kubernetes resource
updateRelease
Deleting a release
Kubernetes resource
deleteRelease
Querying a release
Kubernetes resource
getRelease
Backing up a cluster
Cluster
Snapshot
Querying the snapshot task list of a cluster
Cluster
GetSnapshotTasks
Synchronizing the node pool configuration to existing nodes
Cluster
SyncNodePool
Obtaining tenant permission application records
Cluster
ListPermissionApplyOrders
Applying for tenant permissions
Cluster
CreatePermissionApplyOrder
Adding resource tags to a cluster in a batch
Cluster
BatchCreateDeleteResourceTags
Deleting tags from a cluster in a batch
Cluster
Creating a partition
Cluster
CreatePartition
Querying a partition
Cluster
GetOnePartition
Querying the partition list of a cluster
Cluster
GetPartitionList
Updating a partition
Cluster
UpdatePartition
Querying a warm-up pool
Cluster
GetWarmUpPool
Querying the warm-up pool list
Cluster
ListWarmUpPool
Updating a warm-up pool
Cluster
UpdateWarmUpPool
Creating a warm-up pool
Cluster
CreateWarmUpPool
Deleting a warm-up pool
Cluster
DeleteWarmUpPool
Querying an upgrade path
Cluster
GetClusterUpgradePaths
Querying upgrade feature gates
Cluster
GetUpgradeFeatureGates
Obtaining an automatic upgrade plan
Cluster
GetUpgradePlans
Deleting an automatic upgrade plan
Cluster
DeleteUpgradePlan
Obtaining a cluster maintenance window
Cluster
GetMaintenanceWindow
Updating a cluster maintenance window
Cluster
UpdateMaintenanceWindow
Creating a cluster maintenance window
Cluster
CreateMaintenanceWindow
Deleting a cluster maintenance window
Cluster
DeleteMaintenanceWindow
