Updated on 2026-08-13 GMT+08:00
Cluster Overview
Cloud Container Engine (CCE) is a Kubernetes cluster hosting service for enterprises. It manages the entire lifecycle of containerized applications and delivers scalable, high-performance solutions for deploying and managing cloud native applications.
Cluster Types
  • CCE standard clusters are for commercial use. They fully support the standard features of open-source Kubernetes clusters. Management and O&M of master nodes are not necessary. Depending on the service scenarios, you can choose to use either the container tunnel network model or the VPC network model. This cluster type is suitable for general scenarios without specific performance or scale requirements.
  • CCE Turbo clusters run on the Cloud Native 2.0 infrastructure. They feature hardware and software synergy, zero network performance loss, high security and reliability, and intelligent scheduling, offering you a one-stop, cost-effective container service. The Cloud Native 2.0 networks are available for large-scale, high-performance scenarios. In a CCE Turbo cluster, pod IP addresses are assigned from the VPC CIDR block, and pods and nodes can be in different subnets. External networks in the VPC can directly access pod IP addresses for high performance.
  • CCE Autopilot allows you to create serverless clusters with optimized Kubernetes support, freeing you from time-consuming O&M tasks. You are relieved from deployment, node management, and security configurations. Your costs are now calculated based on actual CPU and memory usages.
For details about the differences between these clusters, see Comparison Between Cluster Types.
Core Features
Feature
Cluster management
  • Cluster creation: You can create clusters of various types, choose from multiple scales, and adjust resources as needed to meet changing service demands quickly, efficiently, and cost-effectively. For details, see Buying a Cluster.
  • Cluster upgrade: You can upgrade your clusters to the latest Kubernetes version to leverage new features, enhance system stability, and boost performance. For details, see Upgrade Management.
Node or node pool management
  • Heterogeneous resource management: available across various Huawei Cloud computing instances, including VMs, BMSs, Kunpeng instances, Ascend computing, and GPU instances. For details, see Node Overview and Node Pool Overview.
  • Flexible configuration: Node pools can be flexibly configured. You can mix nodes of different specifications and billing types within one pool, and specify custom Kubernetes settings to suit various needs.
  • Auto scaling: Nodes can be automatically scaled for efficient resource management and quick response to changes in load, maximizing resource usage while minimizing costs. For details, see Node Scaling.
Workload management
  • Workload lifecycle management: CCE handles every stage of multiple workloads, from creation to upgrades and rollback. It also supports various configurations like environment settings, persistent storage, and logging for applications. For details, see Workload Overview.
  • Affinity scheduling: Node affinity scheduling and workload affinity/anti-affinity scheduling are available to meet scheduling needs in different scenarios. For details, see Overview.
  • Auto scaling: Multiple workload scaling policies such as HPA, CronHPA, and CustomedHPA are available. For details, see Workload Scaling.
  • Release: Grayscale releases and blue-green deployments are available in multiple access modes to maintain high availability and stability during updates and migrations.
Scheduling
Network
  • Container network: CCE clusters support the following network models: VPC, tunnel, and Cloud Native network 2.0. Each model offers unique features and benefits for various deployment scenarios. For details, see Overview.
  • Service: ClusterIP, NodePort, LoadBalancer, and DNAT Services are provided. For details, see Service Overview.
  • Ingress: LoadBalancer and Nginx ingresses are provided. For details, see Ingress Overview.
  • DNS: Cluster domain name resolution is provided. For details, see DNS Overview.
  • Storage add-on: CSI is supported. CCE Container Storage (Everest) is a CCE storage add-on developed based on CSI. It provides different types of persistent storage for containers.
  • StorageClass: EVS, SFS, SFS Turbo, OBS, DSS, local PV, and EV are provided. For details, see Storage Overview.
Auto scaling
  • Workload scaling: The number of workload pods can be adjusted based on service requirements and policies. For details, see Workload Scaling Rules.
  • Node scaling: The number of nodes in a cluster can be automatically adjusted to match changing service demands, freeing up underutilized resources and reducing waste. For details, see Node Scaling Rules.
Cloud native observability
  • Health Center: diagnoses cluster health, detects faults, identifies potential risks, and provides recommendations for resolving these issues. For details, see Overview.
  • Monitoring Center: monitors resources such as clusters, nodes, workloads, and pods, with support for custom cluster monitoring based on Prometheus. For details, see Overview.
  • Logging: collects, stores, and displays cluster and application logs on demand to aid in troubleshooting issues. For details, see Overview.
  • Alarm Center: allows for fast alarm searching and configuring within a cluster. Common alarm rules can be configured with just one click. For details, see Overview.
Cloud native cost governance
IT teams can view costs and resource usages by department, cluster, or namespace. They can also use methods like workload resource recommendations to optimize cluster efficiency and lower costs. For details, see Overview.
Permissions management
IAM authorization and RBAC-based namespace authorization are supported. For details, see Permissions Overview.
  • IAM authorization manages access to cloud services, including CCE clusters and associated resources like VPC, ELB, and ECS resources.
  • RBAC-based namespace authorization manages access to cluster resources, such as creating workloads in a cluster. However, for cluster resources, such as nodes and load balancers, which are dependent on external cloud services, IAM authorization of the respective cloud service applies.
Cluster Network
A cluster network consists of the following three networks:
  • Node network: assigns IP addresses to nodes in a cluster.
  • Container network: assigns IP addresses to containers in a cluster. Currently, multiple container network models are supported, and each model has its own operating principle.
  • Service network: assigns a fixed IP address to each Service used to access containers.
When you create a cluster, select an appropriate CIDR block for each network. Ensure that the CIDR blocks do not conflict with each other and have sufficient available IP addresses. You cannot change the container network model after the cluster is created. Select the right container network model in advance.
You are advised to learn about the cluster network and container network models before creating a cluster. For details, see Container Networks.
Number of Master Nodes in a Cluster and Cluster Scale
In a CCE cluster, the number of master nodes does not determine the cluster scale. They are two different aspects:
  • Master nodes: When creating a cluster on CCE, you have the option to choose one or three master nodes. If you choose three master nodes, the cluster will have high availability.
  • Cluster scale: refers to the maximum number of worker nodes that can be managed by a cluster. For example, you can choose a cluster management scale of 50 or 200 nodes when creating the cluster. The flavors of the master nodes are influenced by the cluster scale. Higher cluster scales require higher master node flavors.
    It is possible to change the cluster scale after creating the cluster. However, you can only increase the scale and cannot decrease it. For details, see Resizing a Cluster.
Cluster Lifecycle
Table 1 Cluster statuses
Status
Creating
A cluster is being created and is requesting cloud resources.
Running
A cluster is running properly.
Hibernating
A cluster is hibernating.
Awaking
A cluster is waking up.
Upgrading
A cluster is being upgraded.
Resizing
The cluster flavor is being changed.
Unavailable
A cluster is unavailable.
Deleting
A cluster is being deleted.
Figure 1 Cluster status transition
