Updated on 2026-08-26 GMT+08:00
CCE Secrets Manager for DEW
Introduction
The CCE Secrets Manager for DEW add-on (formerly dew-provider) interconnects with DEW. It allows you to mount secrets stored outside a cluster (DEW for storing sensitive information) to service pods. In this way, sensitive information can be decoupled from the cluster environment, which prevents information leakage caused by program hardcoding or plaintext configuration. With this add-on, you can enjoy the following capabilities:
  • Mounting secrets: You can mount secrets in DEW to service pods, reducing information leakage risks.
  • Scheduled rotation: After a pod runs normally, if the secret declared in the SecretProviderClass object and stored in CSMS is updated, the latest secret values in the pod can be updated through scheduled rotation. When using this capability, set the secret version to latest.
  • Real-time detection of SecretProviderClass changes: After a pod runs normally, if you modify the secret declared in the SecretProviderClass object (for example, a secret is added or the version is changed), the add-on can detect the change in real time and update the secret in the pod.
  • DEW includes Key Management Service (KMS), Cloud Secret Management Service (CSMS), and Key Pair Service (KPS). This add-on can only connect to CSMS.
  • A maximum of 500 SecretProviderClass objects can be created.
  • When the add-on is uninstalled, related CRD resources are deleted accordingly. Even if the add-on is reinstalled, the original SecretProviderClass object is unavailable. If you want to use the original SecretProviderClass resources after the add-on is uninstalled and then reinstalled, manually create them again.
Installing the Add-on
  2. In the navigation pane, choose Add-ons. Locate CCE Secrets Manager for DEW on the right and click Install.
  3. Configure Agency Settings. This configuration is supported by the add-on of 1.1.106 or later.
    Add-ons require runtime access to other cloud services. You need to configure an add-on agency to authorize these operations. For details, see Custom Agencies for Add-ons.
    • Create automatically: CCE automatically creates a default agency and uses this agency for the add-on. If there is a default agency, CCE will not create one again.
    • Use existing: Select one from the drop-down list. Ensure that the created agency has been assigned the required permissions. Otherwise, the add-on functions may be unavailable.
  4. In the Install Add-on sliding window, configure parameters in the Parameters area, as listed in the table below.
    Item
    Secret Synchronization Period
    rotation_poll_interval
    Rotation interval, in unit of m (instead of min).
    The rotation interval indicates the interval for sending a request to CSMS and obtaining the latest secret. The proper interval range is [1m, 1440m]. The default value is 2m.
  5. Click Install.
    After the add-on is installed, select the cluster and choose Add-ons in the navigation pane. On the displayed page, select Installed add-ons to view the add-on.
Components
Table 1 Add-on components
Component
Resource Type
dew-provider
A component that obtains specified secrets from CSMS and mounts them to service pods
DaemonSet
csi-secrets-store
A component that maintains two CRDs, SecretProviderClass and SecretProviderClassPodStatus (spcPodStatus). SecretProviderClass is used to describe the required secret (such as the secret version and name). It is created by users and will be referenced in service pods. spcPodStatus is used to trace the binding relationships between pods and secrets. It is automatically created by csi-driver and requires no manual operation. One pod corresponds to one spcPodStatus. After a pod is started, a spcPodStatus is generated for the pod. When the pod lifecycle ends, the spcPodStatus is deleted accordingly.
DaemonSet
Mounting a Secret
To mount a DEW secret to a container, take the following steps:
  1. Create a service account.
  2. Create a SecretProviderClass to define and obtain the DEW secret information.
    The token used to access DEW can operate in either of the following modes:
    • Use the temporary agency token associated with the add-on (centralized permission mode). When creating a SecretProviderClass, set useWorkloadCred to false. By default, the add-on uses the CCESecretEncryptAgency agency, which has permission to read any secret in DEW. You can also choose a custom agency during the add-on installation to reduce permissions if needed. This mode is simple to configure and is suitable for scenarios that do not require strict permission separation.
    • Use the temporary agency token associated with the workload's service account (least privilege mode). When creating a SecretProviderClass, set useWorkloadCred to true. You must associate a dedicated agency with the workload's service account and grant it only the permissions required to read the specific DEW secrets needed by the workload. The add-on then uses the temporary credential of this agency to access DEW, instead of relying on the permission of CCESecretEncryptAgency or its custom agency. This mode is suitable for scenarios with high security requirements.
  3. Mount the service account and SecretProviderClass to the service pod to ensure that the pod can securely access related secrets. You can use either of the following ways to mount a secret to a pod:
    • Using a volume: Secrets are mounted to containers as volumes. This is suitable when there is a large amount of data.
    • Using a CCE secret: Secrets are mounted to containers as environment variables. This is suitable when there is only a small amount of sensitive data.
The following describes the usage process.
  1. Create a ServiceAccount object to declare the name of the secret that can be used by the service pod. Before you take this step, ensure that the corresponding secret exists in CSMS. If the secret does not exist, an error occurs when the secret is obtained from CSMS. As a result, the pod cannot run normally. For details about how to create secrets in CSMS, see Creating a Secret.
    Figure 1 Secrets in DEW
    1. Create a YAML file for the ServiceAccount object.
      vim serviceaccount.yaml
      The following is the file content. You can declare the secret names that can be used by the service pod in the cce.io/dew-resource field. In this example, secret_1 and secret_2 can be referenced in the service pod. If you reference a secret that is not declared here, the mounting will fail. As a result, the pod cannot run normally.
      apiVersion: v1
      kind: ServiceAccount
        annotations:
          cce.io/dew-resource: "[\"secret_1\",\"secret_2\"]"  #secrets that allow pod to use
    2. Create the ServiceAccount object.
      kubectl apply -f serviceaccount.yaml
      Information similar to the following is displayed:
      serviceaccount/nginx-spc-sa created
    3. Check whether the ServiceAccount object has been created.
      kubectl get sa
      If the following information is displayed, the ServiceAccount object named nginx-spc-sa has been created and will be referenced in the service pods.
      NAME            SECRETS   AGE
      default         1         18d   # This is the default ServiceAccount object of the system.
      nginx-spc-sa    1         19s   # This is the newly created ServiceAccount object.
  2. Create a SecretProviderClass object to define and manage secrets from DEW so that secrets can be securely mounted to pods in the CCE cluster.
    1. Create a YAML file for the SecretProviderClass object.
      vim secretproviderclass.yaml
      The file content is shown below. The parameters.objects field specifies the secrets to be mounted, in array format.
      apiVersion: secrets-store.csi.x-k8s.io/v1
      kind: SecretProviderClass
        provider: cce     # The value is fixed at cce.
        parameters:
          objects: |
                - objectName: "secret_1"
                  objectAlias: "secret_test"
                  objectVersion: "v1"
                  objectType: "csms"
          useWorkloadCred: "false"  # (Optional) It defaults to false, which means that the temporary agency token associated with the add-on is used to access DEW. If the value is true, it means that the temporary agency token associated with the workload is used to access DEW.
      Table 2 objects parameters
      Type
      Mandatory
      objectName
      String
      Yes
      Secret name. Set this parameter to the secrets referenced in the service account. If there are multiple object names defined in the same SecretProviderClass, each object name must be unique. Otherwise, the mounting fails.
      objectAlias
      String
      No
      File name of the secret written into the container.
      • If this parameter is not specified, the name of the file that the secret is written to the pod will be objectName by default.
      • If this parameter is specified, the value of objectAlias must be different from that of objectName and objectAlias of other secrets and its own objectName. Otherwise, the mounting fails.
      objectType
      String
      Yes
      Secret type. Only csms is supported. A value other than csms is invalid.
      objectVersion
      String
      Yes
      Secret version.
      • Specify a version, for example, v1 or v2.
      • Use the latest version, for example, latest. If objectVersion is set to latest and the corresponding secret in CSMS is updated, scheduled rotation is automatically enabled. The secret in the pod is then updated at the interval specified by rotation_poll_interval.
    2. Create the SecretProviderClass object.
      kubectl apply -f secretproviderclass.yaml
      secretproviderclass/spc-test created
    3. Check whether the SecretProviderClass object has been created.
      kubectl get spc
      If information similar to the following is displayed, a SecretProviderClass object named spc-test has been created and will be referenced in the service pod.
      NAME   AGE
      spc-test   20h
  3. Create a service pod. In this example, this pod is used to run an Nginx application.
    1. Define a workload, reference the created ServiceAccount in serviceAccountName, reference the created SecretProviderClass in secretProviderClass, and specify the container's mountPath. (Do not use system directories such as / or /var/run, as this may prevent the pod from starting.)
      apiVersion: apps/v1
      kind: Deployment
        labels:
          app: nginx
        replicas: 1
        selector:
          matchLabels:
            app: nginx
        template:
            labels:
              app: nginx
            serviceAccountName: nginx-spc-sa   # Reference the created service account.
            volumes:
              - name: secrets-store-inline
                csi:
                  driver: secrets-store.csi.k8s.io   # Specify the Secrets Store CSI driver. The value is fixed.
                  readOnly: true                     # Set the volume to read-only to ensure that the secret is not modified.
                  volumeAttributes:
                    secretProviderClass: "spc-test"  # Reference the created SecretProviderClass.
            containers:
              - name: nginx-spc
                image: nginx:alpine
                imagePullPolicy: IfNotPresent
                volumeMounts:
                    mountPath: "/mnt/secrets-store"  # Define the mount path of secrets in the container.
                    readOnly: true
            imagePullSecrets:
              - name: default-secret
    2. Create the service pod.
      kubectl apply -f deployment.yaml
      deployment/nginx-spc created
    3. Check whether the pod has been created.
      kubectl get pod
      If STATUS of the pod is Running in the command output, the pod has been created.
      NAME                           READY   STATUS     RESTARTS     AGE
      nginx-spc-67c9d5b594-642np     1/1     Running    0            20s
    4. Obtain spcPodStatus to check whether the secret has been mounted to the pod.
      Run the following command to obtain the spcps resource name:
      kubectl get spcps
      NAME                                          AGE
      nginx-spc-67c9d5b594-642np-default-spc-test   103s
      Check whether the secret has been mounted to the pod.
      kubectl get spcps nginx-spc-67c9d5b594-642np-default-spc-test -o yaml
      If information similar to the following is displayed, the secret has been mounted to the pod.
      status:
      mounted: true
      objects:    # Mounted secret
      - id: secret_1
      version: v1
      podName: nginx-spc-67c9d5b594-642np   # Pod that references the SecretProviderClass object
      secretProviderClassName: spc-test               # SecretProviderClass object
      targetPath: /mnt/paas/kubernetes/kubelet/pods/6dd29596-5b78-44fb-9d4c-a5027c420617/volumes/kubernetes.io~csi/secrets-store-inline/mount
    5. Check whether the specified secret can be written.
      1. Enter the container.
        kubectl exec -ti nginx-spc-67c9d5b594-642np -- /bin/sh
      2. Search for the specified secret.
        cd /mnt/secrets-store/
        ls
        If information similar to the following is displayed, secret_1 declared in the SecretProviderClass object has been written to the pod.
        secret_1
    6. After the secret is mounted, a file with the same name as the object alias is generated in the path specified by mountPath in the container. The file content is the value of the secret in DEW. The application can read the file to obtain the secret. The method for reading the file is the same as that for reading a common file.
CCE Secrets Manager for DEW must be 1.1.111 or later.
  1. Create a service account for the workload and associate it with an IAM agency with the minimum necessary permissions. Before you take this step, ensure that the corresponding secret exists in DEW CSMS. If the secret does not exist, an error occurs when the secret is obtained from CSMS. As a result, the pod cannot run normally. For details about how to create secrets in DEW CSMS, see Creating a Secret.
    Figure 2 Secrets in DEW
      The file content is shown below. You can declare the secret names that can be used by the service pod in the cce.io/dew-resource field. In this example, secret_1 and secret_2 can be referenced in the service pod. If you reference a secret that is not declared here, the mounting will fail. As a result, the pod cannot run properly.
      apiVersion: v1
        annotations:
      kubectl get sa
      If information similar to the following is displayed, the ServiceAccount object named nginx-spc-sa has been created and will be referenced in the service pod.
      NAME            SECRETS   AGE
    4. Create an agency and grant it the permission to read only the secrets required by the workload. For details, see Creating an Agency and Assigning Permissions.
      In this example, the agency can only read secret_1 and secret_2.
          "Version": "1.1",
          "Statement": [
                  "Effect": "Allow",
                  "Action": [
                      "kms:dek:crypto",
                      "kms:cmk:get",
                      "kms:cmk:list"
                  "Effect": "Allow",
                  "Action": [
                      "csms:secretVersion:get",
                      "csms:secret:get"
                  "Resource": [
                      "CSMS:*:*:secretName:secret_1",
                      "CSMS:*:*:secretName:secret_2"
                  "Effect": "Allow",
                  "Action": [
                      "csms:secret:list"
    5. On the CCE console, choose Permissions and switch to the Pod Identity Association tab. Select a cluster and click Create. In the window that slides out from the right, select the previously created agency and associate it with the workload's service account.
      Figure 3 Associating an IAM agency with a workload's service account
        parameters:
          objects: |
                  objectVersion: "v1"
                  objectType: "csms"
          useWorkloadCred: "true"  # (Optional) It defaults to false, which means that the temporary agency token associated with the add-on is used to access DEW. If the value is true, it means that the temporary agency token associated with the workload is used to access DEW.
      Table 3 objects parameters
      Type
      Mandatory
      objectName
      String
      Yes
      objectAlias
      String
      No
      objectType
      String
      Yes
      objectVersion
      String
      Yes
      Secret version.
      kubectl get spc
      NAME   AGE
      spc-test   20h
      apiVersion: apps/v1
      kind: Deployment
        labels:
          app: nginx
        replicas: 1
        selector:
          matchLabels:
            app: nginx
        template:
            labels:
              app: nginx
            volumes:
                csi:
                  volumeAttributes:
            containers:
              - name: nginx-spc
                image: nginx:alpine
                volumeMounts:
                    readOnly: true
            imagePullSecrets:
      kubectl get pod
      kubectl get spcps
      NAME                                          AGE
      status:
      mounted: true
      - id: secret_1
      version: v1
        ls
        secret_1
CCE Secrets Manager for DEW must be 1.1.1 or later.
    Figure 4 Secrets in DEW
      apiVersion: v1
        annotations:
      kubectl get sa
      NAME            SECRETS   AGE
  2. Create a SecretProviderClass.
    1. Create the secretproviderclass.yaml file using the template below.
        provider: cce
        parameters:
          # Reference a secret in CSMS.
          objects: |
              objectType: "csms"
              objectVersion: "latest"
              jmesPath:
                - path: key1
                  objectAlias: dbusername01
                - path: key2
                  objectAlias: dbusername02
        # Create a CCE secret based on the CSMS secret and mount the secret to a pod.
        secretObjects:
          - secretName: my-secret-01
            type: Opaque
            data:
              - objectName: dbusername01
                key: db_username_01
              - objectName: dbusername02
                key: db_username_02
      Table 4 objects parameters
      Type
      Mandatory
      objectName
      String
      Yes
      Secret name. Set this parameter to the secret referenced in the service account. If there are multiple object names defined in the same SecretProviderClass, each object name must be unique. Otherwise, the mounting fails.
      objectType
      String
      Yes
      objectVersion
      String
      Yes
      Secret version
      jmesPath
      Array of Object
      Yes
      jmesPath is used to extract key-value pairs from objects in JSON format. CCE Secrets Manager for DEW uses this tool to support secret mounting. If a secret has multiple keys, you need to enter multiple paths and object aliases.
      • path: Enter the key in a DEW secret.
        The key cannot contain special characters such as +, -, {}, and () for the add-on of versions earlier than 1.1.57.
        In add-ons of version 1.1.57 and later versions, the key cannot contain backslashes (\). There is no restriction on other special characters.
      • objectAlias: name of the file mounted to a pod. The value must be the same as that of objectName defined in secretObjects.
      Table 5 secretObjects parameter
      Type
      Mandatory
      secretName
      String
      Yes
      Secret name
      type
      String
      Yes
      Secret type
      data
      Array of Object
      Yes
      • objectName: name of the file mounted to the pod. The value must be the same as that of objectAlias specified in objects.
      • key: key in a secret. The value can be used to reference the encrypted content in a pod.
    2. Create a SecretProviderClass object:
      secretproviderclass/nginx-deployment-spc-k8s-secrets created
      kubectl get spc
      NAME                               AGE
      nginx-deployment-spc-k8s-secrets   20h
    1. Define a workload, reference the created ServiceAccount in serviceAccountName, reference the created SecretProviderClass in secretProviderClass, and specify the container's mountPath. (Do not use system directories such as /or /var/run, as this may prevent the pod from starting.)
      vim deployment.yaml
      The file content is as follows:
      apiVersion: apps/v1
      kind: Deployment
        labels:
          app: nginx-k8s-secrets
        replicas: 1
        selector:
          matchLabels:
        template:
            labels:
            containers:
            - name: nginx-deployment-k8s-secrets
              image: nginx
              volumeMounts:   # Mount the SecretProviderClass to a container.
                - name: secrets-store-inline   # Name of the volume to be mounted
                  mountPath: "/mnt/secrets"    # Path of the container to be mounted
                  readOnly: true
              env:    # Set environment variables so that the container can reference the secret during running.
                - name: DB_USERNAME_01      # Environment variable name in the workload
                  valueFrom:
                    secretKeyRef:
                      name: my-secret-01    # Secret name specified in the SecretProviderClass
                      key: db_username_01   # The value of the key specified in the SecretProviderClass
                - name: DB_USERNAME_02
                  valueFrom:
                    secretKeyRef:
                      key: db_username_02
            imagePullSecrets:
            volumes:    # Use the secret specified in the SecretProviderClass to create a volume.
              - name: secrets-store-inline  # Custom volume name
                csi:
                  readOnly: true
                  volumeAttributes:
                    secretProviderClass: nginx-deployment-spc-k8s-secrets   # Name of the SecretProviderClass created in the previous step
      deployment/nginx-deployment-k8s-secrets created
      kubectl get pod
      nginx-deployment-k8s-secrets-6c945565fb-s7smv     1/1     Running    0            20s
    4. Verify the result.
      kubectl get secrets
      The output shows that a secret named my-secret-01 has been created using secret_1 specified in the SecretProviderClass object.
      NAME             TYPE                             DATA   AGE
      default-secret   kubernetes.io/dockerconfigjson   1      33d
      my-secret-01     Opaque                           2      1h
    5. Check whether the specified secret can be written to the container.
        kubectl exec -ti nginx-deployment-k8s-secrets-6c945565fb-s7smv -- /bin/sh
        echo $DB_USERNAME_01
        echo $DB_USERNAME_02
        If the following information is displayed, the secret has been successfully injected into the container through environment variables:
        value1
        value2
    6. The DEW secret has been injected as a container environment variable through the env configuration in the Deployment. The variable name is the same as the value of env.name. Applications can read environment variables to obtain secret values. The method is the same as that for reading common environment variables.
    Figure 5 Secrets in DEW
      apiVersion: v1
        annotations:
      kubectl get sa
      NAME            SECRETS   AGE
          "Version": "1.1",
          "Statement": [
                  "Effect": "Allow",
                  "Action": [
                      "kms:dek:crypto",
                      "kms:cmk:get",
                      "kms:cmk:list"
                  "Effect": "Allow",
                  "Action": [
                      "csms:secret:get"
                  "Resource": [
                  "Effect": "Allow",
                  "Action": [
                      "csms:secret:list"
      Figure 6 Associating an IAM agency with a workload's service account
        provider: cce
        parameters:
          objects: |
              objectType: "csms"
              jmesPath:
                - path: key1
                - path: key2
        secretObjects:
            type: Opaque
            data:
                key: db_username_01
                key: db_username_02
      Table 6 objects parameters
      Type
      Mandatory
      objectName
      String
      Yes
      objectType
      String
      Yes
      objectVersion
      String
      Yes
      Secret version.
      • Use the latest version, for example, latest. If objectVersion is set to latest and the corresponding secret in CSMS has been updated, scheduled rotation is automatically enabled, and the secret will be updated in the pod after the interval specified by rotation_poll_interval.
      jmesPath
      Array of Object
      Yes
      Table 7 secretObjects parameter
      Type
      Mandatory
      secretName
      String
      Yes
      Secret name
      type
      String
      Yes
      Secret type
      data
      Array of Object
      Yes
      kubectl get spc
      NAME                               AGE
      vim deployment.yaml
      apiVersion: apps/v1
      kind: Deployment
        labels:
        replicas: 1
        selector:
          matchLabels:
        template:
            labels:
            containers:
              image: nginx
                  readOnly: true
                  valueFrom:
                    secretKeyRef:
                  valueFrom:
                    secretKeyRef:
                      key: db_username_02
            imagePullSecrets:
                csi:
                  readOnly: true
                  volumeAttributes:
      kubectl get pod
      kubectl get secrets
      NAME             TYPE                             DATA   AGE
        value1
        value2
    kubectl get secrets
    NAME             TYPE                             DATA   AGE
Scheduled Rotation
As described before, you can use this add-on to mount secrets, that is, you can write the secrets stored in CSMS to a pod.
To change the secret version declared in the SecretProviderClass object to latest, run the following command:
  provider: cce
  parameters:
    objects: |
            objectVersion: "latest"  # change "v1"to "latest"
            objectType: "csms"
After the SecretProviderClass object is updated, the add-on periodically sends a request to CSMS to obtain the value of secret_1 of the latest version and updates the value to the pod that references the SecretProviderClass object. The interval for the add-on to periodically send requests is specified by rotation_poll_interval set in Installing the Add-on.
Real-Time Detection of SecretProviderClass Changes
SecretProviderClass changes are already detected in real time in Using a Volume to Mount a DEW Secret (Accessing DEW Through the Add-on Agency) and Scheduled Rotation. For demonstration, add secret_2 to the SecretProviderClass object as follows:
  provider: cce
  parameters:
    objects: |
            objectType: "csms"
          - objectName: "secret_2"
            objectVersion: "v1"
            objectType: "csms"
After the SecretProviderClass object is updated, the new secret_2 is quickly mounted to the pod that references the SecretProviderClass object.
Viewing Component Logs
You can use kubectl to view component logs.
  1. View the pods for running the add-on.
    kubectl get pod -n kube-system
    csi-secrets-store-76tj2       3/3     Running     0           11h
    dew-provider-hm5fq            1/1     Running     0           11h
  2. View the logs of the dew-provider component.
    kubectl logs dew-provider-hm5fq -n kube-system
    The command output is the detailed log information.
    I0321 13:49:29.319708       1 dew_provider.go:43] object [secret_1]'s version [v1] doesn't change, read from local
    I0321 13:49:29.319735       1 server.go:108] Start writing into mount point
    I0321 13:49:29.319793       1 server.go:117] Write [secret_1/]'s value into file successfully
    I0321 13:49:29.319801       1 server.go:123] Write secret file finished
    I0321 13:49:29.320284       1 server.go:67] "Servicing mount request" Pod="nginx-deployment-k8s-secrets-6c945565fb-s7smv" Namespace="default" ServiceAccount="nginx-spc-sa"
    I0321 13:49:29.617666       1 dew_provider.go:107] "Get secret successfully" name="secret_1" version="v1"
  3. View the logs of the csi-secrets-store component. The pod of the csi-secrets-store component contains multiple containers. When viewing logs, use the -c flag to specify a container. The secrets-store container is the major service container of the add-on and contains the majority of the logs.
    kubectl logs csi-secrets-store-76tj2 -c secrets-store -n kube-system
    I0321 10:17:29.314888       1 secrets-store.go:46] "Initializing Secrets Store CSI Driver" driver="secrets-store.csi.k8s.io" version="local-dev" buildTime=""
    I0321 10:17:29.314987       1 reconciler.go:143] "starting rotation reconciler" rotationPollInterval="2m0s"
    I0321 10:17:29.315141       1 server.go:126] "Listening for connections" address="//mnt/paas/kubernetes/kubelet/plugins/csi.sock"
    I0321 10:17:30.933328       1 nodeserver.go:359] "node: getting default node info\n"
    I0321 10:19:19.269337       1 nodeserver.go:353] "Using gRPC client" provider="cce" pod="nginx-spc-744b4c57dc-x74xq"
    I0321 10:19:19.543221       1 secretproviderclasspodstatus_controller.go:224] "reconcile started" spcps="default/nginx-spc-744b4c57dc-x74xq-default-spc-test"
Release History
Table 8 CCE Secrets Manager for DEW updates
Add-on Version
Supported Cluster Version
New Feature
1.1.130
v1.29
v1.30
v1.31
v1.32
v1.33
v1.34
v1.35
v1.36
Fixed some issues.
1.1.125
v1.29
v1.30
v1.31
v1.32
v1.33
v1.34
v1.35
v1.36
Supported CCE clusters v1.36.
1.1.123
v1.29
v1.30
v1.31
v1.32
v1.33
v1.34
v1.35
Fixed some issues.
1.1.119
v1.29
v1.30
v1.31
v1.32
v1.33
v1.34
v1.35
Supported CCE clusters v1.35.
1.1.112
v1.28
v1.29
v1.30
v1.31
v1.32
v1.33
v1.34
Fixed some issues.
1.1.111
v1.28
v1.29
v1.30
v1.31
v1.32
v1.33
v1.34
Supported using the workload or add-on's temporary agency credentials to access DEW.
1.1.95
v1.28
v1.29
v1.30
v1.31
v1.32
v1.33
v1.34
Supported CCE clusters v1.34.
1.1.82
v1.27
v1.28
v1.29
v1.30
v1.31
v1.32
v1.33
Fixed some issues.
1.1.81
v1.27
v1.28
v1.29
v1.30
v1.31
v1.32
v1.33
Supported CCE clusters v1.33.
1.1.75
v1.25
v1.27
v1.28
v1.29
v1.30
v1.31
v1.32
Supported CCE clusters v1.32.
1.1.60
v1.25
v1.27
v1.28
v1.29
v1.30
v1.31
Fixed some issues.
1.1.57
v1.25
v1.27
v1.28
v1.29
v1.30
v1.31
Supported CCE clusters v1.31.
1.1.33
v1.21
v1.23
v1.25
v1.27
v1.28
v1.29
v1.30
Supported CCE clusters v1.30.
1.1.3
v1.21
v1.23
v1.25
v1.27
v1.28
v1.29
Fixed some issues.
1.1.2
v1.21
v1.23
v1.25
v1.27
v1.28
v1.29
  • Supported CCE clusters v1.29.
  • Secrets can be created during CSMS secret synchronization.
1.0.31
v1.21
v1.23
v1.25
v1.27
v1.28
  • Supported CCE clusters v1.27.
  • Supported CCE clusters v1.28.
1.0.9
v1.19
v1.21
v1.23
v1.25
None
1.0.6
v1.19
v1.21
v1.23
v1.25
None
1.0.3
v1.19
v1.21
v1.23
v1.25
Supported CCE clusters v1.25.
1.0.2
v1.19
v1.21
v1.23
Supported CCE clusters v1.23.
1.0.1
v1.19
v1.21
Supported active detection of changes on the SecretProviderClass objects.
