Situation Awareness
Configuring a Pod Security Policy
Updated on 2024-01-26 GMT+08:00
A pod security policy (PSP) is a cluster-level resource that controls sensitive security aspects of the pod specification. The PodSecurityPolicy object in Kubernetes defines a group of conditions that a pod must comply with to be accepted by the system, as well as the default values of related fields.
By default, the PSP access control component is enabled for clusters of v1.17.17 and a global default PSP named psp-global is created. You can modify the default policy (but not delete it). You can also create a PSP and bind it to the RBAC configuration.
  • In addition to the global default PSP, the system configures independent PSPs for system components in namespace kube-system. Modifying the psp-global configuration does not affect pod creation in namespace kube-system.
  • PodSecurityPolicy was deprecated in Kubernetes v1.21, and removed from Kubernetes in v1.25. You can use pod security admission as a substitute for PodSecurityPolicy. For details, see Configuring Pod Security Admission.
Modifying the Global Default PSP
Before modifying the global default PSP, ensure that a CCE cluster has been created and connected by using kubectl.
  1. Run the following command:
    kubectl edit psp psp-global
  2. Modify the required parameters, as shown in Table 1.
    Table 1 PSP configuration
    Item
    privileged
    Starts the privileged container.
    hostPID
    hostIPC
    Uses the host namespace.
    hostNetwork
    hostPorts
    Uses the host network and port.
    volumes
    Specifies the type of the mounted volume that can be used.
    allowedHostPaths
    Specifies the host path to which a hostPath volume can be mounted. The pathPrefix field specifies the host path prefix group to which a hostPath volume can be mounted.
    allowedFlexVolumes
    Specifies the FlexVolume driver that can be used.
    fsGroup
    Configures the supplemental group ID used by the mounted volume in the pod.
    readOnlyRootFilesystem
    Pods can only be started using a read-only root file system.
    runAsUser
    runAsGroup
    supplementalGroups
    Specifies the user ID, primary group ID, and supplemental group ID for starting containers in a pod.
    allowPrivilegeEscalation
    defaultAllowPrivilegeEscalation
    Specifies whether allowPrivilegeEscalation can be set to true in a pod. This configuration controls the use of Setuid and whether programs can use additional privileged system calls.
    defaultAddCapabilities
    requiredDropCapabilities
    allowedCapabilities
    Controls the Linux capabilities used in pods.
    seLinux
    Controls the configuration of seLinux used in pods.
    allowedProcMountTypes
    Controls the ProcMountTypes that can be used by pods.
    annotations
    Configures AppArmor or Seccomp used by containers in a pod.
    forbiddenSysctls
    allowedUnsafeSysctls
    Controls the configuration of Sysctl used by containers in a pod.
Example of Enabling Unsafe Sysctls in Pod Security Policy
You can configure allowed-unsafe-sysctls for a node pool. For CCE clusters of v1.17.17 and later versions, add configurations in allowedUnsafeSysctls of the pod security policy to make the configuration take effect. For details, see Table 1.
In addition to modifying the global pod security policy, you can add new pod security policies. For example, enable the net.core.somaxconn unsafe sysctls. The following is an example of adding a pod security policy:
apiVersion: policy/v1beta1
kind: PodSecurityPolicy
  annotations:
    seccomp.security.alpha.kubernetes.io/allowedProfileNames: '*'
  allowedUnsafeSysctls:
  - net.core.somaxconn
  allowPrivilegeEscalation: true
  allowedCapabilities:
  fsGroup:
    rule: RunAsAny
  hostIPC: true
  hostNetwork: true
  hostPID: true
  hostPorts:
  - max: 65535
    min: 0
  privileged: true
  runAsGroup:
    rule: RunAsAny
  runAsUser:
    rule: RunAsAny
  seLinux:
    rule: RunAsAny
  supplementalGroups:
    rule: RunAsAny
  volumes:
kind: ClusterRole
rules:
  - apiGroups:
    resources:
      - podsecuritypolicies
    resourceNames:
      - sysctl-psp
    verbs:
      - use
kind: ClusterRoleBinding
roleRef:
  kind: ClusterRole
  apiGroup: rbac.authorization.k8s.io
subjects:
- kind: Group
Restoring the Original PSP
If you have modified the default pod security policy and want to restore the original pod security policy, perform the following operations.
  1. Create a policy description file named policy.yaml. policy.yaml is an example file name. You can rename it as required.
    vi policy.yaml
    The content of the description file is as follows:
      annotations:
      privileged: true
      volumes:
      hostNetwork: true
      hostPorts:
        - min: 0
          max: 65535
      hostIPC: true
      hostPID: true
      runAsUser:
        rule: 'RunAsAny'
      seLinux:
        rule: 'RunAsAny'
      supplementalGroups:
        rule: 'RunAsAny'
      fsGroup:
        rule: 'RunAsAny'
    kind: ClusterRole
    rules:
      - apiGroups:
        resources:
        resourceNames:
          - psp-global
        verbs:
          - use
    roleRef:
      kind: ClusterRole
    subjects:
    - kind: Group
  2. Run the following command:
    kubectl apply -f policy.yaml
