Updated on 2026-06-16 GMT+08:00
Configuring Application Traffic Mirroring for an Nginx Ingress
Nginx ingresses can mirror inter-cluster traffic by duplicating access requests and sending them to the image backend without using the values returned from the backend. This allows for system simulation tests and fault locating without affecting the original requests. This section describes how to use Nginx ingresses to mirror traffic between applications in different clusters.
Figure 1 Traffic mirroring
Preparations
Step 1: Creating a Workload and Exposing Services Through an Ingress
  1. Deploy an application in cluster 1 and test the connection.
    Copy the following data and save it into the nginx-deploy.yaml file:
    apiVersion: apps/v1
    kind: Deployment
      labels:
        version: v1
      namespace: default
      selector:
        matchLabels:
          app: nginx
          version: v1
      template:
          labels:
            app: nginx
            version: v1
          containers:
            - name: container-1
              image: nginx:latest
              imagePullPolicy: IfNotPresent
          terminationGracePeriodSeconds: 30
          dnsPolicy: ClusterFirst
      replicas: 1
    apiVersion: v1
    kind: Service
      labels:
        app: nginx
      namespace: default
      selector:
        app: nginx
      externalTrafficPolicy: Cluster
      ports:
        - name: cce-service-0
          targetPort: 80
          port: 80
          protocol: TCP
      type: NodePort
    kind: Ingress
      namespace: default
      rules:
        - host: example.com
          http:
            paths:
              - path: /
                backend:
                  service:
                    port:
                      number: 80
                property:
      ingressClassName: nginx
  2. Run the following command to create a workload for cluster 1:
    kubectl apply -f nginx-deploy.yaml
  3. Repeat the preceding command to create the same workload in cluster 2.
Step 2: Configuring Traffic Replication
  • As the destination of traffic, cluster 2 does not require any modifications. You only need to configure cluster 1.
  • After the access traffic of the application in cluster 1 is replicated to the application in cluster 2, the client only receives the request response from cluster 1, while discarding the response from cluster 2.
Configure traffic mirroring for cluster 1. For more details, see Nginx Ingress Mirror.
kubectl patch ingress nginx --type merge --patch '"metadata": {"annotations": {"nginx.ingress.kubernetes.io/mirror-target": "http://<cluster_2_ingress_ip_address>:80/", "nginx.ingress.kubernetes.io/mirror-host": "example.com"}}'
In the preceding configuration, <cluster_2_ingress_ip_address> is the public IP address of the ingress load balancer in cluster 2.
Verification
Run the following command to access the application domain name example.com of cluster 1:
curl http://<cluster_1_ingress_ip_address>:80/ -H "Host: example.com"
Check nginx-ingress controller logs in cluster 1.
kubectl logs -f <cceaddon-nginx-ingress-controller_pod_name> -n kube-system
In the preceding command, <cceaddon-nginx-ingress-controller_pod_name> is the pod name of nginx-ingress controller.
According to the logs, whenever the domain name for the ingress in cluster 1 is requested, the request is duplicated and sent to the corresponding service in cluster 2.
