Updated on 2026-09-21 GMT+08:00
Configuring HTTP/2 for LoadBalancer Services
Services can be exposed via HTTP/2. By default, HTTP/1.x is used between clients and load balancers. HTTP/2 can improve access performance between clients and load balancers, but HTTP/1.x is still used between load balancers and backend servers.
  • An HTTPS-compliant load balancer supports HTTP/2.
  • After HTTP/2 is configured, if you delete the advanced configuration for enabling HTTP/2 on the CCE console or delete the target annotation from the YAML file, the configuration on the ELB will be retained.
  • A Kubernetes cluster is available and the cluster version meets the following requirements:
    • v1.23: v1.23.13-r0 or later
    • v1.25: v1.25.8-r0 or later
    • v1.27: v1.27.5-r0 or later
    • v1.28: v1.28.3-r0 or later
    • Other clusters of later versions
Step 1: Deploy a Sample Application
This section uses a Nginx Deployment as an example.
  2. In the navigation pane, choose Workloads. In the upper right corner, click Create Workload.
  3. In the Basic Info area, enter the workload name. In this example, the workload name is nginx. Retain the default settings for other parameters.
  4. In Container Information under Container Settings, specify the image name and tag. Retain the default settings for other parameters.
    Example
    Image Name
    Click Select Image. In the displayed dialog box, click Open Source Images under SWR Shared Edition, search for nginx, select it, and click OK.
    Image Tag
    Select the latest image tag.
  5. Retain the default settings for other parameters and click Create Workload.
Step 2: Create a LoadBalancer Service and Configure HTTP/2
Use one of the following methods.
In this section, the sample certificate is cert-test. Replace it with the actual one.
  2. In the navigation pane, choose Services and Ingresses. In the upper right corner, click Create Service.
    In this example, only mandatory parameters for configuring SNI are listed. Retain the default settings for other parameters. For details, see Using the CCE Console.
  3. Configure basic parameters.
    Example
    Service Type
    Select LoadBalancer.
    None
    Service Name
    Enter a name, which can be the same as the workload name.
    nginx
    Namespace
    Select the namespace that the workload belongs to.
    default
    Selector
    Add the key and value of a pod label. The Service will be associated with the workload pods based on the label and direct traffic to the pods with this label.
    You can also click Reference Workload Label to use the label of an existing workload. In the dialog box displayed, select a workload and click OK.
    app:nginx
  4. Configure load balancer parameters.
    Example
    Load Balancer
    Select a load balance type and how the load balancer will be created. To enable HTTP/HTTPS on the listener port of a dedicated load balancer, the type of the load balancer must be Application (HTTP/HTTPS) or Network (TCP/UDP/TLS) & Application (HTTP/HTTPS).
    • Use existing: Only the load balancers in the same VPC as the cluster can be selected. If no load balancer is available, click Create Load Balancer to create one on the ELB console.
    • Auto create: The load balancer will be created in the VPC that the cluster belongs to. For details, see Table 1.
    An existing Dedicated load balancer of the Network (TCP/UDP/TLS) & Application (HTTP/HTTPS) type
  5. Configure access parameters.
    Example
    Service Affinity
    Whether to route external traffic to a local node or a cluster-wide endpoint. For details, see Service Affinity (externalTrafficPolicy).
    • Cluster-level: The IP addresses and ports of all nodes in a cluster can access the workload associated with the Service. However, accessing the Service may result in performance deterioration due to route redirection, and the client's source IP address may not be obtainable.
    • Node-level: Only the IP address and port of the node where the workload is located can access the workload associated with the Service. Accessing the Service will not result in a performance deterioration due to route redirection, and the client's source IP address can be obtained.
    Cluster-level
    Backend Routing Policy
    • Global: All ports use the same backend routing policy. For details about the parameters, see Table 1.
      CAUTION:
      When multiple ports are added, and some of them use different frontend protocols, the global backend routing policy cannot be applied across all protocols simultaneously. For any protocol to which the policy cannot be applied, CCE automatically falls back to the default configuration. For details about the mapping between the frontend and backend protocols of listeners and backend server groups, see Mapping Between Frontend and Backend Protocols for Load Balancing and Configuration Examples. Custom is recommended.
    • Custom: Each port can have a unique backend routing policy. You can configure the policy in Port > Backend Routing Policy.
    Custom
    Port
    • Protocol: the protocol used by the Service. If a Service needs to use ELB TLS or HTTP, set Protocol to TCP and select the target frontend protocol. For details, see Protocols for Services.
    • Container Port: the port that the workload listens on. For example, Nginx uses port 80 by default.
    • Service Port: the port used by the Service.
      • Listen on a port: The port ranges from 1 to 65535.
      • Listen on ports: ELB allows you to create listeners that listen on ports within specified ranges. Each listener can support up to 10 non-overlapping port ranges.
        To configure port ranges for load balancer listeners, ensure the following conditions are met:
        • The cluster version must be v1.23.18-r0, v1.25.13-r0, v1.27.10-r0, v1.28.8-r0, v1.29.4-r0, v1.30.1-r0, or later.
        • A dedicated load balancer must be used with TCP/UDP/TLS selected.
        • This function requires ELB. Before using this function, check whether ELB supports full-port listening and forwarding for layer-4 protocols in the current region.
    • Frontend Protocol: Set the protocol of the load balancer listener for establishing connections with clients. When a dedicated load balancer is selected, HTTP/HTTPS can be configured only when Application (HTTP/HTTPS) is selected and TLS can be configured only when Network (TCP/UDP/TLS) is selected.
    • Backend Routing Policy: If Backend Routing Policy is set to Custom, you can configure backend routing policies for ports that use different protocols. For details about the parameters, see Table 1.
    When a LoadBalancer Service is created, a random node port number (NodePort) is automatically generated.
    • Protocol: TCP
    • Container Port: 80
    • Service Port: 443
    • Frontend Protocol: HTTPS
    Table 1 Parameters for configuring the backend routing policy
    Example
    Backend Protocol
    The service protocol used by the load balancer's backend server group. TCP, HTTP, HTTPS, TLS, QUIC, and UDP are supported. For details about the mapping between the frontend and backend protocols of listeners and backend server groups, see Mapping Between Frontend and Backend Protocols for Load Balancing and Configuration Examples.
    HTTP
    Load Balancing Algorithm
    Load balancers forward requests from clients to the corresponding backend servers based on the configured traffic routing policies.
    • Weighted round robin: Requests are forwarded to different backend servers in turn based on the server weights you define in the target group.
    • Weighted least connections: Requests are forwarded to the backend server with the smallest connections-to-weight ratio.
    • Source IP hash: Requests from the same source IP address are forwarded to the same backend server by hashing the source IP address.
  6. Configure listener parameters.
    Constraint
    Example
    SSL Authentication
    • One-way authentication: Only the backend server is authenticated. If you also need to authenticate the identity of the client, select two-way authentication.
    • Two-way authentication: Both the clients and the load balancer authenticate each other. This ensures only authenticated clients can access the load balancer. No additional backend server configuration is required if you select this option.
    This parameter is available only when Frontend Protocol is set to HTTPS or TLS.
    Dedicated load balancers are available in clusters v1.23.14-r0, v1.25.9-r0, v1.27.6-r0, v1.28.4-r0, or later. Shared load balancers are available in clusters v1.28.15-r60, v1.29.15-r20, v1.30.14-r20, v1.31.10-r20, v1.32.6-r20, v1.33.5-r10, or later.
    CA Certificate
    If SSL Authentication is set to Two-way authentication, add a CA certificate to authenticate the client. A CA certificate is issued by a Certificate Authority (CA) and is used to verify the issuer of the client's certificate. If HTTPS two-way authentication is enabled, HTTPS connections can be established only if the client provides a certificate issued by a specific CA.
    This parameter is available only when Frontend Protocol is set to HTTPS or TLS and SSL Authentication is set to Two-way authentication.
    None
    Server Certificate
    Select a server certificate. If no certificate is available, create one on the ELB console. For details, see Adding a Certificate.
    cert-test
    Enable HTTP/2
    Whether to enable HTTP/2 for HTTPS requests between the client and the load balancer. Request forwarding using HTTP/2 improves access performance between your application and the load balancer. However, the load balancer still uses HTTP/1.x to forward requests to the backend server.
    This parameter is available only when Frontend Protocol is set to HTTPS.
    Enable
  7. Click Create.
To enable HTTP/2, add the following annotation:
kubernetes.io/elb.http2-enable: 'true'
The following shows an example YAML file where an existing load balancer is associated:
apiVersion: v1
kind: Service
  labels:
    app: test
    version: v1
  namespace: default
  annotations:
    kubernetes.io/elb.class: performance
    kubernetes.io/elb.id: 35cb350b-23e6-4551-ac77-10d5298f5204
    kubernetes.io/elb.protocol-port: https:443
    kubernetes.io/elb.cert-id: b64ab636f1614e1a960b5249c497a880
    kubernetes.io/elb.lb-algorithm: ROUND_ROBIN
  selector:
    app: test
    version: v1
  externalTrafficPolicy: Cluster
  ports:
    - name: cce-service-0
      targetPort: 80
      nodePort: 0
      port: 443
      protocol: TCP
  type: LoadBalancer
  loadBalancerIP: **.**.**.**
Table 2 HTTP/2 parameters
Type
String
If a Service is HTTP/HTTPS-compliant, configure the protocol and port in the format of "protocol:port".
where,
  • protocol: specifies the protocol used by the listener port. The value can be http or https.
  • ports: Service ports specified by spec.ports[].port.
For example, to use HTTPS, the Service port must be 443. Therefore, the parameter value is https:443.
String
ID of an ELB certificate, which is used as the HTTPS server certificate.
How to obtain: Log in to the ELB console and choose Certificates. In the certificate list, copy the ID under the target certificate name.
String
Whether HTTP/2 is enabled. Request forwarding using HTTP/2 improves access performance between your application and the load balancer. However, the load balancer still uses HTTP/1.x to forward requests to the backend server.
Options:
  • true: enabled
  • false: disabled (default value)
Note: HTTP/2 can be enabled or disabled only when the listener uses HTTPS. This parameter is invalid and defaults to false when the listener protocol is HTTP.
Step 3: Access the Workload
Test the HTTP/2 connection. Replace https://example.com with the actual address.
curl -I -k https://example.com --http2
Command output:
HTTP/2 200
date: Wed, 30 Jul 2025 08:03:45 GMT
content-type: text/html
content-length: 612
last-modified: Tue, 17 Apr 2018 13:46:53 GMT
etag: "5ad5facd-264"
accept-ranges: bytes
server: elb
Certain curl versions may not support HTTP/2. Before running the command, run curl --version to check for HTTP/2 in Features. If your curl version does not meet the requirements, obtain the latest version at the official curl website.
