Updated on 2025-11-06 GMT+08:00
Comparison Between Cluster Types
Comparison
CCE provides different types of clusters for you to select. The following table lists the differences between them.
Cluster Type
CCE Standard
CCE Turbo
CCE Autopilot
Positioning
Standard clusters that provide highly reliable and secure containers for commercial use
Next-generation clusters designed for Cloud Native 2.0, with accelerated compute, networking, and scheduling
Serverless clusters that do not need users to manage nodes and are billed based on actual CPU and memory usages
In such clusters, no node deployment, management, and security maintenance are needed.
Application Scenario
For users who expect to use container clusters to manage applications, obtain elastic compute resources, and enable simplified management on compute, network, and storage resources
For users who have higher requirements on performance, resource utilization, and full-scenario coverage
For users whose services suffer frequent traffic surges, such as users in the online education and e-commerce sectors
Network Model
Cloud Native 1.0 networks: for scenarios where requirements on performance are not high and there are not so many containers
  • Tunnel network
  • Virtual Private Cloud (VPC) network
Cloud Native 2.0 networks: for scenarios where there are many containers and high performance is needed
A maximum of 2,000 nodes is supported.
hostPort
Supported
Not supported
Not supported
Network Performance
The container network is overlaid with the VPC network, causing certain performance loss.
The VPC network and container network are flattened into one for zero performance loss.
Network Isolation
  • Tunnel networks: network policies for communications within a cluster
  • VPC networks: isolation not supported
Pods can be associated with security groups for isolation. This ensures consistent security isolation both within and outside a cluster.
Container Resource Isolation
cgroups are used to isolate common containers.
  • VM-level isolation is supported for secure containers that run only on physical machines.
  • cgroups are used to isolate common containers.
VM-level isolation
Edge Infrastructure Management
Not supported
Management of CloudPond edge sites
Not supported
