Updated on 2026-09-21 GMT+08:00
Changing Process ID Limits (kernel.pid_max)
Context
Process IDs (PIDs) are a fundamental resource on nodes. It is trivial to hit the task limit without hitting any other resource limits, which can then cause instability to a host machine.
You can adjust the PID limit (kernel.pid_max) according to service requirements.
kernel.pid_max Defaults
By the end of January 2022, CCE changed the default value of kernel.pid_max to 4194304 for EulerOS 2.5, CentOS 7.6, and Ubuntu 18.04 nodes in clusters v1.17 or later. Specific conditions:
  • Cluster version: v1.17.17 or later
  • Time when nodes were created: after January 30, 2022
If the preceding two conditions are not met, kernel.pid_max on EulerOS 2.5, CentOS 7.6, and Ubuntu 18.04 nodes defaults to 32768.
Table 1 kernel.pid_max defaults
OS
Clusters of 1.17.9 and Earlier
Clusters of 1.17.17 and Later
Nodes Created on or Before January 30, 2022
Nodes Created After January 30, 2022
EulerOS 2.5
32768
32768
4194304
CentOS 7.6
32768
32768
4194304
Ubuntu 18.04
N/A
32768
4194304
EulerOS 2.3
57344
57344
57344
EulerOS 2.9
N/A
4194304
4194304
Huawei Cloud EulerOS 2.0
N/A
N/A
4194304
Ubuntu 22.04
N/A
N/A
4194304
Huawei Cloud EulerOS 1.1
N/A
N/A
4194304
Change Suggestion
Viewing kernel.pid_max
Log in to the node and run the following command to obtain the value of kernel.pid_max:
sysctl kernel.pid_max
Command output:
kernel.pid_max = 32768
Change kernel.pid_max, if necessary, as instructed in Changing kernel.pid_max.
Checking Node PIDs
Log in to the node and run the following command to check how many PIDs are in use:
ps -eflL | wc -l
Command output:
691
Log in to the node and run the following command. 4194304 indicates the value of kernel.pid_max and is used as an example here.
echo kernel.pid_max = 4194304 >> /etc/sysctl.conf && sysctl -p
Check whether the returned value matches your configuration. If it does, the change is successful.
Command output:
Configuring kernel.pid_max When Creating a Node Pool
EulerOS 2.3: Configuration required.
For a node pool running EulerOS 2.5, CentOS 7.6, or Ubuntu 18.04 in a cluster v1.17.9 or earlier, kernel.pid_max is required. In clusters v1.17.17 or later, kernel.pid_max has been changed to 4194304 in the OS image and does not need to be configured.
You can configure kernel.pid_max using the pre-installation script when creating a node in a node pool.
When creating a node pool, choose Advanced Settings > Post-installation script and add the following command:
You can configure kernel.pid_max using the pre-installation script when creating a node.
When creating a node, choose Advanced Settings > Post-installation script and add the following command:
