Help Center/ Cloud Container Engine/ User Guide/ Node Pools/ Managing Node Pools/ Synchronizing Node Pools
Updated on 2026-08-13 GMT+08:00
After the settings of a node pool are updated, some settings cannot be automatically synchronized for existing nodes. You can manually synchronize the settings for these nodes.
- Do not delete or reset nodes during batch synchronization. Otherwise, the synchronization of node pool configuration may fail.
- This operation involves resetting nodes. Workloads running on a node may be interrupted due to standalone deployment or insufficient schedulable resources. Evaluate the upgrade risks and perform the upgrade during off-peak hours. Alternatively, specify a disruption budget for your key applications to ensure the availability of these applications during the upgrade.
- During configuration synchronization for existing nodes, the nodes will be reset, and the system disks and data disks will be cleared. Back up important data before the synchronization.
- Only some node pool parameters can be synchronized by resetting nodes. For details, see Updating a Node Pool.
- If a new OS patch is available in the environment, synchronize the node pool to update the OS.
- Log in to the CCE console.
- Click the cluster name to access the cluster console. Choose Nodes in the navigation pane. In the right pane, click the Nodes tab.
- Find the node marked with Node pool updated in the node pool.
- Move the cursor to Node pool updated. The Reset button is displayed. You can then determine whether to reset the node immediately.
- Click the cluster name to access the cluster console. Choose Nodes in the navigation pane. In the right pane, click the Node Pools tab.
- Choose More > Synchronize in the Operation column of the target node pool.
- In the Batch Synchronize window, configure parameters.
- OS: shows the image of the target version. You do not need to configure this parameter.
- Synchronization Type: Reset node is supported.
- Max. Nodes for Batch Synchronization: the maximum number of nodes that can be synchronized simultaneously. Nodes will be unavailable during synchronization when the nodes are reset. Properly configure this parameter to prevent pod scheduling failures caused by too many unavailable nodes in the cluster.
- Select the target nodes and click OK to start the synchronization.
Operations on the Cluster Upgrade Page
- Click the cluster name to access the cluster console. Choose Cluster Upgrade in the navigation pane. In the right pane, click the Node Pool Upgrade tab.
- Click Synchronize in the Operation column of the target node pool.
- Click OK.
0
3
4
5
6
7
8
9
10
Very dissatisfiedVery satisfied
