Help Center/ Cloud Container Engine/ User Guide/ Nodes/ Node O&M/ Node Resource Reservation Rules
Updated on 2026-08-13 GMT+08:00
Some node resources are used to run mandatory Kubernetes system components and resources to make the node as part of your cluster. Therefore, the total number of node resources and the number of allocatable node resources for your cluster are different. The larger the node specifications, the more the containers deployed on the node. Therefore, more node resources need to be reserved to run Kubernetes components.
To maintain node stability, a specific number of CCE node resources will be reserved for Kubernetes components like kubelet, kube-proxy, and Docker, based on the node specifications.
CCE calculates the resources that can be allocated to user nodes as follows:
Allocatable = Capacity – Reserved – Eviction threshold
The memory eviction threshold is fixed at 100 MiB.
Total amount indicates the available memory of the ECS, excluding the memory used by system components. Therefore, it is slightly less than the total memory of the node flavor. For details, see Why Is the Memory of an ECS Obtained by Running the free Command Inconsistent with the Actual Memory?
When the memory consumed by all pods on a node increases, the following behaviors may occur:
  • When the available memory of the node is lower than the eviction threshold, kubelet is triggered to evict pods. For details about the eviction threshold in Kubernetes, see Node-pressure Eviction.
  • If a node triggers an OS memory insufficiency event (OOM) before kubelet reclaims memory, the system terminates the container. Unlike pod eviction, kubelet restarts the container based on the pod's RestartPolicy.
Querying Node Allocatable Resources
Use kubectl to access the cluster and run the following command to view a summary of all nodes. The output lists node names and statuses.
kubectl get nodes
View the total resources and allocatable resources of a specific node. Replace <node_name> with the name of the target node.
kubectl describe node <node_name> | grep Capacity -A 17
Expected output:
Capacity:
  cpu:                2                 # The number of CPU cores on the node
  ephemeral-storage:  102622136Ki       # Total ephemeral storage of the node, in KiB
  hugepages-1Gi:      0
  hugepages-2Mi:      0
  localssd:           0
  localvolume:        0
  memory:             3852580Ki         # Total memory of the node, in KiB
  pods:               20
Allocatable:
  cpu:                1930m             # The number of node's allocatable CPU cores
  ephemeral-storage:  94576560382       # The node's allocatable ephemeral storage, in bytes
  hugepages-1Gi:      0
  hugepages-2Mi:      0
  localssd:           0
  localvolume:        0
  memory:             2632996Ki          # The node's allocatable memory, in KiB
  pods:               20
Relationship Between Node Resource Reservation and Cluster Versions
Cluster Version
Specific Version
Node Memory Reservation
Node CPU Reservation
Node Data Disk Reservation
v1.29 or later
N/A
Node Memory Reservation Rule v2
Node CPU Reservation Rules
Node Data Disk Reservation Rules
v1.28
v1.28.2-r0 or later
Earlier than v1.28.2-r0
v1.27
v1.27.4-r0 or later
Earlier than v1.27.4-r0
v1.25
v1.25.7-r0 or later
Earlier than v1.25.7-r0
v1.23
v1.23.12-r0 or later
v1.23.3-r0 or later, or earlier than v1.23.12-r0
Earlier than v1.23.3-r0
Node Memory Reservation Rule v1
v1.21
v1.21.13-r0 or later
v1.21.4-r0 or later, or earlier than v1.21.13-r0
Earlier than v1.21.4-r0
You can use the following formula to calculate how much memory you should reserve for running containers on a node:
Total reserved amount = Reserved memory for system components + Reserved memory for kubelet to manage pods
Table 1 Reservation rules for system components
Total Memory (TM)
Reserved Memory for System Components
TM ≤ 8 GiB
0 MiB
8 GiB < TM ≤ 16 GiB
[(TM – 8 GiB) × 1,024 × 10%] MiB
16 GiB < TM ≤ 128 GiB
[8 GiB × 1,024 × 10% + (TM – 16 GiB) × 1,024 × 6%] MiB
TM > 128 GiB
[8 GiB × 1,024 × 10% + 112 GiB × 1,024 × 6% + (TM – 128 GiB) × 1,024 × 2%] MiB
Table 2 Reservation rules for kubelet
Total Memory (TM)
Number of Pods
Reserved Memory for kubelet
TM ≤ 2 GiB
None
TM × 25%
TM > 2 GiB
0 < Max. pods on a node ≤ 16
700 MiB
16 < Max. pods on a node ≤ 32
[700 + (Max. pods on a node – 16) × 18.75] MiB
32 < Max. pods on a node ≤ 64
[1,024 + (Max. pods on a node – 32) × 6.25] MiB
64 < Max. pods on a node ≤ 128
[1,230 + (Max. pods on a node – 64) × 7.80] MiB
Max. pods on a node > 128
[1,740 + (Max. pods on a node – 128) × 11.20] MiB
For a small-capacity node, adjust the maximum number of pods based on site requirements. Alternatively, when creating a node on the CCE console, you can adjust the maximum number of pods on the node based on the node specifications.
The total reserved memory of a CCE node using memory reservation rule v2 includes memory allocated for system components and Kubernetes.
Reserved memory includes basic and floating parts. For system components, the floating memory depends on the node specifications. For Kubernetes, the floating memory depends on the number of pods on a node.
By default, CCE automatically calculates the reserved memory based on the rules listed in Table 3. You can specify the reserved memory by configuring parameters system-reserved-mem and kube-reserved-mem in the node pool settings. For details, see Configuring a Node Pool.
Table 3 Node memory reservation rule v2
Memory Reserved For
Basic/Floating
Reservation
Used By
System components
Basic
Fixed at 400 MiB
OS service components such as sshd and systemd-journald.
Floating (depending on the node memory)
25 MiB reserved for each GiB of node memory. For custom node pools, the calculation uses the actual node memory. For default node pools, the calculation uses the memory value specified in the node flavor.
Kernel
Kubernetes
Basic
Fixed at 500 MiB
Container runtime components, such as kubelet and kube-proxy, when the node is unloaded
Floating (depending on the number of pods on the node)
Docker: 20 MiB/Pod
containerd: 5 MiB/pod
Container runtime components when the number of pods increases
When the v2 model reserves memory for a node by default, the default maximum number of pods is estimated based on the memory. For details, see Table 1.
Table 4 Node CPU reservation rules
Total CPU Cores (Total)
Reserved CPU Cores
Total ≤ 1 core
Total × 6%
1 core < Total ≤ 2 cores
1 core × 6% + (Total – 1 core) × 1%
2 cores < Total ≤ 4 cores
1 core × 6% + 1 core × 1% + (Total – 2 cores) × 0.5%
Total > 4 cores
1 core × 6% + 1 core × 1% + 2 cores × 0.5% + (Total – 4 cores) × 0.25%
CCE uses Logical Volume Manager (LVM) for disk management. LVM creates a metadata area on a disk to store logical and physical volume information, occupying 4 MiB of space. Therefore, the actual available disk space of a node is the disk size minus 4 MiB.
Helpful Links
For details about how to configure resource reservation and eviction thresholds, see Configuring a Node Pool.
