Alarm Center FAQ
How Do I Stop Receiving Alarm Notifications?
Delete the subscribed endpoint on the Default Contact Groups tab (Alarm Center > Default Contact Groups).
Why Are Alarms Still Sent After They Are Cleared?
When an alarm is cleared, only the statistics on the Alarm Rules tab are cleared. If the alarm continuously reaches the threshold or abnormal events occur continuously, the alarm is still generated.
Can the Contact Group of Alarm Center Be a Third-Party System?
Third-party systems, such as DingTalk and Lark, cannot be created on the Default Contact Groups tab of Alarm Center. You need to enable them on the SMN console. For details, see SMN documentation
What Is the Strategy for Clearing Alarms Reported by CCE to AOM?
If the Cloud Native Log Collection add-on is installed in the cluster, alarms are cleared automatically within 10 minutes by default.
If the Cloud Native Log Collection add-on is not installed, AOM clears the alarms by default after 15 days.
