Help Center/ Cloud Container Engine/ User Guide/ O&M/ O&M Best Practices/ Monitoring Metrics of NGINX Ingress Controller
Updated on 2026-09-21 GMT+08:00
You can use Prometheus and Grafana to observe the metrics of NGINX Ingress Controller.
The following uses Prometheus as an example to describe how to view the metrics of NGINX Ingress Controller of a cluster.
  1. Accessing Prometheus
    (Optional) Bind a LoadBalancer Service to Prometheus so that Prometheus can be accessed from external networks.
  2. Monitoring Metrics of NGINX Ingress Controller
    Enable metric collection for the NGINX Ingress Controller add-on so that NGINX Ingress Controller metrics are automatically reported.
  • Cloud Native Cluster Monitoring v3.9.5 or later has been installed in the cluster. For details, see Cloud Native Cluster Monitoring.
  • NGINX Ingress Controller v2.5.4 or later has been installed in the cluster, and metric collection has been enabled. For details, see NGINX Ingress Controller.
After the Cloud Native Cluster Monitoring add-on is installed, you can deploy workloads and Services. The Prometheus server will be deployed as a StatefulSet in the monitoring namespace.
You can create a public LoadBalancer Service to enable Prometheus access from the Internet.
  1. Log in to the CCE console and click the name of the cluster with Prometheus installed to access the cluster console. In the navigation pane, choose Services and Ingresses.
  2. Click Create from YAML in the upper right corner to create a public LoadBalancer Service.
    apiVersion: v1
    kind: Service
      name: prom-lb     # Service name, which is customizable.
      namespace: monitoring
      labels:
        app: prometheus
        component: server
      annotations:
        kubernetes.io/elb.id: 038ff***     # Replace it with the ID of the public load balancer in the VPC that the cluster belongs to.
      ports:
        - name: cce-service-0
          protocol: TCP
          port: 88             # Service port, which is user-defined.
          targetPort: 9090     # Default Prometheus port. Retain the default value.
      selector:                # The label selector can be adjusted based on the label of a Prometheus server instance.
        app.kubernetes.io/name: prometheus
        prometheus: server
      type: LoadBalancer
  3. After the Service is created, enter {public-IP-address-of-the-load-balancer}:{Service-port} in the address box of the browser to access Prometheus.
    Figure 1 Accessing Prometheus
  4. Choose Status > Targets to view the targets monitored by Prometheus.
    Figure 2 Viewing monitored targets
Log in to Prometheus and click Graph to view the metrics of NGINX Ingress Controller.
Figure 3 Viewing the metrics of NGINX Ingress Controller
Table 1 Metrics of NGINX Ingress Controller
Category
Metric
Type
Traffic and request processing metrics
nginx_ingress_controller_bytes_sent
Basic metric
Total number of bytes sent by NGINX Ingress Controller to the client (including all response content, such as the response header and response body).
Unit: byte
nginx_ingress_controller_connect_duration_seconds
Basic metric
Time taken by NGINX Ingress Controller to establish a connection with the upstream server (backend service). This metric reflects the connection establishment efficiency.
Unit: second
nginx_ingress_controller_header_duration_seconds
Basic metric
Time taken from the moment when NGINX Ingress Controller sends a request to the upstream server to the moment when NGINX Ingress Controller receives the first response header from the upstream server.
Unit: second
nginx_ingress_controller_ingress_upstream_latency_seconds
Basic metric
Total latency for the upstream server to process a request. It is the time taken from the moment when NGINX Ingress Controller forwards the request to the upstream server to the moment when the upstream server returns a complete response.
Unit: second
nginx_ingress_controller_request_duration_seconds
Basic metric
Total processing time from the moment when the client sends a request to NGINX Ingress Controller to the moment when NGINX Ingress Controller returns a complete response to the client.
Unit: second
nginx_ingress_controller_request_size
Basic metric
Total length of a client request, including the request line (for example, GET /api HTTP/1.1), request header (for example, Host: example.com), and request body (for example, POST data).
Unit: byte
nginx_ingress_controller_requests
Basic metric
Total number of client requests received by NGINX Ingress Controller. The number of requests can be collected based on labels such as domain names and paths.
Unit: N/A
nginx_ingress_controller_response_duration_seconds
Basic metric
Time taken by NGINX Ingress Controller to receive the response from the upstream server, including all response bodies.
Unit: second
nginx_ingress_controller_response_size
Basic metric
Total length of the response returned by NGINX Ingress Controller to the client, including the response line (for example, HTTP/1.1 200 OK), response header, and response body.
Unit: byte
Process status metrics
nginx_ingress_controller_nginx_process_connections
Basic metric
Current number of client connections by state, including active connections (processing requests or waiting for responses), connections that are reading client requests, connections that are returning responses to clients, and idle connections (maintaining the connection status and waiting for new requests).
Unit: N/A
nginx_ingress_controller_nginx_process_connections_total
Basic metric
Total number of connections, including the number of accepted client connections and the number of connections that have been processed (requests successfully established and processed).
Unit: N/A
nginx_ingress_controller_nginx_process_cpu_seconds_total
Basic metric
Accumulated CPU time used by a process. This metric reflects the CPU resource consumption.
Unit: second
nginx_ingress_controller_nginx_process_num_procs
Basic metric
Number of processes that are running (including the main process and worker processes).
Unit: N/A
nginx_ingress_controller_nginx_process_oldest_start_time_seconds
Basic metric
Start time of the earliest process. The time is expressed as a Unix timestamp (number of seconds since 00:00:00 UTC on January 1, 1970). This metric measures how long a process has been running.
Unit: None
nginx_ingress_controller_nginx_process_read_bytes_total
Basic metric
Number of bytes read by a process from data sources such as disks and networks (for example, reading static files and receiving client request data).
Unit: byte
nginx_ingress_controller_nginx_process_requests_total
Basic metric
Total number of client requests processed by a process.
Unit: N/A
nginx_ingress_controller_nginx_process_resident_memory_bytes
Basic metric
Size of the physical memory (resident memory) currently used by a process, excluding the memory that is swapped to the disk. This metric indicates the hardware memory actually occupied.
Unit: byte
nginx_ingress_controller_nginx_process_virtual_memory_bytes
Basic metric
Total size of the virtual memory used by the process, including the physical memory, swap memory, and unused address space. This metric reflects the memory address range requested by the process.
Unit: byte
nginx_ingress_controller_nginx_process_write_bytes_total
Basic metric
Accumulated number of bytes written by a process (for example, sending responses to clients and writing log files) to the disk, network, and other devices.
Unit: byte
Controller configuration and status metrics
nginx_ingress_controller_build_info
Basic metric
A constant metric (the value is always 1). The label contains the build information of the controller.
Unit: None
nginx_ingress_controller_check_success
Basic metric
The frequency at which NGINX Ingress Controller checks the syntax of ingress rules and Nginx configurations.
Unit: N/A
nginx_ingress_controller_config_hash
Basic metric
Hash value of the current Nginx configuration file. This metric is used to check whether the configuration has changed.
Unit: None
nginx_ingress_controller_config_last_reload_successful
Basic metric
Whether the last attempt to reload the configuration is successful. The value 1 indicates that the configuration is reloaded, and the value 0 indicates that the configuration fails to be reloaded.
Unit: None
nginx_ingress_controller_config_last_reload_successful_timestamp_seconds
Basic metric
Unix timestamp when the last Nginx configuration is reloaded.
Unit: None
nginx_ingress_controller_ssl_certificate_info
Basic metric
SSL certificate-related label information (such as the certificate domain name, expiration time, and issuer) to monitor the certificate status (for example, whether the certificate is about to expire).
Unit: None
nginx_ingress_controller_success
Basic metric
The frequency at which NGINX Ingress Controller successfully reloads the configuration.
Unit: N/A
nginx_ingress_controller_orphan_ingress
Basic metric
Status of an isolated ingress. The value 1 indicates that an isolated ingress exists, and the value 0 indicates that no isolated ingress exists. An isolated ingress indicates that the Service or endpoint referenced in the rule does not exist. The labels are as follows:
  • namespace: namespace where the ingress is located.
  • ingress: ingress name
  • type: the reason why the ingress is isolated. The value can be no-service (indicating that the Service does not exist) or no-endpoint (indicating that the Service does not have available endpoints).
Admission Controller metrics
nginx_ingress_controller_admission_config_size
Basic metric
Size of the ingress configuration tested by Admission Controller.
Unit: byte
nginx_ingress_controller_admission_render_duration
Basic metric
Time taken by Admission Controller to render the ingress configuration.
Unit: second, floating-point type
nginx_ingress_controller_admission_render_ingresses
Basic metric
Number of ingresses rendered by Admission Controller.
Unit: N/A
nginx_ingress_controller_admission_roundtrip_duration
Basic metric
Total time taken by Admission Controller to process a complete event (from receiving a request to returning a result).
nginx_ingress_controller_admission_tested_duration
Basic metric
Time taken by Admission Controller to test the ingress configuration.
nginx_ingress_controller_admission_tested_ingresses
Basic metric
Number of ingresses processed by Admission Controller.
Unit: N/A
Liveness metric
up
Basic metric
Status of the monitored object.
  • 1: normal
  • 0: unavailable
When NGINX Ingress Controller is heavily loaded, there will be memory leakage if full metric collection is enabled. For details, see the community issue. It has been verified that the memory usage increase can be effectively suppressed after the following metrics are shielded. To prevent service loss caused by memory leakage, NGINX Ingress Controller shields the following metrics by default. We will continue to pay attention to the latest news in the community and fix this issue in a timely manner.
  • nginx_ingress_controller_header_duration_seconds
  • nginx_ingress_controller_ingress_upstream_latency_seconds
