Help Center/ Cloud Container Engine/ User Guide/ Storage/ SFS/ Using an Existing SFS File System Through a Static PV
Updated on 2026-09-21 GMT+08:00
SFS is a type of network-attached storage (NAS) that provides shared, scalable, and high-performance file storage. It applies to large-capacity expansion and cost-sensitive services. This section describes how to use an existing SFS file system to statically create PVs and PVCs for data persistence and sharing in workloads.
  • You have created a cluster and installed the CCE Container Storage (Everest) add-on in the cluster.
  • To create a cluster using commands, ensure kubectl is used. For details, see Accessing a Cluster Using kubectl.
  • You have created an SFS file system that is in the same VPC as the cluster.
  • Before using a general purpose file system (SFS 3.0 Capacity-Oriented) for storage, ensure a VPC endpoint has been created in the VPC where the cluster is located for the cluster to access the file system. For details, see Creating a VPC Endpoint.
  • Multiple PVs can use the same SFS or SFS Turbo file system with the following restrictions:
    • If a pod mounts an SFS or SFS Turbo volume used by multiple PVCs/PVs, and the PVs have identical volumeHandle values, the pod may fail to start. To avoid this issue, do not mount the same SFS or SFS Turbo file system to the same pod.
    • The persistentVolumeReclaimPolicy parameter in the PVs must be set to Retain. Otherwise, when a PV is deleted, the associated underlying volume may be deleted. In this case, other PVs associated with the underlying volume malfunction.
    • When the underlying volume is repeatedly used, enable isolation and protection for ReadWriteMany at the application layer to prevent data overwriting and loss.
  • If a general purpose file system (SFS 3.0 Capacity-Oriented) is used, Everest v2.0.9 or later must be installed in the cluster.
  • If a general purpose file system (SFS 3.0 Capacity-Oriented) is used, the owner group and permission of the mount point cannot be modified. The default owner of the mount point is user root.
  • If a general purpose file system (SFS 3.0 Capacity-Oriented) is used, there may be latency during the creation or deletion of PVCs and PVs. The billing duration is determined by the time when the resource is created or deleted on the SFS console.
  • If the CCE Container Storage (Everest) version is earlier than 2.4.105 or the target region is CN South-Guangzhou, and the Delete reclaim policy is used for the general purpose file system (SFS 3.0 Capacity-Oriented), you must delete files from the file system. Otherwise, deleting the PVs and PVCs may fail. If the add-on version is 2.4.105 or later and the region is not CN South-Guangzhou, this restriction does not apply.
Using an Existing SFS File System on the Console
  2. Statically create a PVC and PV.
    1. Choose Storage in the navigation pane. In the right pane, click the PVCs tab. Click Create PVC in the upper right corner. On the slide-out panel, configure PVC parameters.
      PVC Type
      In this example, select SFS.
      PVC Name
      Enter the PVC name, which must be unique in a namespace.
      Creation Method
      • If the underlying storage is available, create a PV or use an existing PV to statically create a PVC.
      • If no underlying storage is available, select Dynamically provision. For details, see Using an SFS File System Through a Dynamic PV.
      In this example, select Create new to create both a PV and PVC on the console.
      PVa
      Select an existing PV in the cluster. For details about how to create a PV, see "Creating a storage volume" in Related Operations.
      You do not need to specify this parameter in this example.
      SFSb
      Click Select SFS. On the displayed page, select the SFS file system that meets your requirements and click OK.
      Only general purpose file systems (SFS 3.0 Capacity-Oriented) are supported.
      Subdirectoryb
      Determine whether to use subdirectories to create PVs. If this parameter is set to Yes, enter the absolute path of the subdirectory, for example, /a/b.
      • For Everest v2.4.176 and later, CCE will automatically create the subdirectory if it does not already exist, provided that secure containers are not in use.
      • In other cases, ensure that the subdirectory exists and is accessible.
      PV Nameb
      Enter the PV name, which must be unique in the same cluster.
      Access Modeb
      SFS volumes support only ReadWriteMany, indicating that a storage volume can be mounted to multiple nodes in read/write mode. For details, see Volume Access Modes.
      Reclaim Policyb
      You can select Delete or Retain to specify the reclaim policy of the underlying storage when the PVC is deleted. For details, see PV Reclaim Policy.
      If multiple PVs use the same underlying storage volume, use Retain to prevent the underlying volume from being deleted when a PV is deleted.
      Subdirectory Reclaim Policyb
      Determine whether to retain subdirectories when a PVC is deleted. This parameter must be used with PV Reclaim Policy and can be configured when PVs are created using subdirectories and PV Reclaim Policy is set to Delete.
      • Retain: When a PVC is deleted, the PV is deleted, but its associated subdirectories are retained.
      • Delete: When a PVC is deleted, the PV and its associated subdirectories are also deleted.
      Mount Optionsb
      Enter the mounting parameter key-value pairs. For details, see Configuring SFS Volume Mount Options.
      a: The parameter is available when Creation Method is set to Use existing.
      b: The parameter is available when Creation Method is set to Create new.
    2. Click Create to create a PVC and a PV.
      You can choose Storage in the navigation pane and view the created PVC and PV on the PVCs and PVs tabs, respectively.
  3. Create an application.
    1. Choose Workloads in the navigation pane. In the right pane, click the Deployments tab.
    2. Click Create Workload in the upper right corner. On the displayed page, click Data Storage in the Container Information area under Container Settings and choose Add Volume > PVC.
      Mount and use storage volumes. For details about the parameters, see Table 1. For other parameters, see Workloads.
      Table 1 Mounting a storage volume
      PVC
      Select an existing SFS volume.
      Mount Path
      Enter a mount path, for example, /tmp.
      This parameter specifies a container path to which a data volume will be mounted. Do not mount the volume to a system directory such as / or /var/run. This may lead to container errors. Mount the volume to an empty directory. If the directory is not empty, ensure that there are no files that affect container startup. Otherwise, the files will be replaced, leading to container startup failures or workload creation failures.
      NOTICE:
      If a volume is mounted to a high-risk directory, use an account with minimum permissions to start the container. Otherwise, high-risk files on the host may be damaged.
      Subpath
      Enter the subpath of the storage volume and mount a path in the storage volume to the container. In this way, different folders of the same storage volume can be used in a single pod. tmp, for example, indicates that data in the mount path of the container is stored in the tmp folder of the storage volume. If this parameter is left blank, the root path will be used by default.
      Permission
      • Read-only: You can only read the data in the mounted volumes.
      • Read-write: You can modify the data volumes mounted to the path. Newly written data will not be migrated if the container is migrated, which may cause data loss.
      In this example, the disk is mounted to the /data path of the container. The container data generated in this path is stored in the SFS file system.
    3. After the configuration, click Create Workload.
      After the workload is created, the data in the container mount directory will be persistently stored. Verify the storage by referring to Verifying Data Persistence and Sharing.
Using an Existing SFS File System Through kubectl
You can select a mode that meets the requirements of your service.
  1. Use kubectl to access the cluster.
  2. Create a PV.
    1. Create the pv-sfs.yaml file.
      Example:
      apiVersion: v1
      kind: PersistentVolume
        annotations:
          pv.kubernetes.io/provisioned-by: everest-csi-provisioner
          everest.io/reclaim-policy: retain-volume-only      # (Optional) The underlying volume is retained when the PV is deleted.
        name: pv-sfs    # PV name
        accessModes:
        - ReadWriteMany      # Access mode. The value must be ReadWriteMany for SFS volumes.
        capacity:
          storage: 1Gi       # Storage capacity. This parameter is only for verification. It must not be empty or 0, but the specified size will not take effect.
        csi:
          driver: nas.csi.everest.io    # Dependent storage driver for the mounting
          fsType: nfs
          volumeHandle: <sfs30_name>   # Enter the file system name when a general purpose file system (SFS 3.0 Capacity-Oriented) is used.
          volumeAttributes:
            everest.io/share-export-location: <your_location>  # Shared path of the SFS volume
            storage.kubernetes.io/csiProvisionerIdentity: everest-csi-provisioner
            everest.io/sfs-version: sfs3.0       # A general purpose file system (SFS 3.0 Capacity-Oriented) is used.
        persistentVolumeReclaimPolicy: Retain    # Reclaim policy
        storageClassName: csi-sfs               # StorageClass name. csi-sfs indicates a general purpose file system (SFS 3.0 Capacity-Oriented)
        mountOptions: []                         # Mount options
      Table 2 Key parameters
      Mandatory
      No
      Only retain-volume-only is supported.
      This parameter is valid only when the Everest version is 1.2.9 or later and the reclaim policy is Delete. If the reclaim policy is Delete and the current value is retain-volume-only, the associated PV is deleted while the underlying storage volume is retained, when a PVC is deleted.
      volumeHandle
      Yes
      If a general purpose file system (SFS 3.0 Capacity-Oriented) is used, enter the name of the file system.
      Yes
      Shared path of a general purpose file system (SFS 3.0 Capacity-Oriented).
      A shared path is in the following format:
      {your_sfs30_name}.sfs3.{region}.myhuaweicloud.com:/{your_sfs30_name}
      mountOptions
      No
      Mount options.
      If not specified, the following configurations are used by default. For details, see Configuring SFS Volume Mount Options.
      mountOptions:
      - vers=3
      - timeo=600
      - nolock
      - hard
      Yes
      A reclaim policy is supported when the cluster version is 1.19.10 or later and the Everest version is 1.2.9 or later.
      The Delete and Retain reclaim policies are supported. For details, see PV Reclaim Policy. If multiple PVs use the same SFS volume, use Retain to prevent the underlying volume from being deleted when a PV is deleted.
      Retain: When a PVC is deleted, the PV and the associated underlying storage resources are retained. The PV changes to the Released state and cannot be bound to another PVC. If you want to continue using the underlying storage resources, delete the PV first. Then, create a new PV and PVC and associate them with the underlying storage resources.
      Delete: When a PVC is deleted, its associated underlying storage resources are deleted and the PV resources are removed. Exercise caution if you select this option.
      storage
      Yes
      Requested capacity in the PVC, in Gi.
      For SFS, this parameter is only for verification. It must not be empty or 0, and its value is fixed at 1. Any value you set will not take effect.
      storageClassName
      Yes
      StorageClass name. Enter csi-sfs, indicating that a general purpose file system (SFS 3.0 Capacity-Oriented) is used.
    2. Run the following command to create a PV:
      kubectl apply -f pv-sfs.yaml
  3. Create a PVC.
    1. Create the pvc-sfs.yaml file.
      apiVersion: v1
      kind: PersistentVolumeClaim
        namespace: default
        annotations:
          volume.beta.kubernetes.io/storage-provisioner: everest-csi-provisioner
        accessModes:
        - ReadWriteMany               # The value must be ReadWriteMany for SFS.
        resources:
          requests:
            storage: 1Gi               # SFS volume capacity
         storageClassName: csi-sfs     # StorageClass name, which must be the same as that of the PV
        volumeName: pv-sfs    # PV name
      Table 3 Key parameters
      Mandatory
      storage
      Yes
      The value must be the same as the storage size of the existing PV.
      storageClassName
      Yes
      StorageClass name. Enter csi-sfs, indicating that a general purpose file system (SFS 3.0 Capacity-Oriented) is used. The value of this parameter must be the same as the PV StorageClass specified in 1.
      volumeName
      Yes
      PV name, which must be the same as the PV name in 1.
    2. Run the following command to create a PVC:
      kubectl apply -f pvc-sfs.yaml
  4. Create an application.
    1. Create a file named web-demo.yaml. In this example, the SFS volume is mounted to the /data path.
      apiVersion: apps/v1
      kind: Deployment
        namespace: default
        replicas: 2
        selector:
          matchLabels:
            app: web-demo
        template:
            labels:
              app: web-demo
            containers:
            - name: container-1
              image: nginx:latest
              volumeMounts:
              - name: pvc-sfs-volume    # Volume name, which must be the same as the volume name in the volumes field
                mountPath: /data  # Location where the storage volume is mounted
            imagePullSecrets:
              - name: default-secret
            volumes:
              - name: pvc-sfs-volume    # Volume name, which is user-defined
                persistentVolumeClaim:
                  claimName: pvc-sfs    # Name of the created PVC
    2. Run the following command to create a workload to which the SFS volume is mounted:
      kubectl apply -f web-demo.yaml
  2. Create a PV.
      Example:
      apiVersion: v1
        annotations:
        accessModes:
        capacity:
        csi:
          fsType: nfs
          volumeHandle: pv-sfs    # Enter the PV name when using a subdirectory.
          volumeAttributes:
            everest.io/csi.volume-as: absolute-path   # An SFS subdirectory is used.
            everest.io/csi.path: /a  # Enter the absolute path of the subdirectory.
            everest.io/csi.sfs30-name: <sfs_name>     # SFS instance name. This parameter is available only when subdirectories are used.
            everest.io/csi.reclaim-policy: retain-volume-only    # When a PVC is deleted, the PV will be deleted, but the subdirectories associated with the PV will be retained. This parameter is available only when subdirectories are used and the reclaim policy is Delete.
      Table 4 Key parameters
      Mandatory
      volumeHandle
      Yes
      PV name when an SFS subdirectory is used.
      Yes
      {your_sfs30_name}.sfs3.{region}.myhuaweicloud.com:/{your_sfs30_name}/{absolute_path}
      mountOptions
      No
      Mount options.
      mountOptions:
      - vers=3
      - timeo=600
      - nolock
      - hard
      Yes
      No
      The value is fixed at absolute-path, indicating that a dynamically created SFS subdirectory is used.
      Ensure Everest v2.4.41 or later has been installed in the cluster.
      everest.io/csi.path
      No
      An absolute path of the subdirectory.
      No
      An SFS instance name. This parameter is used only when an SFS subdirectory is dynamically created.
      No
      Whether to retain subdirectories when deleting a PVC. Use this parameter only when creating a dynamic SFS subdirectory. This parameter must be used with PV Reclaim Policy. This parameter is available only when the PV reclaim policy is Delete. Options:
      • retain-volume-only: When a PVC is deleted, the PV is deleted, but its associated subdirectories are retained.
      • delete: When a PVC is deleted, the PV and its associated subdirectories are also deleted.
        When a subdirectory is deleted, only the absolute path of the subdirectory specified in the PVC is deleted. The parent directory is retained.
      storage
      Yes
      storageClassName
      Yes
  3. Create a PVC.
      apiVersion: v1
        namespace: default
        annotations:
          everest.io/csi.volume-as: absolute-path # (Optional) An SFS subdirectory is used.
        accessModes:
        resources:
          requests:
      Table 5 Key parameters
      Mandatory
      Yes
      everest.io/csi.path
      Yes
      Yes
      Yes
      storage
      Yes
      storageClassName
      Yes
      volumeName
      Yes
      apiVersion: apps/v1
      kind: Deployment
        namespace: default
        replicas: 2
        selector:
          matchLabels:
            app: web-demo
        template:
            labels:
              app: web-demo
            containers:
            - name: container-1
              image: nginx:latest
              volumeMounts:
            imagePullSecrets:
            volumes:
  2. Create a PV.
      Example:
      apiVersion: v1
        annotations:
        accessModes:
        capacity:
        csi:
          fsType: nfs
          volumeHandle: <your_volume_id>   # SFS Capacity-Oriented volume ID
          volumeAttributes:
        storageClassName: csi-nas               # StorageClass name. csi-nas indicates that SFS Capacity-Oriented is used.
      Table 6 Key parameters
      Mandatory
      No
      volumeHandle
      Yes
      Volume ID if SFS Capacity-Oriented is used.
      Log in to the CCE console, choose Service List > Storage > Scalable File Service, and select SFS Capacity-Oriented. In the list, click the name of the target SFS file system. On the details page, copy the content following ID.
      Yes
      Shared path of the file system.
      On the CCE console, choose Service List > Storage > Scalable File Service. In the navigation pane, choose File Systems. You can obtain the shared path of the file system.
      mountOptions
      No
      Mount options.
      mountOptions:
      - vers=3
      - timeo=600
      - nolock
      - hard
      Yes
      storage
      Yes
      Requested PVC capacity, in Gi. The value must be the same as that of the existing SFS Capacity-Oriented storage.
      storageClassName
      Yes
      StorageClass name csi-nas, indicating that SFS 1.0 Capacity-Oriented is used for storage.
  3. Create a PVC.
      apiVersion: v1
        namespace: default
        annotations:
        accessModes:
        resources:
          requests:
        storageClassName: csi-nas     # StorageClass name, which must be the same as that of the PV
      Table 7 Key parameters
      Mandatory
      storage
      Yes
      storageClassName
      Yes
      StorageClass name csi-nas, which must be the same as the StorageClass of the PV specified in 1. This indicates that SFS 1.0 Capacity-Oriented is used for storage.
      volumeName
      Yes
      apiVersion: apps/v1
      kind: Deployment
        namespace: default
        replicas: 2
        selector:
          matchLabels:
            app: web-demo
        template:
            labels:
              app: web-demo
            containers:
            - name: container-1
              image: nginx:latest
              volumeMounts:
            imagePullSecrets:
            volumes:
  1. View the deployed application and files.
    1. Run the following command to view the created pod:
      kubectl get pod -n <namespace> | grep web-demo
      Expected output:
      web-demo-846b489584-mjhm9   1/1     Running   0             46s
      web-demo-846b489584-wvv5s   1/1     Running   0             46s
    2. Run the following commands in sequence to check the files in the /data path of the pods:
      kubectl exec -n <namespace> web-demo-846b489584-mjhm9 -- ls /data
      kubectl exec -n <namespace> web-demo-846b489584-wvv5s -- ls /data
      If no result is returned for both pods, no file exists in the /data path.
  2. Run the following command to create a file named static in the /data path:
    kubectl exec -n <namespace> web-demo-846b489584-mjhm9 --  touch /data/static
  3. Run the following command to check the files in the /data path:
    Expected output:
    static
  4. Verify data persistence.
    1. Run the following command to delete the pod named web-demo-846b489584-mjhm9:
      kubectl delete pod -n <namespace> web-demo-846b489584-mjhm9
      Expected output:
      pod "web-demo-846b489584-mjhm9" deleted
      After the deletion, the Deployment controller automatically creates a replica.
    2. Run the following command to view the created pod:
      The expected output is as follows, in which web-demo-846b489584-d4d4j is the newly created pod:
      web-demo-846b489584-d4d4j   1/1     Running   0             110s
      web-demo-846b489584-wvv5s    1/1     Running   0             7m50s
    3. Run the following command to check whether the files in the /data path of the new pod have been modified:
      kubectl exec -n <namespace> web-demo-846b489584-d4d4j -- ls /data
      Expected output:
      static
      The static file is retained, indicating that the data can be stored persistently.
  5. Verify data sharing.
      Expected output:
      web-demo-846b489584-d4d4j   1/1     Running   0             7m
      web-demo-846b489584-wvv5s   1/1     Running   0             13m
    2. Run the command below to create a file named share in the /data path of either pod. In this example, select the pod named web-demo-846b489584-d4d4j.
      kubectl exec -n <namespace> web-demo-846b489584-d4d4j --  touch /data/share
      Check the files in the /data path of the pod.
      Expected output:
      share
      static
    3. Check whether the share file exists in the /data path of another pod (web-demo-846b489584-wvv5s) as well to verify data sharing.
      Expected output:
      share
      static
      After you create a file in the /data path of a pod, if the file is also created in the /data path of the other pod, the two pods share the same volume.
Related Operations
You can also perform the operations listed in Table 8.
Table 8 Related operations
Operation
Creating a storage volume (PV)
Create a PV on the CCE console.
  1. Choose Storage in the navigation pane. In the right pane, click the PVs tab. Click Create PV in the upper right corner. On the slide-out panel, configure parameters.
    • Volume Type: Select SFS.
    • SFS: Click Select SFS. On the displayed page, select the SFS file system that meets your requirements and click OK.
    • Subdirectory: Determine whether to use subdirectories to create PVs. To use this function, enter the absolute path of a subdirectory (for example, /a/b). Ensure that the subdirectory exists and is accessible.
    • PV Name: Enter the PV name, which must be unique in a cluster.
    • Access Mode: SFS volumes support only ReadWriteMany, indicating that a storage volume can be mounted to multiple nodes in read/write mode. For details, see Volume Access Modes.
    • Reclaim Policy: Delete or Retain is supported. For details, see PV Reclaim Policy.
    • Subdirectory Reclaim Policy: Determine whether to retain subdirectories when a PVC is deleted. This parameter must be used with PV Reclaim Policy and can be configured when PVs are created using subdirectories and PV Reclaim Policy is set to Delete.
    • Mount Options: Enter the mounting parameter key-value pairs. For details, see Configuring SFS Volume Mount Options.
  2. Click Create.
Viewing events
View event names, event types, number of occurrences, Kubernetes events, first occurrence time, and last occurrence time of the PVC or PV.
  1. Choose Storage in the navigation pane. In the right pane, click the PVCs or PVs tab.
  2. Locate the target PVC or PV and click View Events in the Operation column to view events generated within one hour (events are retained for one hour).
Viewing a YAML file
View, copy, or download the YAML file of a PVC or PV.
  2. Locate the target PVC or PV and click View YAML in the Operation column to view or download the YAML.
Editing Reclaim Policy
Modify the reclaim policy of a PV.
  2. Locate the target PV and choose More > Edit Reclaim Policy in the Operation column.
Synchronizing PVC capacity (supported only for PVCs created from non-subdirectories of SFS Capacity-Oriented file systems)
When the underlying storage outgrows the PVC, resize the PVC capacity on the CCE console to match the new size.
  2. Locate the target PVC and click Synchronize in the Capacity column to make the PVC capacity consistent with the underlying storage capacity.
    Synchronize is only displayed when the underlying storage capacity is greater than the PVC capacity.
Helpful Links
If a storage volume fails to mount to a workload, rectify the fault by referring to What Should I Do If a Storage Volume Cannot Be Mounted or the Mounting Times Out?
