Updated on 2026-09-21 GMT+08:00
Scaling a Node Pool
When you create a node pool, it contains no nodes. Add nodes to ensure sufficient resources for your workloads. When resources are underutilized, scale in nodes to reduce costs.
The default node pool does not support autoscaling. To adjust the number of nodes, see Creating a Node (scale-out) or Deleting or Unsubscribing from a Node (scale-in).
Node Pool Resizing
Scaling out nodes
This operation adds nodes to a node pool. You specify the flavor and quantity of nodes to add. If node creation fails (for example, due to resource exhaustion), CCE retries automatically until the actual node count matches the expected count. If a node pool contains multiple flavors, nodes are billed according to the flavor you select for each scaling operation. For details, see Multi-flavor Billing Description.
Scaling in nodes
This operation removes nodes from a node pool. You specify the flavor and quantity of nodes to remove. You cannot designate specific nodes for deletion first. To delete a specific node, remove it directly from the node list. For details, see Deleting or Unsubscribing from a Node.
A node's system disk and data disks share its lifecycle. When a node is deleted, its EVS disks are also deleted, and all data is permanently lost and cannot be restored. For data requiring persistent storage, use PVs to decouple storage from the node lifecycle and ensure data durability.
  1. Log in to the CCE console.
  2. Click the cluster name to access the cluster console. Choose Nodes in the navigation pane. In the right pane, click the Node Pools tab.
  3. Click Resize next to the target node pool.
  4. In the Resize Node Pool dialog box, configure scaling parameters.
    • Resize: Add or reduce nodes for scaling.
    • Use the selected flavor to increase or decrease the number of nodes.
    • Select a billing mode only when adding nodes.
      • Yearly/Monthly
        You must specify the required duration if Yearly/Monthly is selected. You can choose whether to select Auto-renew based on site requirements. Your order will automatically renew on a monthly or yearly basis, depending on whether you purchased by month or by year.
      • Pay-per-use
        Resources will be billed based on usage duration. You can provision or delete resources at any time.
      • Spot price
        A postpaid billing mode, in which a spot cloud server will be billed based on the service duration at a lower price than that of a pay-per-use ECS cloud server with the same specifications. For details, see Spot Pricing ECSs.
        • If you purchase a data disk and an EIP while creating a spot pricing ECS, they will be automatically released when the ECS is released. If you attach data disks or bind EIPs to an existing spot pricing ECS, these resources must be manually released after the ECS is deleted.
        • Spot pricing ECSs cannot be reset, accepted for management, removed, migrated, changed to yearly/monthly, or upgraded by resetting the cluster. Before resetting a cluster for an upgrade, delete spot pricing nodes and set the number of pods in the spot pricing node pool to 0.
        • Spot pricing ECSs may be released if the quoted price is lower than the market price or if there are not enough resources available. Install the latest CCE Node Problem Detector add-on in the cluster so that you can receive a notification 5 minutes before a spot pricing ECS is released. This add-on generates a ReceivedReclaimNodeNotification event, adds the taint node-problem-controller.cce.io/SpotPriceNodeReclaimNotification: NoExecute to the node (spot pricing ECS), and evicts the pods on the node. This allows pods to be migrated to other nodes before the spot pricing ECS is deleted.
    • Configure the number of nodes to be added or deleted.
      • When scaling out a node pool, make sure that the total number of nodes, both existing and new, does not exceed the management scale of the current cluster.
      • When scaling in a node pool, make sure that the number of nodes to be removed does not exceed the number of nodes currently in the pool.
        Scaling in can result in the unavailability of resources associated with a node, such as local storage and workloads that were scheduled to that node. Exercise caution when performing this operation to avoid impact on running services.
  5. Click OK. If the node pool status changes from Scaling to Normal, the node pool has been scaled in or out.
Non-Standard Operations and Remediation
Performing non-standard operations may prevent a node pool from scaling as expected and cause unexpected issues. Do not perform any non-standard operations. The following table lists common non-standard operations, their impacts, and remediation steps.
Non-standard Operation
Impact
Remediation
Remove a node directly through kubectl delete node.
The cluster API server loses access to the node, and the node status in the node pool is displayed as Unavailable.
However, the ECS is not released, so the node pool's node count remains unchanged.
Perform all node operations through the CCE console.
To restore the node, reset it.
Delete a node through the ECS console.
Deleting an ECS on the ECS console renders the CCE node unavailable. After 10 minutes, CCE automatically deletes the node and triggers a scale-out to ensure the node pool maintains the expected number of nodes.
Delete the node through the CCE console.
Helpful Links
