Help Center>
Cloud Container Engine>
User Guide (Kuala Lumpur Region)>
Clusters>
Upgrading a Cluster>
Troubleshooting for Pre-upgrade Check Exceptions>
Node ID File
Updated on 2024-01-24 GMT+08:00
Node ID File
Check Item
Check the ID file format.
Solution
- On the Nodes page of the CCE console, click the name of the abnormal node to go to the ECS page.
- Copy the node ID and save it to the local host.
- Log in to the abnormal node and back up files.
cp /var/lib/cloud/data/instance-id /tmp/instance-id cp /var/paas/conf/server.conf /tmp/server.conf
- Log in to the abnormal node and write the obtained node ID to the file.
echo "Node ID" > /var/lib/cloud/data/instance-id echo "Node ID" > /var/paas/conf/server.conf
Parent topic: Troubleshooting for Pre-upgrade Check Exceptions
