Help Center/
Cloud Container Engine/
User Guide/
User Guide for Standard and Turbo Clusters/
Clusters/
Upgrading a Cluster/
Troubleshooting for Pre-upgrade Check Exceptions/
Node Python Commands
Updated on 2023-10-27 GMT+08:00
Check Items
Check whether the Python commands are available on a node.
Check Method
/usr/bin/python --version echo $?
If the command output is not 0, the check fails.
Solution
Install Python before the upgrade.
Parent topic: Troubleshooting for Pre-upgrade Check Exceptions
