Updated on 2026-09-21 GMT+08:00
KubeRay Add-on
Introduction
KubeRay is a native Kubernetes add-on designed to seamlessly manage and operate the Ray distributed computing framework within Kubernetes clusters, including CCE standard and Turbo clusters. Ray is a high-performance distributed computing library commonly used in scenarios like machine learning, reinforcement learning, and data processing. The goal of KubeRay is to integrate Ray into Kubernetes for easy deployment, management, and scaling of RayClusters.
As a Kubernetes operator, KubeRay handles the lifecycle of RayClusters through CRDs. Its core functions include:
  • RayCluster deployment: KubeRay handles the creation and management of both head and worker nodes in RayClusters automatically.
  • Auto scaling: The number of worker node pods within a RayCluster adjusts dynamically based on workload demands.
  • Resource management: KubeRay seamlessly integrates with Kubernetes' resource management system, including CPUs, memory, and GPUs.
  • Fault recovery: KubeRay monitors the health of RayClusters and automatically recovers any faulty nodes.
  • Logging and monitoring: KubeRay incorporates Kubernetes logging and monitoring tools to simplify debugging and optimization of Ray applications.
Open-source community: https://github.com/ray-project/kuberay
  • The CCE cluster (standard or Turbo) version must be v1.27 or later.
  • This add-on is being deployed. For details about the regions where this add-on is available, see the console.
Billing
To access the Ray Dashboard, you need to bind an EIP to any node in the cluster. Using an EIP is billed. For details, see EIP Price Calculator.
Installing the Add-on
  2. In the navigation pane, choose Add-ons. Locate KubeRay on the right and click Install.
  3. In the Install Add-on sliding window, configure the specifications. You can configure the CPU and memory quotas as required.
    • CPU quotas are measured in cores, with the value being an integer followed by the unit suffix (m), such as 100m.
      Table 1 CPU quotas
      Example Value
      Request
      100m
      The minimum number of CPUs required by a container
      Limit
      500m
      The maximum number of CPUs available for a container. If the CPU usage goes beyond the set limit, the instance might restart, impacting the add-on's regular operation.
    • Memory quotas are measured in bytes, with the value being an integer followed by the unit suffix (Mi), such as 100Mi. To manage 500 Ray pods, you need approximately 500 MiB of memory. You can modify the settings based on memory usage.
      Table 2 Memory quotas
      Example Value
      Request
      100Mi
      The minimum amount of memory required by a container
      Limit
      500Mi
      Maximum amount of memory available for a container. If the memory usage goes beyond the set limit, the instance might restart, impacting the add-on's regular operation.
  4. Configure the parameters. For details, seeTable 3.
    Table 3 Parameters
    Example Value
    Add-on Namespace
    default
    Namespace where the KubeRay add-on is in. The parameter defaults to default. You can use another namespace.
    Batch Scheduler
    Do not use
    Whether to use an external scheduler to schedule multiple RayJobs simultaneously. The parameter defaults to Do not use.
    • Do not use: An external scheduler is not used to schedule multiple RayJobs simultaneously.
    • Volcano: Volcano is used to schedule multiple RayJobs simultaneously. If you selected Volcano but do not have it on-premises, you are advised to install the Volcano Scheduler add-on. For details, see Volcano Scheduler.
    Service Port
    8080
    Port used by KubeRay to provide services for external systems. The parameter defaults to 8080.
  5. Click Install. If the add-on is in the Running state, it means that the add-on has been installed.
Components
Table 4 Add-on components
Component
Resource Type
kuberay-operator
Used to deploy Ray and manage its lifecycle.
Deployment
Use Case
The following provides different ways to submit a Ray job using the KubeRay add-on. For details about the workflow and application scenarios, see Table 5. For details about how to use KubeRay, see the official documentation.
Table 5 Comparison of different ways to submit a job
How to Submit a Job
Using a RayCluster custom resource
To get started, create a RayCluster custom resource, log in to the head node pod, and submit a job. The head node will then automatically distribute the job to a worker node for execution.
Using a RayJob custom resource
You can mount a Python script directly to the head node of a RayCluster using the RayJob. The head node will then distribute the job to a worker node for execution. In this example, the YAML file for creating a RayJob custom resource is provided, which can be customized as needed.
  1. The RayJob initiates a RayCluster with a head node and a set of worker nodes that scale based on job statuses.
  2. The RayJob mounts the Python script to the head node through ConfigMaps.
  3. The RayJob automatically executes the Python script to run the distributed counter job. Once the job is finished, the RayJob will be completed, but the RayCluster remains active until it is manually deleted.
  1. Install kubectl on an existing ECS and access the cluster using kubectl. For details, see Accessing a Cluster Using kubectl.
  2. Create a YAML file for configuring a RayJob custom resource. In this example, the file name is my-rayjob.yaml. You can change it as needed.
    vim my-rayjob.yaml
    If you encounter network issues when using an official Ray image, it may fail to be pulled. To avoid this, push the image to an SWR image repository in advance and update the image address in the file with the SWR image address. For details about how to push an image to SWR, see Migrating Images to SWR Using Docker Commands.
    The file content is as follows:
    apiVersion: ray.io/v1
    kind: RayJob    # The resource type is RayJob.
    spec:           # Define the specifications of the RayJob, including the job entry point, runtime environment, and RayCluster configuration.
      entrypoint: python /home/ray/samples/sample_code.py     # Specify the entry point command of the job. In this example, a Python script will be run.
      runtimeEnvYAML: |
        env_vars:   # Define the environment variables.
          counter_name: "test_counter"
      rayClusterSpec:     # Define the configuration of the RayCluster.
        headGroupSpec:    # Define the configuration of the head node in the RayCluster.
          rayStartParams: {}
          template:
              containers:
                - name: ray-head
                  image: rayproject/ray:2.52.0
                  ports:
                    - containerPort: 6379
                    - containerPort: 8265 # Ray dashboard
                    - containerPort: 10001
                  resources:
                    limits:
                      cpu: "1"
                    requests:
                      cpu: "200m"
                  volumeMounts:
                    - mountPath: /home/ray/samples
              volumes:
                - name: code-sample
                  configMap:
                    items:
                      - key: sample_code.py
                        path: sample_code.py
        workerGroupSpecs:    # Define the configuration of the worker nodes in the RayCluster.
          - replicas: 1
            minReplicas: 1
            maxReplicas: 5
            groupName: small-group
            rayStartParams: {}
            template:
                containers:
                  - name: ray-worker
                    resources:
                      limits:
                        cpu: "1"
                      requests:
                        cpu: "200m"
    # Define a specific job. The Python script sample_code.py is included, which creates a basic distributed counter.
    apiVersion: v1
    kind: ConfigMap
    data:
      sample_code.py: |
        import ray
        import os
        ray.init()
        @ray.remote
        class Counter:
            def __init__(self):
                # Used to verify runtimeEnv
                self.name = os.getenv("counter_name")
                assert self.name == "test_counter"
                self.counter = 0
            def inc(self):
                self.counter += 1
            def get_counter(self):
                return "{} got {}".format(self.name, self.counter)
        counter = Counter.remote()
        for _ in range(1000):
            ray.get(counter.inc.remote())
            print(ray.get(counter.get_counter.remote()))
  3. Create the RayJob and ConfigMap (used to store job code).
    kubectl create -f my-rayjob.yaml
    If information similar to the following is displayed, the resources have been created:
    rayjob.ray.io/my-rayjob created
    configmap/ray-job-code-sample created
  4. Check the deployment of the RayJob.
    1. Check whether the RayCluster has been created.
      kubectl get pod
      If information similar to that shown below is displayed, the resource has been created. In the command below, my-rayjob-raycluster-4464z-head-hb5qx indicates the head node pod, my-rayjob-raycluster-4464z-small-group-worker-csqb2 indicates the worker node pod, and my-rayjob-x2tv6 indicates the job execution status. If STATUS of my-rayjob-x2tv6 is Completed, it means that the job is complete.
      NAME                                                  READY    STATUS    RESTARTS    AGE
      my-rayjob-raycluster-4464z-head-hb5qx                 1/1      Running   0           24s
      my-rayjob-raycluster-4464z-small-group-worker-csqb2   1/1      Running   0           24s
      my-rayjob-x2tv6                                       1/1      Running   0           4s
    2. Check the status of the RayJob.
      kubectl get rayjob
      If information similar to that shown below is displayed, the job is still in progress. If JOB STATUS is SUCCEEDED, the job is complete.
      NAME        JOB STATUS    DEPLOYMENT STATUS    RAY CLUSTER NAME              START TIME            END TIME    AGE
      my-rayjob   RUNNING       Running              my-rayjob-raycluster-4464z    2025-02-10T07:16:26Z              28
    3. View the job execution status.
      kubectl logs my-rayjob-x2tv6
      Information similar to the following is displayed:
      2025-02-21 03:32:23,631 INFO cli.py:36 -- Job submission server address: http://my-rayjob-raycluster-4464z-head-svc.default.svc.cluster.local:8265
      2025-02-21 03:32:24,142 SUCC cli.py:60 -- --------------------------------------------
      2025-02-21 03:32:24,143 SUCC cli.py:61 -- Job 'my-rayjob-x2tv6' submitted successfully
      2025-02-21 03:32:24,143 SUCC cli.py:62 -- --------------------------------------------
      2025-02-21 03:32:24,143 INFO cli.py:286 -- Next steps
      2025-02-21 03:32:24,143 INFO cli.py:287 -- Query the logs of the job:
      2025-02-21 03:32:24,143 INFO cli.py:289 -- ray job logs my-rayjob-x2tv6
      2025-02-21 03:32:24,143 INFO cli.py:291 -- Query the status of the job:
      2025-02-21 03:32:24,143 INFO cli.py:293 -- ray job status my-rayjob-x2tv6
      2025-02-21 03:32:24,143 INFO cli.py:295 -- Request the job to be stopped:
      2025-02-21 03:32:24,143 INFO cli.py:297 -- ray job stop my-rayjob-x2tv6
      2025-02-21 03:32:24,147 INFO cli.py:304 -- Tailing logs until the job exits (disable with --no-wait):
      2025-02-21 03:32:25,011 INFO worker.py:1429 -- Using address 172.20.0.10:6379 set in the environment variable RAY_ADDRESS
      2025-02-21 03:32:25,012 INFO worker.py:1564 -- Connecting to existing Ray cluster at address: 172.20.0.10:6379...
      2025-02-21 03:32:25,017 INFO worker.py:1740 -- Connected to Ray cluster. View the dashboard at 172.20.0.10:8265
      test_counter got 1
      test_counter got 2
      test_counter got 3
      test_counter got 4
  5. Monitor and manage the RayCluster status, resource usage, and job execution in real time on the Ray Dashboard.
    1. Obtain the label of the head node pod in the RayCluster so that the pod can be identified and associated with the Service created in 5.b. You can change my-rayjob-raycluster-4464z-head-hb5qx as needed.
      kubectl describe pod my-rayjob-raycluster-4464z-head-hb5qx
      Information similar to that shown below is displayed. You are advised to use my-rayjob-raycluster-4464z-head as the label.
      Labels:           app.kubernetes.io/created-by=kuberay-operator
                        app.kubernetes.io/name=kuberay
                        ray.io/cluster=my-rayjob-raycluster-4464z
                        ray.io/group=headgroup
                        ray.io/identifier=my-rayjob-raycluster-4464z-head
                        ray.io/is-ray-node=yes
                        ray.io/node-type=head
    2. Create a YAML file for configuring a NodePort Service. In this example, the file name is ray-dashboard.yaml. You can change it as needed. This Service is used to expose services to external systems so that you can directly access the Ray Dashboard from a browser.
      vim ray-dashboard.yaml
      apiVersion: v1
      kind: Service
        labels:
          ray.io/identifier: my-rayjob-raycluster-4464z-head
        namespace: default
        ports:
        - name: cce-service-0
          port: 8265          # Port for accessing the Service, which is set to 8265
          protocol: TCP       # Protocol used for accessing the Service. The value can be TCP or UDP.
          targetPort: 8265    # Port used by the Service to access the target container. This port is closely related to the application running in a container and must be 8265.
        selector:             # Label selector
        externalTrafficPolicy: Cluster
        type: NodePort        # Service type. NodePort indicates that services are accessed through a node port.
    3. Create the Service.
      kubectl create -f ray-dashboard.yaml
      If information similar to the following is displayed, the Service has been created:
      service/ray-dashboard created
    4. Obtain the node port of the Service.
      kubectl get services
      Information similar to that shown below is displayed. 32638 specifies the node port.
      NAME                                  TYPE        CLUSTER-IP       EXTERNAL-IP   PORT(S)                                AGE
      ray-dashboard                         NodePort    10.247.147.102   <none>        8265:32638/TCP                         8s
    5. Enter http://<EIP of a cluster node>:32638 in the address bar of a browser to access the Ray Dashboard. Ensure that an EIP has been bound to a node in the cluster. To bind an EIP to a node, log in to the CCE console, click the cluster name to access the cluster console, choose Nodes in the navigation pane, click the Nodes tab in the right pane, and click the node name to go to the ECS console. For details, see Binding an EIP.
      If the page displayed is similar to Figure 2, the access is successful. You can monitor and manage the status of the RayCluster, track resource usage, and oversee job execution in real time using the Ray Dashboard. For example, you can check the status of job execution in the Recent jobs area.
      Figure 2 Accessing the Ray Dashboard
  6. Delete related resources.
    1. Delete the resources related to the RayJob.
      kubectl delete -f my-rayjob.yaml
      rayjob.ray.io "my-rayjob" deleted
      configmap "ray-job-code-sample" deleted
    2. Delete the resources related to the Service.
      kubectl delete -f ray-dashboard.yaml
      service "ray-dashboard" deleted
Common Issues
After removing the KubeRay add-on from a CCE cluster, the CRDs for the RayCluster, RayJob, and Ray Service will still be present. You can delete these remaining resources by following these steps:
  1. On the ECS that has been connected to the cluster, search for the CRDs related to Ray.
    kubectl get crd | grep ray
    Information similar to that shown below is displayed. It means that there are two related CRDs.
    rayclusters.ray.io                          2025-02-01T12:00:00Z
    rayjobs.ray.io                              2025-02-01T12:00:00Z
    rayservices.ray.io                          2025-02-01T12:00:00Z
  2. Delete the related resources. You can replace rayclusters.ray.io, rayjobs.ray.io, and rayservices.ray.io in the command as needed.
    kubectl delete crd rayclusters.ray.io
    kubectl delete crd rayjobs.ray.io
    kubectl delete crd rayservices.ray.io
    If information similar to the following is displayed, the resources have been deleted.
    customresourcedefinition.apiextensions.k8s.io "rayclusters.ray.io" deleted
    customresourcedefinition.apiextensions.k8s.io "rayjobs.ray.io" deleted
    customresourcedefinition.apiextensions.k8s.io "rayservices.ray.io" deleted
Release History
Table 6 KubeRay updates
Add-on Version
Supported Cluster Version
New Feature
Community Version
1.5.3
  • v1.29
  • v1.30
  • v1.31
  • v1.32
  • v1.33
  • v1.34
  • v1.35
  • v1.36
Supported CCE clusters v1.36.
v1.5.1
1.5.2
  • v1.29
  • v1.30
  • v1.31
  • v1.32
  • v1.33
  • v1.34
  • v1.35
  • Updated the add-on to its community version 1.5.1.
  • Supported CCE clusters v1.35.
v1.5.1
1.2.7
  • v1.28
  • v1.29
  • v1.30
  • v1.31
  • v1.32
  • v1.33
  • v1.34
Supported clusters v1.34.
v1.2.2
1.2.5
  • v1.27
  • v1.28
  • v1.29
  • v1.30
  • v1.31
  • v1.32
  • v1.33
Fixed some issues.
v1.2.2
1.2.4
  • v1.27
  • v1.28
  • v1.29
  • v1.30
  • v1.31
  • v1.32
  • v1.33
Supported clusters v1.33.
v1.2.2
1.2.3
  • v1.27
  • v1.28
  • v1.29
  • v1.30
  • v1.31
  • v1.32
Supported clusters v1.32.
v1.2.2
1.2.2
  • v1.27
  • v1.28
  • v1.29
  • v1.30
  • v1.31
The KubeRay add-on is now available.
v1.2.2
