Updated on 2026-09-21 GMT+08:00
Enabling Cost Insights
Cost Insights uses in-house cost profile algorithms to split costs by department, cluster, namespace, or application, based on your bills and cluster resource usages. Cost Insights helps cost management personnel analyze cluster costs and resource usages and identify resource waste for cost optimization.
This section describes how to enable Cost Insights.
  • After Cost Insights is enabled, Cloud Native Cluster Monitoring will be installed automatically, and metrics will be reported to the selected AOM instance. Basic metrics are free, but custom metrics are charged by AOM. For details, see Pricing Details. Cost Insights only uses basic metrics.
  • After Cost Insights is enabled, an OBS bucket will be created in AP-Singapore to store your bills subscribed from the billing center. Then, you will be billed for the OBS storage. For details, see Pricing Details.
You have an account in the admin user group to delegate CCE and its dependent services.
When you access Cloud Native Cost Governance, the Authorize dialog box is automatically displayed. After you click Authorize, CCE automatically completes the authorization. For details about permission types, see Table 1.
Table 1 Resource permissions
Assigned To
Permission
CCE
IAM ReadOnlyAccess
IAM users need to access Cloud Native Cost Governance.
CCE
Tenant Guest
Cloud Native Cost Governance checks the configurations of global resources (such as OBS and DNS) associated with a cluster.
CCE
CCE Administrator
Cloud Native Cost Governance needs to access CCE to obtain information about clusters, nodes, and workloads for health checks.
CCE
AOM Administrator
Cloud Native Cost Governance needs to access AOM to obtain metrics.
CCE
OBS Administrator
Cloud Native Cost Governance needs to access the OBS bucket where your bills are stored.
CCE
CBC Finance
Cloud Native Cost Governance needs to periodically store your bills in the OBS bucket for later use.
AOM
DMS UserAccess
AOM retrieves data from DMS.
AOM
ECS CommonOperations
AOM obtains system metrics and logs from the UniAgent and ICAgent installed on an ECS.
AOM
CES ReadOnlyAccess
AOM synchronizes metrics from Cloud Eye.
AOM
CCE FullAccess
AOM synchronizes container metrics from CCE.
AOM
RMS ReadOnlyAccess
AOM CMDB manages cloud service instance data.
AOM
ECS ReadOnlyAccess
AOM
LTS FullAccess
AOM obtains logs from LTS.
AOM
CCI FullAccess
AOM synchronizes container metrics from CCI.
  • Cloud Native Cost Governance is only available in clusters v1.17 or later.
  • Before using Cloud Native Cost Governance, you need to use an account in the admin user group to delegate CCE and its dependent services. After the authorization is complete, users with the CCE Administrator role or CCE FullAccess permission can perform all operations on Cloud Native Cost Governance.
Enabling Cost Insights for a Region
  1. Log in to the CCE console.
  2. Log in to the CCE console. In the navigation pane, choose Cloud Native Cost Governance.
    Figure 1 Cloud Native Cost Governance
  3. Click Enable, select clusters that require Cost Insights, and click Connect Now.
    The system will automatically perform the following operations. After 3 to 5 minutes, the Cost Insights page is displayed.
    1. Install Cloud Native Cluster Monitoring to provide basic metrics for Cost Insights.
    2. Activate cost tags. Cluster tags will be added to the bills exported from the billing center. The Cost Insights background classifies the bills by cluster. After this step is complete, the CCE-Cluster-ID and CCE-Dynamic-Provisioning-Node tags are activated on the cost tag page of Cloud Native Cost Governance.
    3. Create an OBS bucket named cce-cost-{region}-{domain_id} for the default tenant to store bills exported from the billing center.
    4. Subscribe to bills. After bills are subscribed, the billing center will periodically push bills to the OBS bucket for cost insights.
    Figure 2 Enabling Cost Insights for clusters
  4. (Optional) Click Create Department.
    Figure 3 Creating departments
    1. Customize departments based on the service requirements and associate them with clusters or namespaces as follows:
      • Department Name: Use the actual name of a business department.
      • Department Scope: Select the cluster or namespace for the business department. In the following example, department1 and department2 are configured by namespace.
      Figure 4 Customizing departments
    2. Allocate shared costs in a cluster to departments. Management costs and unallocated costs in the default cluster are evenly allocated among departments. The allocation ratio can be changed.
      Figure 5 Allocating shared costs
    3. Manage costs by department. After departments are created, click Submit. The configurations are displayed on the department management page. The following shows example department configurations.
      Figure 6 Department configurations
Enabling Cost Insights for a Cluster
  2. In the navigation pane, choose Cloud Native Cost Governance > Cost Insights.
  3. Click Enable. The system automatically installs Cloud Native Cluster Monitoring, activates cost tags, creates an OBS bucket for the default tenant, and subscribes to bills. Wait for 3 to 5 minutes. The Cost Insights page is displayed.
    Figure 7 Enabling Cost Insights
