Using DSS Through a Dynamic PV
CCE allows you to specify a StorageClass to automatically create a DSS disk and the corresponding PV. This function is applicable when no underlying storage volume is available.
Notes and Constraints
  • DSS disks cannot be attached across AZs and cannot be used by multiple workloads, multiple pods of the same workload, or multiple tasks. Data sharing of a shared disk is not supported between nodes in a CCE cluster. If a DSS disk is attached to multiple nodes, I/O conflicts and data cache conflicts may occur. Therefore, select only one pod when creating a Deployment that uses DSS.
  • If an HPA policy is used to expand the capacity of a workload with a DSS disk attached, new pods cannot be started because the DSS disk cannot attach to them.
Automatically Creating a DSS Volume on the Console
  2. Dynamically create a PVC and PV.
    1. Choose Storage in the navigation pane. In the right pane, click the PVCs tab. Click Create PVC in the upper right corner. In the dialog box displayed, configure PVC parameters.
      PVC Type
      In this example, select DSS.
      PVC Name
      Enter the PVC name, which must be unique in a namespace.
      Creation Method
      • If no underlying storage is available, select Dynamically provision to create a PVC, PV, and underlying storage on the console in cascading mode.
      • If underlying storage is available, create a PV or use an existing PV to statically create a PVC. For details, see Using DSS Through a Static PV.
      In this example, select Dynamically provision.
      Storage Classes
      The storage class for DSS disks is csi-disk-dss.
      (Optional) Storage Volume Name Prefix
      Available only when the cluster version is v1.23.14-r0, v1.25.9-r0, v1.27.6-r0, v1.28.4-r0, or later, and Everest of v2.4.15 or later is installed in the cluster.
      This parameter specifies the name of the underlying storage that is automatically created. The actual underlying storage name is in the format of "PV name prefix + PVC UID". If this parameter is left blank, the default prefix pvc will be used.
      For example, if the PV name prefix is set to test, the actual underlying storage name is test-{UID}.
      DSS Pool
      Select an existing DSS pool.
      Capacity (GiB)
      Capacity of the requested storage volume.
      Access Mode
      DSS volumes support only ReadWriteOnce, indicating that a storage volume can be mounted to one node in read/write mode.
      Encryption
      Configure whether to encrypt underlying storage. If you select Enabled (key), an encryption key must be configured.
      Resource Tag
      You can add resource tags to classify resources, which is supported only when the Everest version in the cluster is 2.1.39 or later.
      You can create predefined tags on the TMS console. The predefined tags are available to all resources that support tags. You can use predefined tags to improve the tag creation and resource migration efficiency.
      CCE automatically creates system tags CCE-Cluster-ID={Cluster ID}, CCE-Cluster-Name={Cluster name}, and CCE-Namespace={Namespace name}. These tags cannot be modified.
      After a dynamic PV of the DSS type is created, the resource tags cannot be updated on the CCE console. To update DSS resource tags, go to the DSS console.
    2. Click Create.
      You can choose Storage in the navigation pane and view the created PVC and PV on the PVCs and PVs tab pages, respectively.
  3. Create an application.
    1. Choose Workloads in the navigation pane. In the right pane, click the StatefulSets tab.
    2. Click Create Workload in the upper right corner. On the displayed page, click Data Storage in the Container Settings area and click Add Volume to select PVC.
      Mount and use storage volumes, as shown in Table 1. For details about other parameters, see Workloads.
      Table 1 Mounting a storage volume
      PVC
      Select an existing DSS volume.
      A DSS volume can be mounted to only one workload.
      Mount Path
      Enter a mount path, for example, /tmp.
      This parameter specifies a container path to which a data volume will be mounted. Do not mount the volume to a system directory such as / or /var/run. Otherwise, containers will be malfunctional. Mount the volume to an empty directory. If the directory is not empty, ensure that there are no files that affect container startup. Otherwise, the files will be replaced, leading to container startup failures or workload creation failures.
      NOTICE:
      If a volume is mounted to a high-risk directory, use an account with minimum permissions to start the container. Otherwise, high-risk files on the host may be damaged.
      Subpath
      Enter the subpath of the storage volume and mount a path in the storage volume to the container. In this way, different folders of the same storage volume can be used in a single pod. tmp, for example, indicates that data in the mount path of the container is stored in the tmp folder of the storage volume. If this parameter is left blank, the root path is used by default.
      Permission
      • Read-only: You can only read the data in the mounted volumes.
      • Read-write: You can modify the data volumes mounted to the path. Newly written data will not be migrated if the container is migrated, which may cause data loss.
      In this example, the disk is mounted to the /data path of the container. The container data generated in this path is stored in the DSS disk.
      A non-shared DSS disk can be attached to only one workload pod. If there are multiple pods, extra pods cannot start properly. Ensure that the number of workload pods is 1 if a DSS disk is attached.
      If multiple workload pods are needed, create a StatefulSet and dynamically mount a PV to each pod. For details, see Dynamically Mounting a DSS Disk to a StatefulSet.
    3. After the configuration, click Create Workload.
      After the workload is created, the data in the container mount directory will be persistently stored. Verify the storage by referring to Verifying Data Persistence.
Automatically Creating a DSS Volume Through kubectl
  1. Use kubectl to access the cluster.
  2. Use StorageClass to dynamically create a PVC and PV.
    1. Create the pvc-dss-auto.yaml file.
      apiVersion: v1
      kind: PersistentVolumeClaim
        namespace: default
        annotations:
          everest.io/disk-volume-type: SAS    # Disk type
          everest.io/csi.dedicated-storage-id: <dss_id>     # ID of the DSS storage pool
          everest.io/crypt-key-id: <your_key_id>    # (Optional) Encryption key ID. Mandatory for an encrypted disk.
          everest.io/disk-volume-tags: '{"key1":"value1","key2":"value2"}' # (Optional) Custom resource tags
          everest.io/csi.volume-name-prefix: test  # (Optional) PV name prefix of the automatically created underlying storage
        labels:
          failure-domain.beta.kubernetes.io/region: <your_region>   # Region of the node where the application is to be deployed
          failure-domain.beta.kubernetes.io/zone: <your_zone>       # AZ of the node where the application is to be deployed
        accessModes:
        - ReadWriteOnce               # The value must be ReadWriteOnce for DSS.
        resources:
          requests:
            storage: 10Gi             # Disk capacity, ranging from 1 to 32768
        storageClassName: csi-disk-dss    # StorageClass is DSS.
      Table 2 Key parameters
      Mandatory
      Yes
      Region where the cluster is located.
      For details about the value of region, see Regions and Endpoints.
      Yes
      AZ where the disk is created. It must be the same as the AZ planned for the workload.
      For details about the value of zone, see Regions and Endpoints.
      Yes
      Disk type. All letters are in uppercase.
      • SAS: high I/O
      • SSD: ultra-high I/O
      Yes
      ID of the DSS storage pool where the DSS disk resides.
      To obtain a DSS storage pool ID, log in to the Cloud Server Console. In the navigation pane, choose Dedicated Distributed Storage Service > Storage Pools and click the name of the target storage pool. On the resource pool details page, copy the pool ID.
      No
      Mandatory when the DSS disk is encrypted. Enter the encryption key ID selected during disk creation.
      To obtain a key ID, log in to the DEW console, locate the key to be encrypted, and copy the key ID.
      No
      This field is optional. It is supported when the Everest version in the cluster is 2.1.39 or later.
      You can add resource tags to classify resources.
      No
      (Optional) This parameter is available only when the cluster version is v1.23.14-r0, v1.25.9-r0, v1.27.6-r0, v1.28.4-r0, or later, and Everest of v2.4.15 or later is installed in the cluster.
      Enter 1 to 26 characters that cannot start or end with a hyphen (-). Only lowercase letters, digits, and hyphens (-) are allowed.
      storage
      Yes
      Requested PVC capacity, in Gi. The value ranges from 1 to 32768.
      storageClassName
      Yes
    2. Run the following command to create a PVC:
      kubectl apply -f pvc-dss-auto.yaml
    1. Create a file named web-dss-auto.yaml. In this example, the disk is mounted to the /data path.
      apiVersion: apps/v1
      kind: StatefulSet
        namespace: default
        replicas: 1
        selector:
          matchLabels:
            app: web-dss-auto
        serviceName: web-dss-auto   # Headless Service name
        template:
            labels:
              app: web-dss-auto
            containers:
            - name: container-1
              image: nginx:latest
              volumeMounts:
              - name: pvc-disk-dss    # Volume name, which must be the same as the volume name in the volumes field
                mountPath: /data  # Location where the storage volume is mounted
            imagePullSecrets:
              - name: default-secret
            volumes:
              - name: pvc-disk-dss    # Volume name, which can be customized
                persistentVolumeClaim:
                  claimName: pvc-dss-auto    # Name of the created PVC
      apiVersion: v1
      kind: Service
        name: web-dss-auto   # Headless Service name
        namespace: default
        labels:
          app: web-dss-auto
        selector:
          app: web-dss-auto
        clusterIP: None
        ports:
          - name: web-dss-auto
            targetPort: 80
            nodePort: 0
            port: 80
            protocol: TCP
        type: ClusterIP
    2. Run the following command to create a workload to which the DSS volume is mounted:
      kubectl apply -f web-dss-auto.yaml
  1. View the deployed application and DSS volume files.
    1. Run the following command to view the created pod:
      kubectl get pod | grep web-dss-auto
      Expected output:
      web-dss-auto-0                  1/1     Running   0               38s
    2. Run the following command to check whether the DSS volume has been mounted to the /data path:
      kubectl exec web-dss-auto-0 -- df | grep data
      Expected output:
      /dev/sdc              10255636     36888  10202364   0% /data
    3. Run the following command to check the files in the /data path:
      kubectl exec web-dss-auto-0 -- ls /data
      Expected output:
      lost+found
  2. Run the following command to create a file named static in the /data path:
    kubectl exec web-dss-auto-0 --  touch /data/static
    Expected output:
    lost+found
    static
  4. Run the following command to delete the pod named web-dss-auto-0:
    kubectl delete pod web-dss-auto-0
    Expected output:
    pod "web-dss-auto-0" deleted
  5. After the deletion, the StatefulSet controller automatically creates a replica with the same name. Run the following command to check whether the files in the /data path have been modified:
    Expected output:
    lost+found
    static
    The static file is retained, indicating that the data in the DSS volume can be stored persistently.
Related Operations
You can also perform the operations listed in Table 3.
Table 3 Related operations
Operation
Expanding the capacity of DSS storage
Quickly expand the capacity of an attached DSS disk on the CCE console.
  1. Choose Storage in the navigation pane. In the right pane, click the PVCs tab. Click More in the Operation column of the target PVC and select Scale-out.
  2. Enter the capacity to be added and click OK.
Viewing events
View event names, event types, number of occurrences, Kubernetes events, first occurrence time, and last occurrence time of the PVC or PV.
  1. Choose Storage in the navigation pane. In the right pane, click the PVCs or PVs tab.
  2. Click View Events in the Operation column of the target PVC or PV to view events generated within one hour (events are retained for one hour).
Viewing a YAML file
View, copy, or download the YAML file of a PVC or PV.
  2. Click View YAML in the Operation column of the target PVC or PV to view or download the YAML.
