Private IPv4 Addresses of Load Balancers
Check Items
Check whether the load balancer associated with a Service is allocated with a private IPv4 address.
Solution 1: Delete the Service that is associated with a load balancer without a private IPv4 address.
Solution 2: Bind a private IP address to the load balancer without a private IPv4 address. The procedure is as follows:
- Obtain the load balancer associated with the target Service.
- Method 1: Obtain the load balancer ID based on the pre-upgrade check log. Go to the ELB console and filter the load balancer by load balancer ID.
elbs (ids: [*****]) without ipv4 private ip, please bind private ip to these elbs and try again
- Method 2: Log in to the CCE console and click the cluster name to access the cluster console. Then, choose Services & Ingresses in the navigation pane. In the right pane, click the name of the target load balancer to go to the ELB page.
- Check whether the load balancer has a private IPv4 address.
- Bind a private IP address to the load balancer without a private IPv4 address.
- Log in to the ELB console and click the name of the target load balancer.
- On the Summary tab, click Bind next to Private IPv4 address.
- Configure the subnet and IPv4 address, and click OK.
