Headless Services
Services allow internal and external pod access, but not the following scenarios:
- Accessing all pods at the same time
 - Pods in a Service accessing each other
This is where headless Service come into service. A headless Service does not create a cluster IP address, and the DNS records of all pods are returned during query. In this way, the IP addresses of all pods can be queried. StatefulSets use headless Services to support mutual access between pods.
apiVersion: v1 kind: Service # Object type (Service) metadata: name: nginx-headless labels: app: nginx spec: ports: - name: nginx # - name: nginx # Name of the port for communication between pods port: 80 # Port number for communication between pods selector: app: nginx # Select the pod whose label is app:nginx. clusterIP: None # Set this parameter to None, indicating that a headless Service is to be created.
Run the following command to create a headless Service:
# kubectl create -f headless.yaml service/nginx-headless created
After the Service is created, you can query the Service.
# kubectl get svc NAME TYPE CLUSTER-IP EXTERNAL-IP PORT(S) AGE nginx-headless ClusterIP None <none> 80/TCP 5s
Create a pod to query the DNS. You can view the records of all pods. In this way, all pods can be accessed.
$ kubectl run -i --tty --image tutum/dnsutils dnsutils --restart=Never --rm /bin/sh If you do not see a command prompt, try pressing Enter. / # nslookup nginx-0.nginx Server: 10.247.3.10 Address: 10.247.3.10#53 Name: nginx-0.nginx.default.svc.cluster.local Address: 172.16.0.31 / # nslookup nginx-1.nginx Server: 10.247.3.10 Address: 10.247.3.10#53 Name: nginx-1.nginx.default.svc.cluster.local Address: 172.16.0.18 / # nslookup nginx-2.nginx Server: 10.247.3.10 Address: 10.247.3.10#53 Name: nginx-2.nginx.default.svc.cluster.local Address: 172.16.0.19
