Binding a Security Group to a Pod Using an Annotation
Application Scenarios
In Cloud Native Network 2.0, pods use ENIs or sub-ENIs of the VPC. You can configure a security group for a pod using a pod's annotation.
Configure a security group in either of the following cases:
- To newly bind a security group to a pod, use annotation yangtse.io/security-group-ids.
 - To bind more security groups to a pod, use annotation yangtse.io/additional-security-group-ids.
   The priority of the security group bound to a pod using annotation yangtse.io/security-group-ids is higher than those of the security groups in the security group policy (SecurityGroup) and cluster container network configuration (NetworkAttachmentDefinition).
- v1.23: v1.23.16-r0 or later
 - v1.25: v1.25.11-r0 or later
 - v1.27: v1.27.8-r0 or later
 - v1.28: v1.28.6-r0 or later
 - v1.29: v1.29.2-r0 or later
 - Versions later than v1.29
Using kubectl
- Create a workload with a security group configured. The security group bound to the pod is subject to the one configured using an annotation.
     If the pod has been bound to a security group, the configuration will be overwritten.
apiVersion: apps/v1 kind: Deployment metadata: name: nginx spec: replicas: 3 selector: matchLabels: app: nginx template: metadata: labels: app: nginx annotations: yangtse.io/security-group-ids: ***** # Security group ID. Use commas (,) to separate multiple security groups. spec: containers: - name: container-0 image: nginx:alpine resources: limits: cpu: 100m memory: 200Mi requests: cpu: 100m memory: 200Mi imagePullSecrets: - name: default-secret - Add an additional security group for the workload.
apiVersion: apps/v1 kind: Deployment metadata: name: nginx spec: replicas: 3 selector: matchLabels: app: nginx template: metadata: labels: app: nginx annotations: yangtse.io/additional-security-group-ids: ***** # Security group ID. Use commas (,) to separate multiple security groups. spec: containers: - name: container-0 image: nginx:alpine resources: limits: cpu: 100m memory: 200Mi requests: cpu: 100m memory: 200Mi imagePullSecrets: - name: default-secret
        Annotation  |
        Description  |
        Value Range  |
        yangtse.io/security-group-ids  |
        Configure a security group for a pod. The security group of the pod is subject to the one configured using this annotation. If the pod already has a security group, the original security group will be overwritten.  |
        Security group IDs. A maximum of five IDs are allowed. Use commas (,) to separate multiple security groups.  |
        yangtse.io/additional-security-group-ids  |
        Add more security groups to a pod.  |
        Security group IDs. The total number of newly added security group IDs and existing security group IDs cannot exceed 5. Use commas (,) to separate multiple security groups.  |
