Updated on 2026-09-21 GMT+08:00
Managing Node Labels
You can add different labels to nodes and define different attributes for labels. By using these node labels, you can quickly understand the characteristics of each node.
Node Label Usage Scenario
Node labels are mainly used in the following scenarios:
  • Node management: Node labels are used to classify nodes.
  • Node affinity or anti-affinity for workloads: By adding labels to nodes, you can schedule pods to specific nodes through node affinity or prevent pods from being scheduled to specific nodes through node anti-affinity. For details, see Configuring Node Affinity Scheduling (nodeAffinity).
Inherent Labels of a Node
After a node is created, some fixed labels exist and cannot be deleted. For details about these labels, see Table 1.
Do not manually modify system labels automatically applied to nodes. System values take precedence over conflicting manual changes.
Table 1 Inherent labels of a node
Key
New: topology.kubernetes.io/region
Old: failure-domain.beta.kubernetes.io/region
Region where the node is located
New: topology.kubernetes.io/zone
Old: failure-domain.beta.kubernetes.io/zone
AZ where the node is located
New: node.kubernetes.io/baremetal
Old: failure-domain.beta.kubernetes.io/is-baremetal
Whether it is a bare metal node
false indicates that the node is not a bare metal node.
node.kubernetes.io/container-engine
Container runtime
Example: docker or containerd
node.kubernetes.io/instance-type
beta.kubernetes.io/instance-type
Node specifications
kubernetes.io/arch
beta.kubernetes.io/arch
Node processor architecture
kubernetes.io/hostname
Node name
kubernetes.io/os
beta.kubernetes.io/os
Node OS type
node.kubernetes.io/subnetid
ID of the subnet where the node is located
os.architecture
For example, amd64 indicates a AMD64-bit processor.
os.name
Node OS name
os.version
Node OS kernel version
accelerator/huawei-npu
NPU node label
accelerator
GPU node label
cce.cloud.com/cce-nodepool
The dedicated label of a node in a node pool, indicating the node pool name
cce.cloud.com/cce-nodepool-id
The dedicated label of a node in a node pool, indicating the node pool ID
node.cce.io/billing-mode
Node billing mode
node.cce.io/eni-network-mode
The type of network interfaces used by pods on a node. This label is available only for nodes in CCE Turbo clusters.
Adding, Updating, or Deleting a Node Label
  2. In the navigation pane, choose Nodes. On the displayed page, click the Nodes tab, select the target node and click Manage Labels and Taints above the node list.
  3. In the displayed window, click Add Operation under Batch Operation, and then choose Add/Update or Delete.
    Enter the key and value of the label to be added, updated, or deleted, and click OK.
    For example, the key is deploy_qa and the value is true, indicating that the node is used to deploy the QA (test) environment.
    Figure 1 Adding a node label
  4. Check the added label in node data.
Helpful Links
You can schedule workloads based on node labels. For details, see Overview.
