(kubectl) Creating a Pod Mounted with an EVS Volume
After an EVS volume is created or imported to CCE, you can mount it to a workload.
EVS disks cannot be attached across AZs. Before mounting a volume, you can run the kubectl get pvc command to query the available PVCs in the AZ where the current cluster is located.
Notes and Constraints
The following configuration example applies to clusters of Kubernetes 1.13 or earlier.
- Use kubectl to connect to the cluster. For details, see Connecting to a Cluster Using kubectl.
- Run the following commands to configure the evs-deployment-example.yaml file, which is used to create a Deployment.
touch evs-deployment-example.yaml
vi evs-deployment-example.yaml
Example of mounting an EVS volume to a Deployment (PVC-based, shared volume):apiVersion: apps/v1 kind: Deployment metadata: name: evs-deployment-example namespace: default spec: replicas: 1 selector: matchLabels: app: evs-deployment-example template: metadata: labels: app: evs-deployment-example spec: containers: - image: nginx name: container-0 volumeMounts: - mountPath: /tmp name: pvc-evs-example imagePullSecrets: - name: default-secret restartPolicy: Always volumes: - name: pvc-evs-example persistentVolumeClaim: claimName: pvc-evs-auto-example
Table 1 Key parameters Parent Parameter
spec.template.spec.containers.volumeMounts
name
Name of the volume mounted to the container.
mountPath
Mount path of the container. In this example, the volume is mounted to the /tmp directory.
spec.template.spec.volumes
name
Name of the volume.
spec.template.spec.volumes.persistentVolumeClaim
claimName
Name of an existing PVC.
spec.template.spec.containers.volumeMounts.name and spec.template.spec.volumes.name must be consistent because they have a mapping relationship.
Mounting an EVS volume to a StatefulSet (PVC template-based, non-shared volume):
Example YAML:apiVersion: apps/v1 kind: StatefulSet metadata: name: deploy-evs-sas-in spec: replicas: 1 selector: matchLabels: app: deploy-evs-sata-in template: metadata: labels: app: deploy-evs-sata-in failure-domain.beta.kubernetes.io/region: ap-southeast-1 failure-domain.beta.kubernetes.io/zone: ap-southeast-1a spec: containers: - name: container-0 image: 'nginx:1.12-alpine-perl' volumeMounts: - name: bs-sas-mountoptionpvc mountPath: /tmp imagePullSecrets: - name: default-secret volumeClaimTemplates: - metadata: name: bs-sas-mountoptionpvc annotations: volume.beta.kubernetes.io/storage-class: sas volume.beta.kubernetes.io/storage-provisioner: flexvolume-huawei.com/fuxivol spec: accessModes: - ReadWriteOnce resources: requests: storage: 10Gi serviceName: wwww
Table 2 Key parameters Parent Parameter
metadata
name
Name of the created workload.
Image of the workload.
mountPath
spec
serviceName
Service corresponding to the workload. For details about how to create a Service, see Creating a StatefulSet.
spec.template.spec.containers.volumeMounts.name and spec.volumeClaimTemplates.metadata.name must be consistent because they have a mapping relationship.
- Run the following command to create the pod:
kubectl create -f evs-deployment-example.yaml
After the creation is complete, log in to the CCE console. In the navigation pane, choose Resource Management > Storage > EVS. Then, click the PVC name. On the PVC details page, you can view the binding relationship between the EVS volume and the PVC.
