Help Center/ Cloud Container Engine/ User Guide/ Clusters/ Managing Clusters/ Changing the Default Node Security Group
Updated on 2026-09-21 GMT+08:00
When creating a cluster, you can specify a node security group to centrally manage network security policies. For a created cluster, you can change its default node security group.
  1. Log in to the CCE console. In the navigation pane, choose Clusters.
  2. Click the cluster name to access the Overview page.
  3. In the Networking Configuration area, click Edit next to the Default Node Security Group.
    Figure 1 Default node security group
  4. Select an existing security group, confirm that the security group rules meet the cluster requirements, and click OK.
    • Ensure that correct port rules are configured for the selected security group. Otherwise, the nodes cannot be created. The port rules that a security group must comply with vary with the cluster type. For details, see How Can I Configure a Security Group Rule in a Cluster?
    • The new security group takes effect only for newly created or managed nodes. For existing nodes, modify the security group rules and reset the nodes in real time. The original security group is still used. For details about how to modify the security group settings of the existing nodes in batches, see How Do I Change the Security Group of Nodes in a Cluster in Batches?
    Figure 2 Editing default node security group
Helpful Links
Modifying cluster or node settings can affect services due to high-risk operations. To avoid potential risks, see High-Risk Operations.
